查看: 3467|回復: 1
51單片機+8279 3*8鍵盤輸入程序 數碼管向前滾動輸入0~f Proteus仿真
3*8 鍵盤輸入  led數碼管向前滾動輸入 0~f   C51 單片機 protues仿真+代碼
壓縮包里有 protues仿真工程 和keil 代碼
  1. #include<reg51.h>
  2. #include<absacc.h>
  3. #define COM8279 XBYTE[0x7fff]           //這個是命令口。是CS
  4. #define DAT8279 XBYTE[0x7eff]           //這個是數據口。是A0
  5. #define uchar unsigned char
  6. uchar code   table[]={0x3F,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00,0x40};//0-F,-
  7. uchar idata keybuffer[6]={16,16,16,16,16,16};                          //   臨時放需要顯示的數字的地方
  8. sbit clflag=ACC^7;
  9. uchar key;
  10. uchar Keyflag;
  11. uchar run_once=1;
  12. uchar flag_display;
  13. uchar p;
  14. void delay(uchar x)                       //延時子程序
  15. {
  16.    uchar i;
  17.    for(i=0;i<x;i++);
  18.
  19. }
  20. void Display()                                  //顯示函數
  21. {
  22.
  23.     uchar i;
  24.         COM8279=0X90;
  25.         for(i=0;i<6;i++)
  26.   {
  27.         COM8279=i+0x80;
  28.         DAT8279=table[keybuffer[i]];
  29.         delay(10);
  30.          }
  31. }
  32. void Disp(d)        //顯示函數,
  33.     {
  34.         COM8279=0X90;
  35.         COM8279=0x80;
  36.         DAT8279=table[d];
  37.         delay(10);
  38.          }
  39.
  40. void Key_0(void) interrupt 0 using 1          //鍵盤按鍵使用外部中斷0
  41. {
  42.    uchar ch;
  43.    COM8279=0x40;
  44.    ch=DAT8279;
  45.    ch&=0x3f;
  46.    key=ch;
  47.
  48.           flag_display=1;
  49.
  50.
  51.
  52.
  53.     if(key==0)
  54.     {
  55.         if(run_once==1)
  56.         {
  57.            run_once=0;
  58.         return;
  59.         }
  60.
  61.     }
  62.      if(key!=0x00&&key!=0x01&&key!=0x02&&key!=0x03&&key!=0x04&&key!=0x05&&key!=0x06&&key!=0x07&&key!=0x08
  63.         &&key!=0x09&&key!=0x0a&&key!=0x0b&&key!=0x0c&&key!=0x0d&&key!=0x0e&&key!=0x0f)
  64.     {
  65.
  66.             key=17;
  67.     }
  68.
  69.
  70.
  71.
  72.    if(p>6)
  73.    {
  74.       p = 0;
  75.
  76.    }
  77.      keybuffer[5]=keybuffer[4];
  78.      keybuffer[4]=keybuffer[3];
  79.      keybuffer[3]=keybuffer[2];
  80.      keybuffer[2]=keybuffer[1];
  81.      keybuffer[1]= keybuffer[0];
  82.      keybuffer[0]=key;
  83.     Keyflag=1;
  84.         p++;
  85.
  86.
  87.
  88. }
  89. void KeyTest(uchar keyh)                    //鍵盤按鍵處理及通道選擇程序
  90. {
  91.
  92.     if(key!=0x00&&key!=0x01&&key!=0x02&&key!=0x03&&key!=0x04&&key!=0x05&&key!=0x06&&key!=0x07&&key!=0x08
  93.         &&key!=0x09&&key!=0x0a&&key!=0x0b&&key!=0x0c&&key!=0x0d&&key!=0x0e&&key!=0x0f)
  94.     {
  95.
  96.     Disp(0x10);
  97.     }
  98.
  99.
  100.
  101.    switch (keyh)
  102.      {
  103.       case 0x00:{//按鍵0
  104.          Disp(key);
  105.          break;}
  106.       case 0x01:{//按鍵1
  107.           Disp(key);
  108.                  break;}
  109.       case 0x02:{//按鍵2
  110.         Disp(key);
  111.          break;}
  112.       case 0x03:{//按鍵3
  113.             Disp(key);
  114.          break;}
  115.       case 0x04:{//按鍵4
  116.             Disp(key);
  117.          break;}
  118.       case 0x05:{//按鍵5
  119.             Disp(key);
  120.          break;}
  121.       case 0x06:{//按鍵6
  122.                Disp(key);
  123.          break;}
  124.       case 0x07:{//按鍵7
  125.         Disp(key);
  126.            break;}
  127.       case 0x08:{//按鍵0
  128.             Disp(key);
  129.          break;}
  130.       case 0x09:{//按鍵1
  131.               Disp(key);
  132.                  break;}
  133.           case 0x0a:{//按鍵5
  134.              Disp(key);
  135.          break;}
  136.       case 0x0b:{//按鍵6
  137.              Disp(key);
  138.          break;}
  139.       case 0x0c:{//按鍵7
  140.              Disp(key);
  141.       case 0x0d:{//按鍵0
  142.              Disp(key);
  143.          break;}
  144.       case 0x0e:{//按鍵1
  145.              Disp(key);
  146.                  break;}
  147.
  148.          case 0x0f:{//按鍵1
  149.                  Disp(key);
  150.                  break;}
  151.
  152.          default:
  153.       break; }
  154.          }
  155. }
  156. void main(void)
  157. ……………………
  158. …………限于本文篇幅 余下代碼請從51黑下載附件…………
多鍵值輸入顯示.zip (147.26 KB, 下載次數: 57)
ID:988777 發表于 2021-12-14 15:55 | 只看該作者
麻煩問一下這個void KeyTest(uchar keyh) 函數在哪里調用了,我根本沒有看到
