51單片機(jī)學(xué)習(xí)記錄,按時(shí)計(jì)數(shù)選取顯示
單片機(jī)源程序如下:
- #include<reg52.h>
- #include<string.h>
- #define uchar unsigned char
- sbit RS=P1^0;
- sbit RW=P1^1;
- sbit E=P1^2;
- unsigned int num,units=0,tens=0,hundreds=0;
- uchar row1[]={"Welcome to China"};
- uchar row2[]={"0123456789"};
- void delay(uchar ms)
- uchar k;
- while(ms--)
- for(k=0;k<123;k++);
- void command(uchar com)
- RS=0;
- RW=0;
- E=1;
- P0=com;
- E=0;
- delay(1);
- void WriteData(uchar dat)
- RS=1;
- RW=0;
- E=1;
- P0=dat;
- E=0;
- delay(1);
- void init()
- command(0x38);
- command(0x0c);
- command(0x06);
- command(0x01);
- void display()
- if(units==10)units=0,tens++;
- if(tens==10)tens=0,hundreds++;
- if(hundreds==10)hundreds=0;
- command(0x80);
- for(num=0;num<16;num++)
- WriteData(row1[num]),delay(5);
- command(0x80+0x40);
- WriteData(row2[hundreds]);
- command(0x80+0x40+0x01);
- WriteData(row2[tens]);
- command(0x80+0x40+0x02);
- WriteData(row2[units]);
- units++;
- delay(10);
- void main()
- init();
- while(1)
- display();
復(fù)制代碼 |
exp41.zip
2020-6-21 00:30 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
75.24 KB, 下載次數(shù): 4, 下載積分: 黑幣 -5
keil和proteus8.9
