//把全局變量uchar num改為局部變量就行了
#include"reg52.h"
sbit s2=P3^4;
sbit s3=P3^5;
uchar code table[]={0xfe,0xfd,0xfb,0xf7,
0xef,0xdf,0xbf,0x7f};
void delayms(uint);
if(s2==0)
delayms(5);
if(s2==0)
{ uchar num=0;
while(s3)
P1=table[num];
delayms(500);
num++;
if(num==8)
num=0;
if(s3==0)
delayms(5);
if(s3==0)
{ uchar num=8;
while(s2)
P1=table[num-1];
delayms(500);
num--;
if(num==0)
num=8;
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
