LCD5110屏是一款早期用于手機上的顯示屏,其與外部的接口采用SPI通訊方式,具有顯示信息較多和節能的特點 SC95F8616核心板則是一款基于SC95F8616最小系統板,未配置板載的調試下載工具,需借助板上調試下載接口以外掛的方式來開發。 LCD5110屏與開發板的連接關系如下: P27 -- LED+ P24 -- D0 (SCL) P25 -- D1 (SDI) P22 -- D/C P26 -- RST P23 -- CS 為實現顯示屏的輸出所定義的高低電平輸出引腳為: #define LCD_LED_High() GPIO_WriteHigh(GPIO2,GPIO_PIN_7); //PA7 #define LCD_CLK_H GPIO_WriteHigh(GPIO2,GPIO_PIN_4); // PA4 #define LCD_CLK_L GPIO_WriteLow(GPIO2,GPIO_PIN_4); #define LCD_DIN_H GPIO_WriteHigh(GPIO2,GPIO_PIN_5); // PA5 #define LCD_DIN_L GPIO_WriteLow(GPIO2,GPIO_PIN_5); #define LCD_DC_H GPIO_WriteHigh(GPIO2,GPIO_PIN_2); // PA2 #define LCD_DC_L GPIO_WriteLow(GPIO2,GPIO_PIN_2); #define LCD_CS_H GPIO_WriteHigh(GPIO2,GPIO_PIN_3); // PA3 #define LCD_CS_L GPIO_WriteLow(GPIO2,GPIO_PIN_3); #define LCD_RST_H GPIO_WriteHigh(GPIO2,GPIO_PIN_6); // PA6 #define LCD_RST_L GPIO_WriteLow(GPIO2,GPIO_PIN_6); 定義相關引腳為輸出口的函數為:
- void LCD_GPIO_Cogfig(void)
- GPIO_Init(GPIO2,GPIO_PIN_7,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_6,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_5,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_4,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_3,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_2,GPIO_MODE_OUT_PP);
- LCD_LED_High();
LCD5110屏的初始化函數為:
- void LCD5510_Init(void)
- LCD_GPIO_Cogfig();
- mdelay(800);
- LCD_reset_hard;
- LCD_write_cmd(0x21);
- LCD_write_cmd(0x06);
- LCD_write_cmd(0x13);
- LCD_write_cmd(0xc8);
- LCD_write_cmd(0x20);
- LCD_write_cmd(0x0c);
- LCD_write_cmd(Y_Page_Addr);
- LCD_write_cmd(X_Col_Addr);
- LCD_clr_scr();
實現圖示顯示效果的主程序為:
- void main(void)
- uint16_t i,j;
- GPIO_Init(GPIO0,GPIO_PIN_6,GPIO_MODE_OUT_PP);
- mdelay(200);
- LCD5510_Init();
- LCD_prints(0,0,"SC95F8616 TEST");
- LCD_prints(0,1,"LCD5510 ");
- LCD_prints(0,2,"jinglixixi");
- while(1);
2020-6-22 13:59 上傳
LCD5110屏顯示效果
