查看: 1489|回復: 1
雅馬哈 642 驅屏源碼
ID:786183 發表于 2020-6-21 22:52 | 顯示全部樓層 |閱讀模式
/*  CONFIDENTIAL        */
/*  Copyright (C) 2011 Yamaha Corporation. All rights reserved.                 */
/*  Module          : $Workfile: LCD_HSD043I9W1.h $                             */
/*  Description     : Clock, DisplayScan Prameter Include header                */
/*  Version         : $Rev: 89 $                                                */
/*  Last UpDate Time: $Date:: 2012-05-31 17:57:20#$                             */
/*  FOOT NOTE       : adjust 4tab                                               */
/*  AUTHOR          : H.Katayama                                                */
#ifndef _LCD_HSD043I9W1_
#define _LCD_HSD043I9W1_
/*                      I N C L U D E                                           */
#include "Yvc1.h"
/*                      D E F I N E                                             */
/* WQVGA LCD HannStar HSD043I9W1                                                */
/* DotClock: 9.529MHz                                                           */
/* 480亊272 Digital interface TFT                                               */
/*                      Clock Setting                                   */
/* DotClock , System Clock <Common>                                     */
/* PLLCTL[2:0]      = 'HHL'                                             */
/* XIN              = 9.529MHz  DTCKIN x  ----------->* Dot Clock       */
/* DTCKIN           = ---                 |   -----                     */
/* Dot Clock        = XIN    33M               *->| PLL |->* System Clock    */
/* System Clock     = 77.82MHz                -----                     */
/* 仸DTCKS_N Pin    = 'H'                                               */
/* 仸TCON Pin       = 'L'                                               */
const T_YVC1_DATA tYvc1Data = {
        /* Clock : Clk[3]                                        */
        {                                /*           |  D7   |  D6   |  D5   |  D4   |  D3   |  D2   |  D1   |  D0   |  */
                0x00,                /*  0: R#01h | PLLR[4:0]                             |  "0"  |  "0"  | PLL[8]|  */   //00
                //0x40,                /*  1: R#02h | PLLF[7:0]     //00                                                |  *///40
                0x40,
                0x84,                /*  2: R#03h | DTSEL | REVCK | //00             DTDV[5:0]                        |  *///84
        /* Display scan : Disp[23]                        */
                0x12,                /*  0: R#06h |  "0"  |  "0"  | CSYOE | VSTM  | REVSY | REVBL | VTL[9:8]      |  */
                0x09,                /*  1: R#07h | VTL[7:0]                                                      |  */
                0x04,                /*  2: R#08h |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | HTL[10:8]             |  */
                0x1f,                /*  3: R#09h | HTL[7:0]                                                      |  */
                0x02,                /*  4: R#0Ah |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | VBLS[9:8]     |  */
                0x01,                /*  5: R#0Bh | VBLS[7:0]                                                     |  */
                0x03,                /*  6: R#0Ch |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | HBLS[10:8]            |  */
                0xf7,                /*  7: R#0Dh | HBLS[7:0]                                                     |  */
                0x00,                /*  8: R#0Eh |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | VBLE[9:8]     |  */
                0x21,                /*  9: R#0Fh | VBLE[7:0]                                                     |  */
                0x00,                /* 10: R#10h |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | HBLE[10:8]            |  */
                0xd7,                /* 11: R#11h | HBLE[7:0]                                                     |  */
                0x08,                /* 12: R#12h | PDDS[4:0]                             | NMCMD | VDS[9:8]      |  */
                0x21,                /* 13: R#13h | VDS[7:0]                                                      |  */
                0x00,                /* 14: R#14h |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | HDS[10:8]             |  */
                0xd7,                /* 15: R#15h | HDS[7:0]                                                      |  */
                0x02,                /* 16: R#16h |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | VDE[9:8]      |  */
                0x01,                /* 17: R#17h | VDE[7:0]                                                      |  */
                0x03,                /* 18: R#18h |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | HDE[10:8]             |  */
                0xf7,                /* 19: R#19h | HDE[7:0]                                                      |  */
                0x01,                /* 20: R#1Ah |  "0"  |  "0"  |   HSW[9:8]    |            VSW[3:0]           |  */
                0x7f,                /* 21: R#1Bh | HSW[7:0]                                                      |  */
                0x03,                /* 22: R#1Ch |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | SYEN  | DTEN  |  */
        /* Video Output Control : VideoOut        */
                0x07,                /*  0: R#31h |  "0"  |  "0"  |  "0"  |  "0"  |  "0"  | FRCE  | FRCM  | VOBSEL|  */
        /* T-CON : TCON[23]                                        */
        /* 枹巊梡 */
                0x00,                /*  0: R#67h | REVSH |  "0"  | STHE[10:8]                                    |  */
                0x00,                /*  1: R#68h | STHE[7:0]                                                     |  */
                0x00,                /*  2: R#69h | STHS[7:0]                                                     |  */
                0x00,                /*  3: R#6Ah | REVLH |  "0"  | LDHE[10:8]            | LDHS[10:8]            |  */
                0x00,                /*  4: R#6Bh | LDHE[7:0]                                                     |  */
                0x00,                /*  5: R#6Ch | LDHS[7:0]                                                     |  */
                0x00,                /*  6: R#6Dh | REVCV |  "0"  | CKVE[10:8]            | CKVS[10:8]            |  */
                0x00,                /*  7: R#6Eh | CKVE[7:0]                                                     |  */
                0x00,                /*  8: R#6Fh | CKVS[7:0]                                                     |  */
                0x00,                /*  9: R#70h | REVSV | REVSVV|  "0"  |  "0"  | STVEV[9:8]   | STVSV[9:8]     |  */
                0x00,                /* 10: R#71h | STVEV[7:0]                                                    |  */
                0x00,                /* 11: R#72h | STVSV[7:0]                                                    |  */
                0x00,                /* 12: R#73h | REVSVH|  "0"  | STVEH[10:8]           | STVSH[10:8]           |  */
                0x00,                /* 13: R#74h | STVEH[7:0]                                                    |  */
                0x00,                /* 14: R#75h | STVSH[7:0]                                                    |  */
                0x00,                /* 15: R#76h | REVOE | REVOEV|  "0"  |  "0"  | OEEV[9:8]     | OESV[9:8]     |  */
                0x00,                /* 16: R#77h | OEEV[7:0]                                                     |  */
                0x00,                /* 17: R#78h | OESV[7:0]                                                     |  */
                0x00,                /* 18: R#79h | REVOEH|  "0"  | OEEH[10:8]            | OESH[10:8]            |  */
                0x00,                /* 19: R#7Ah | OEEH[7:0]                                                     |  */
                0x00,                /* 20: R#7Bh | OESH[7:0]                                                     |  */
                0x00,                /* 21: R#7Ch | POLEN |  "0"  | POLM[2:0]             | POLP[10:8]            |  */
                0x00,                /* 22: R#7Dh | POLP[7:0]                                                     |  */
#endif /* _LCD_HSD043I9W1_        */
/* ----------------------------- E O F ----------------------------------------*/
ID:1 發表于 2020-6-22 15:41 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
