以單片機為核心,設計一個8位競賽搶答器
2020-6-19 16:32 上傳
- #include<reg51.h>
- sbit DIN=P3^0; //與max7219接口定義
- sbit LOAD=P3^1;
- sbit CLK=P3^2;
- sbit key0=P1^0; //8路搶答器按鍵
- sbit key1=P1^1;
- sbit key2=P1^2;
- sbit key3=P1^3;
- sbit key4=P1^4;
- sbit key5=P1^5;
- sbit key6=P1^6;
- sbit key7=P1^7;
- sbit key_clear=P2^0; //主持人時間設置、清除
- sbit begin=P2^1; //主持人開始按鍵
- sbit sounder=P3^7; //蜂鳴器
- unsigned char second=30; //秒表計數值
- unsigned char counter=0; //counter每100,minite加1
- unsigned char people=0; //搶答結果
- unsigned char
- num_add[]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08};
- //max7219讀寫地址、內容
- unsigned char num_dat[]={0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89};
- unsigned char keyscan() //鍵盤掃描函數
- unsigned char keyvalue,temp;
- keyvalue=0;
- P1=0xff;
- temp=P1;
- if(~(P1&temp))
- switch(temp)
- case 0xfe:
- keyvalue=1;
- break;
- case 0xfd:
- keyvalue=2;
- break;
- case 0xfb:
- keyvalue=3;
- break;
- case 0xf7:
- keyvalue=4;
- break;
- case 0xef:
- keyvalue=5;
- break;
- case 0xdf:
- keyvalue=6;
- break;
- case 0xbf:
- keyvalue=7;
- break;
- case 0x7f:
- keyvalue=8;
- break;
- default:
- keyvalue=0;
- break;
- return keyvalue;
- void max7219_send(unsigned char add,unsigned char dat)
- // 函數功能:向max7219寫命令
- unsigned char ADS,i,j;
- LOAD=0;
- i=0;
- while(i<16)
- if(i<8)
- ADS=add;
- else
- ADS=dat;
- for(j=8;j>=1;j--)
- DIN=ADS&0x80;
- ADS=ADS<<1;
- CLK=1;
- CLK=0;
- i=i+8;
- LOAD=1;
- void max7219_init() //函數功能:max7219初始化
- max7219_send(0x0c,0x01);
- max7219_send(0x0b,0x07);
- max7219_send(0x0a,0xf5);
- max7219_send(0x09,0xff);
- void time_display(unsigned char x) //函數功能:時間顯示
- unsigned char i,j;
- i=x/10;
- j=x%10;
- max7219_send(num_add[1],num_dat[j]);
- max7219_send(num_add[0],num_dat[i]);
- void scare_display(unsigned char x) //函數功能:搶答結果顯示
- i=x/10;
- j=x%10;
- max7219_send(num_add[3],num_dat[j]);
- max7219_send(num_add[2],num_dat[i]);
- void holderscan() //函數功能:搶答時間設置,0-60s
- time_display(second);
- scare_display(people);
- if(~key_clear) //如果有鍵按下,改變搶答時間
- while(~key_clear);
- if(people) //如果搶答結果沒有清空,搶答器重置
- second=30;
- people=0;
- if(second<60)
- second++;
- else
- second=0;
- void timer_init() //定時器T0初始化
- EA=1;
- ET0=1;
- TMOD=0x01;
- TH0=0xd8; //裝入定時器定時常數,設定10ms中斷一次
- TL0=0xef;
- void main()
- while(1)
- do
- holderscan();
- }while(begin); //開始前進行設置,若未按下開始鍵
- while(~begin); //防抖
- max7219_init(); //芯片初始化
- timer_init(); //中斷初始化
- TR0=1; //開始中斷
- do
- people=keyscan();
- }while((!people)&&(second)); //運行直到搶答結束或時間結束
- TR0=0;
- void timer0() interrupt 1 //定時器T0中斷函數
- if(counter<100)
- counter++;
- if(counter==50)
- sounder=0;
- else
- sounder=1;
- counter=0;
- second=second-1;
- TH0=0xd8; //重新裝載
- TL0=0xef;
- TR0=1;
2020-6-19 16:34 上傳
2020-6-19 16:37 上傳
右側顯示不正常 求大神幫忙修改一下程序啊:
11-5-8位搶答器.rar
(104.57 KB, 下載次數: 9)
2020-6-19 13:25 上傳
下載積分: 黑幣 -5
