查看: 2421|回復: 0
51單片機信號發生器 單緩沖的,想改成雙緩沖 代碼和原來圖都在資料里了
這是單緩沖的,想改成雙緩沖,但是改了好多次都不行,就是兩個函數可以分別在兩個示波器上,求大家幫忙看看!謝謝大家啦!
ORG     0000H        ;程序開始
       MOV     DPTR,#0FEFFH ;0832的地址
       MOV     SP,#60H      ;設置堆棧
START:
       JNB     P1.1,SJB     ;輸出三角波程序
           JNB     P1.4,ZXB     ;輸出正弦波程序
           SJMP    START        ;循環檢測開關情況
           RET
           /**************三角波************/
SJB:   MOV      R6,#00H     ;給R6初值
DA1:   MOV      A,R6        ;R6送A
       MOVX     @DPTR,A     ;初值給地址
           INC      R6          ;R6的內容既初值+1
           CJNE     R6,#0FFH,DA1;初值到最大
DA2:   DEC      R6          ;R6內容既初值-1
       MOV      A,R6        ;R6送A
       MOVX     @DPTR,A     ;初值給地址
       CJNE     R6,#00H,DA2 ;初值到最小
       JB       P1.1,START  ;開關斷開了既退出
       AJMP     SJB         ;跳轉到SJB處
/*************正弦波************/
ZXB:   MOV       R1,#00H     ;取表格初值
LOOP1: MOV       A,R1        ;在表格里取數送到指定地址
       MOV       DPTR,#TAB   ;把DPTR指針指向表格TAB的所在的地址。
           MOVC      A,@A+DPTR   ;將DPTR的地址加上累加器A存的偏移量,形成的新地址中的數取出給A
           MOV       DPTR,#0FEFFH;建立數據指針地址為0FEFFH
           MOVX      @DPTR,A     ;傳送數據時先把地址給DPTR,然后用MOVX指令把累加器A的內容傳送給@DPTR
           INC       R1          ;加一
           JB        P1.4,START  ;開關斷開了既退出
           AJMP      LOOP1       ;循環
TAB:   DB 080H,083H,086H,089H,08DH,090H,093H,096H
           DB 099H,09CH,09FH,0A2H,0A5H,0A8H,0ABH,0AEH
           DB 0B1H,0B4H,0B7H,0BAH,0BCH,0BFH,0C2H,0C5H
           DB 0C7H,0CAH,0CCH,0CFH,0D1H,0D4H,0D6H,0D8H
           DB 0DAH,0DDH,0DFH,0E1H,0E3H,0E5H,0E7H,0E9H
           DB 0EAH,0ECH,0EEH,0EFH,0F1H,0F2H,0F4H,0F5H
           DB 0F6H,0F7H,0F8H,0F9H,0FAH,0FBH,0FCH,0FDH
           DB 0FDH,0FEH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
           DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FEH,0FDH
           DB 0FDH,0FCH,0FBH,0FAH,0F9H,0F8H,0F7H,0F6H
           DB 0F5H,0F4H,0F2H,0F1H,0EFH,0EEH,0ECH,0EAH
           DB 0E9H,0E7H,0E5H,0E3H,0E1H,0DEH,0DDH,0DAH
           DB 0D8H,0D6H,0D4H,0D1H,0CFH,0CCH,0CAH,0C7H
       DB 0C5H,0C2H,0BFH,0BCH,0BAH,0B7H,0B4H,0B1H
           DB 0AEH,0ABH,0A8H,0A5H,0A2H,9FH,9CH,99H
           DB 96H,93H,90H,8DH,89H,86H,83H,80H
           DB 80H,7CH,79H,78H,72H,6FH,6CH,69H
           DB 66H,63H,60H,5DH,5AH,57H,55H,51H
           DB 4EH,4CH,48H,45H,43H,40H,3DH,3AH
           DB 38H,35H,33H,30H,2EH,2BH,29H,27H
           DB 25H,22H,20H,1EH,1CH,1AH,18H,16H
           DB 15H,13H,11H,10H,0EH,0DH,0BH,0AH
           DB 09H,08H,07H,06H,05H,04H,03H,02H
           DB 02H,01H,00H,00H,00H,00H,00H,00H
           DB 00H,00H,00H,00H,00H,00H,01H,02H
           DB 02H,03H,04H,05H,06H,07H,08H,09H
       DB 0AH,0BH,0DH,0EH,10H,11H,13H,15H
           DB 16H,18H,1AH,1CH,1EH,20H,22H,25H
           DB 27H,29H,2BH,2EH,30H,33H,35H,38H
           DB 3AH,3DH,40H,43H,45H,48H,4CH,4EH
           DB 51H,55H,57H,5AH,5DH,60H,63H,66H
           DB 69H,6CH,6FH,72H,76H,79H,7CH,80H
           RET
           END
資料.zip
22.67 KB, 下載次數: 5
