查看: 3250|回復: 2
STM32無法循環點亮,求個大神幫幫忙
#include "stm32f10x.h"
uint16_t temp,i;
void Delay(unsigned int count)
        unsigned int i;
        for(;count!=0;count--)
                i=5000;
                while(i--);
void main(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
                if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==0)
                        Delay(500);
                                temp=0x0100;
                    for(i=0;i<8;i++)
                            GPIO_Write(GPIOB,~temp);
                             Delay(100);
                            temp=temp<<1;
                                        while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==1);
           }else if (GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==1){
                         temp=0x8000;
                         for(i=7;i>=0;i--)
                             Delay(100);
                            temp=temp>>1;
ID:277948 發表于 2020-6-21 18:19 | 只看該作者
我把程序改為 按鍵按下燈取反四次
#include "sys.h"
//#include "intrins.h"
#define LED1 PDout(2)        // PD2
uint16_t temp,i;
        unsigned int i;
                i=5000;
                while(i--);
int main(void)
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//注意GPIO_Mode_IPD不是GPIO_Mode_IPU
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
        GPIO_Init(GPIOD,&GPIO_InitStructure);
                                temp=0x0001;//注要放在循環前邊
        if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==1)     //沒按下按鍵為0 按下按鍵為1
                Delay(200);
                        for(i=0;i<8;i++)
//                                GPIO_Write(GPIOD,temp);
                                LED1=!LED1;
                                Delay(1000);
   }while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)==0); //按鍵釋放應該放在按鍵判斷之外
ID:355173 發表于 2020-6-22 14:47 | 只看該作者
是IPU(上拉輸入),而IPD是(下拉),很明顯PA0接了個電阻到VDD,而當有按鍵按下時,電路接通到地,所以PA0處讀到的電壓是0,當釋放時,與VDD想接,是高電平為1
