查看: 4185|回復: 6
求教 單片機程序應該在哪個地方把這些按鈕加上去啊?
ID:786338 發(fā)表于 2020-6-22 16:33 | 顯示全部樓層 |閱讀模式
50黑幣
本帖最后由 1269210768 于 2020-6-23 08:43 編輯
按下A鍵啟動,數(shù)碼管的時、分、秒顯示00.00.00CL,從零開始,按照鐘表走時,再次按下A鍵停止,數(shù)碼管保持顯示當前時間,其中,CL代表時鐘狀態(tài)clock。
按“B” 鍵一次,秒鐘加一,按多次則加多次,秒鐘到59再按則為0;
按“C” 鍵一次,分鐘加一,按多次則加多次,分鐘到59再按則為0;
按“D” 鍵一次,時鐘加一,按多次則加多次,時鐘到23再按則為0;
這個是我源程序,A按鍵應該怎么改,我要怎么改A才能控制啟停,求教!!
#include<regx51.h>
#define TIME=1200
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
unsigned int cnt=0;
unsigned char i=0;
unsigned long sec=0;
unsigned char second = 0;
unsigned char minute = 0;
unsigned char hour = 0;
unsigned char code segment_code[10] = {0x3f, 0x06, 0x5b, 0x4f,0x66, 0x6d, 0x7d, 0x07,0x7f, 0x6f};
unsigned char digital_tube[8]={0x3f,0x3f,0x3f,0x3f,0x3f,0x39,0x38};
void ScanLed()
        static unsigned char display_bit = 0;
        switch (display_bit)
        case 0:
                P2=0xfe;
                break;
        case 1:
                P2=0xfd;
                break;
        case 2:
                P2=0xfb;
                break;
        case 3:
                P2=0xf7;
                break;
        case 4:
                P2=0xef;
                break;
        case 5:
                P2=0xdf;
                break;
        case 6:
                P2=0xbf;
                break;
        case 7:
                P2=0x7f;
                break;
        default:
                break;
        P0=digital_tube[display_bit];
                display_bit++;
        if (display_bit == 8)
                display_bit = 0;
        TMOD = 0x01;
    TH0 = 64536 / 256;
    TL0 = 64536 % 256;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
        while (1)
void delay(unsigned int xms)
        unsigned int i,j;
        for(i=xms;i>0;i--)
                for(j=100;j>0;j--);
void Timer0() interrupt 1
        static int index = 0;
        TH0 = 64536 / 256;
   TL0 = 64536 % 256;
        index++;
        ScanLed();
        if (index == 1000)
                index = 0;
                second++;
        if (second == 60)
                second = 0;
                minute++;
        if (minute == 60)
                minute = 0;
                hour++;
        if (hour == 24)
                hour = 0;
        if(K4==0)
  delay(10);
   if(K4==0)
hour++;
if(hour==24)        hour=0;
  while(!K4);
if(K3==0)
  delay(10);
  if(K3==0)
  minute++;
  if(minute==60)        minute=0;
while(!K3);
if(K2==0)
delay(10);
if(K2==0)
second++;
if(second==24)       second=0;
while(!K2);
if(K1==0)
delay(10);
if(K1==0)
hour=0;
minute=0;
second=0;
while(!K1);
digital_tube[0] = segment_code[hour / 10];
digital_tube[1] = segment_code[hour % 10]+0x80;
digital_tube[2] = segment_code[minute / 10];
digital_tube[3] = segment_code[minute % 10]+0x80;
digital_tube[4] = segment_code[second / 10];
digital_tube[5] = segment_code[second % 10]+0x80;
digital_tube[6] = 0x39;
digital_tube[7] = 0x38;
ID:332444 發(fā)表于 2020-6-22 17:04 | 顯示全部樓層
ID:739545 發(fā)表于 2020-6-22 17:28 | 顯示全部樓層
ScanLed()函數(shù)不就是按鍵么,在你的中斷函數(shù)里面,也可以放到mian函數(shù)的while(1)里面去
ID:786916 發(fā)表于 2020-6-22 17:39 | 顯示全部樓層
右鍵單擊橫線  選擇 PLACE WIRE LABLE
ID:672631 發(fā)表于 2020-6-22 19:40 | 顯示全部樓層
試一試加到main()里面,
if(K1==0)second++;
if(K1==0)minute++;
if(K1==0)hour++;(沒加按鍵去抖,要給一點延時)
或者可以試一試加在定時器中斷函數(shù)里面
ID:786338 發(fā)表于 2020-6-23 08:37 | 顯示全部樓層
123ty 發(fā)表于 2020-6-22 19:40
試一試加到main()里面,
if(K1==0)second++;
if(K1==0)minute++;
好的我試試,謝謝
ID:786338 發(fā)表于 2020-6-23 08:41 | 顯示全部樓層
試一試加到main()里面,
if(K1==0)second++;
if(K1==0)minute++;
這樣就變成了A按下就都加一啊,我只是想讓A鍵控制啟停
