查看: 5819|回復: 14
蜂鳴器要加在單片機程序的哪里?
70黑幣
本帖最后由 1269210768 于 2020-6-26 20:59 編輯
當時鐘走到整點時,蜂鳴器鳴響一分鐘。按“E” 鍵,系統進入鬧鐘設定狀態,數碼管顯示屏不再顯示當前時間,而顯示鬧鐘設定值,最初為00.00.00AL,然后根據“B”“C”“D”鍵來設定鬧鐘的秒,分,時。設定完畢,再次按“E”鍵,系統回到時鐘走時狀態,繼續走時。其中AL代表鬧鐘狀態alarm,且在鬧鐘設定時,后臺的時鐘繼續走時。
當時鐘時間與鬧鐘時間一致時,蜂鳴器鳴響一分鐘。蜂鳴器播放音樂做鬧鐘鈴聲。
我的程序在下面,這個蜂鳴器的程序應該怎么編程,可以教一下我這個要怎么編輯嗎?謝謝
#include<regx51.h>
#define TIME=1200
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
unsigned int cnt=0;
unsigned char i=0;
unsigned long sec=0;
unsigned char second = 0;
unsigned char minute = 0;
unsigned char hour = 0;
unsigned char code segment_code[10] = {0x3f, 0x06, 0x5b, 0x4f,0x66, 0x6d, 0x7d, 0x07,0x7f, 0x6f};
unsigned char digital_tube[8]={0x3f,0x3f,0x3f,0x3f,0x3f,0x39,0x38};
void ScanLed()
        static unsigned char display_bit = 0;
        switch (display_bit)
        case 0:
                P2=0xfe;
                break;
        case 1:
                P2=0xfd;
                break;
        case 2:
                P2=0xfb;
                break;
        case 3:
                P2=0xf7;
                break;
        case 4:
                P2=0xef;
                break;
        case 5:
                P2=0xdf;
                break;
        case 6:
                P2=0xbf;
                break;
        case 7:
                P2=0x7f;
                break;
        default:
                break;
        P0=digital_tube[display_bit];
                display_bit++;
        if (display_bit == 8)
                display_bit = 0;
        TMOD = 0x01;
    TH0 = 64536 / 256;
    TL0 = 64536 % 256;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
        while (1)
void delay(unsigned int xms)
        unsigned int i,j;
        for(i=xms;i>0;i--)
                for(j=100;j>0;j--);
void Timer0() interrupt 1
        static int index = 0;
        TH0 = 64536 / 256;
   TL0 = 64536 % 256;
        index++;
        ScanLed();
        if (index == 1000)
                index = 0;
                second++;
        if (second == 60)
                second = 0;
                minute++;
        if (minute == 60)
                minute = 0;
                hour++;
        if (hour == 24)
                hour = 0;
        if(K4==0)
  delay(10);
   if(K4==0)
hour++;
if(hour==24)        hour=0;
  while(!K4);
if(K3==0)
  delay(10);
  if(K3==0)
  minute++;
  if(minute==60)        minute=0;
while(!K3);
if(K2==0)
delay(10);
if(K2==0)
second++;
if(second==24)       second=0;
while(!K2);
if(K1==0)
delay(10);
if(K1==0)
hour=0;
minute=0;
second=0;
while(!K1);
digital_tube[0] = segment_code[hour / 10];
digital_tube[1] = segment_code[hour % 10]+0x80;
digital_tube[2] = segment_code[minute / 10];
digital_tube[3] = segment_code[minute % 10]+0x80;
digital_tube[4] = segment_code[second / 10];
digital_tube[5] = segment_code[second % 10]+0x80;
digital_tube[6] = 0x39;
digital_tube[7] = 0x38;
ID:584814 發表于 2020-6-23 15:26 | 只看該作者
加在哪里都無所謂,只要鬧鐘程序觸發后能調用到就可以。
ID:665461 發表于 2020-6-25 04:04 | 只看該作者
按照程序的安排來看,這個不是必要的操作,所以加在哪都可以
ID:452950 發表于 2020-6-25 12:43 | 只看該作者
要求是當時鐘時間與鬧鐘時間一致時,蜂鳴器鳴響一分鐘。
那就每秒比對一次時間,到點就控制蜂鳴器響60s就好了。
ID:789451 發表于 2020-6-25 13:48 | 只看該作者
當蜂鳴器需要調用時可以響應就行,自己可以找個位置加上,仿真調試實驗一下!
ID:750684 發表于 2020-9-7 08:28 | 只看該作者
ID:311846 發表于 2020-9-7 09:47 | 只看該作者
你這個程序放在主循環即可,能觸發就行影響不大。養成良好的編程習慣,定時器盡量不要放代碼,盡量將執行程序放在主循環,
ID:235954 發表于 2020-9-7 11:57 | 只看該作者
制作函數模塊,用的時候可以調用
ID:816586 發表于 2020-9-7 13:31 | 只看該作者
制作蜂鳴器函數模塊,需要使用的時候可以直接調用就行了
ID:420836 發表于 2020-9-8 08:33 | 只看該作者
它應該在調用它的main函數中。
ID:348041 發表于 2020-9-9 08:13 | 只看該作者
建議嘗試采用時間片輪詢的方式寫整個程序的架構,可以讓你對單片機的運轉方式更加了解
ID:807182 發表于 2020-9-16 15:25 | 只看該作者
蜂鳴器的代碼加到那都可以,看心情
ID:820049 發表于 2020-9-17 09:18 | 只看該作者
如果是蜂鳴器檢測時間的程序的話可以放在小時計數之后。影響不大
ID:820049 發表于 2020-9-17 09:20 | 只看該作者
放在主函數中小時計時的后面,我習慣這么做
ID:582903 發表于 2020-9-17 10:55 | 只看該作者
在main里面加,到時相應位置1
