查看: 1890|回復: 3
這是基于AT89c52單片機控制的病房呼叫系統(tǒng)設計的程序,仿真時LED顯示亂碼,為什么?
ID:779600 發(fā)表于 2020-6-15 09:55 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
ORG 0000H
      LJMP MAIN
          ORG 0003H
          LJMP INTR_0
          ORG 0030H
MAIN: SETB EA
      SETB EX0
          SETB IT0
MAIN1:CLR P3.7
      MOV 30H,#0FFH
          LCALL DISP
DP1:  LCALL KEY
      LCALL DISP
          LJMP DP1
KEY:
      LCALL KS
          JNZ K1
          LCALL DELAY2
          RET
K1:   LCALL DELAY2
      JNZ K2
          LJMP  KEY
K2:   MOV R2,#0FEH
      MOV P1,#0FFH
          MOV R4,#00H
K3:   MOV P2,R2
LOOP0: JB P1.0,LOOP1
      MOV A,#00H
          LJMP LOOPK
LOOP1:JB P1.1,LOOP2
      MOV A,#08H
          LJMP LOOPK
LOOP2:JB P1.2,LOOP3
      MOV A,#10H
          LJMP LOOPK
LOOP3: JB P1.3,LOOP4
          MOV A,#18H
          LJMP LOOPK
LOOP4:JB P1.4,LOOP5
      MOV A,#20H
          LJMP LOOPK
LOOP5: JB P1.5,LOOP6
      MOV A,#28H
          LJMP LOOPK
LOOP6: JB P1.6,LOOP7
      MOV A,#30H
          LJMP LOOPK
LOOP7: JB P1.7,NEXT
      MOV A,#38H
LOOPK:ADD A,R4
      PUSH ACC
K4:   LCALL KS
      JNZ K4
          POP ACC
          MOV 30H,A
          SETB P3.7
          LCALL DELAY3
          CLR P3.7
          RET
NEXT: INC R4
      MOV A,R2
          JNB ACC.7,RET0
          RL A
          MOV R2,A
          LJMP K3
KS:   MOV P2,#0FFH
      MOV P1,#00H
          MOV A,P2
          XRL A,#0FFH
          RET0:RET
DELAY2:MOV R5,#08H
D7:   MOV R6,#0FAH
D8:   DJNZ R6,D8
      DJNZ R5,D7
          RET
DISP:
      LCALL HBCD
PLAY: CLR P3.0
      MOV DPTR,#DSEG1
          MOV A,31H
          MOVC A,@A+DPTR
          MOV P0,A
          LCALL DL1
          SETB P3.0
          CLR P3.1
          MOV DPTR,#DSEG1
          MOV A,32H
          MOVC A,@A+DPTR
          MOV P0,A
          LCALL DL1
          SETB P3.1
          RET
DL1:  MOV R7,#05H
DL:   MOV R6,#0FFH
DL6:  DJNZ R6,$
      DJNZ R7,DL
          RET
DSEG1:DB 3FH,06H,5BH,4FH,66H
      DB 6DH,7DH,07H,7FH,6FH
HBCD:
      MOV A,30H
          INC A
          MOV B,#100
   DIV AB
   MOV R5,A
   MOV A,#10
   XCH A,B
   DIV AB
       MOV 31H,A
           MOV 32H,B
        RET
INTR_0:MOV 30H,#0FFH
       CLR P3.7
           RETI
DELAY3:
DDL1: MOV 41H,#220
DDL2: MOV 42H,#250
DDL3:
      DJNZ 42H,DDL3
          LCALL DISP
          DJNZ 41H,DDL2
          RET
          END
仿真電路圖
仿真電路圖
ID:96682 發(fā)表于 2020-6-16 01:19 來自觸屏版 | 只看該作者
此帖僅作者可見
ID:277948 發(fā)表于 2020-6-16 14:07 | 只看該作者
此帖僅作者可見
ID:123289 發(fā)表于 2020-6-16 15:59 | 只看該作者
此帖僅作者可見
