查看: 1430|回復(fù): 0
基于單片機(jī)的8路舵機(jī)機(jī)控制
ID:401793 發(fā)表于 2020-6-15 08:38 | 顯示全部樓層 |閱讀模式
#include "led.h"
#include "delay.h"
#include "sys.h"
#include "key.h"
#include "usart.h"
#include "exti.h"
#include "wdg.h"
#include "timer.h"
#include "pwm.h"
int main(void)
        u16 pwm_value=225;
        int dir=1;
        SystemInit();
        delay_init(72);             //Ñóê±3õê¼»ˉ
        NVIC_Configuration();
//        uart_init(9600);
//        LED_Init();
//         delay_us(500);
//        KEY_Init();          //°′¼ü3õê¼»ˉ
        TIM1_Init(1999,719);         //PWMÆμÂê=72000/9000/150=50hz
        TIM2_Init(9000,160);         //PWMÆμÂê=72000/9000/150=50hz
        TIM3_Init(9000,160);         //PWMÆμÂê=72000/9000/150=50hz
        TIM4_Init(9000,160);         //PWMÆμÂê=72000/9000/150=50hz
//        LED_Init();
                 delay_us(1000);
                pwm_value = pwm_value + dir;
                if(pwm_value > 1125)
                dir = -1;
                if(pwm_value < 225)
                dir = 1;
                TIM_SetCompare1(TIM2,pwm_value);
                TIM_SetCompare2(TIM2,pwm_value);
                TIM_SetCompare3(TIM2,pwm_value);
                TIM_SetCompare4(TIM2,pwm_value);
                TIM_SetCompare1(TIM3,pwm_value);
                TIM_SetCompare2(TIM3,pwm_value);
                TIM_SetCompare3(TIM3,pwm_value);
                TIM_SetCompare4(TIM3,pwm_value);
                TIM_SetCompare1(TIM4,pwm_value);
                TIM_SetCompare2(TIM4,pwm_value);
                TIM_SetCompare3(TIM4,pwm_value);
                TIM_SetCompare4(TIM4,pwm_value);
                TIM_SetCompare1(TIM1,pwm_value);
                TIM_SetCompare2(TIM1,pwm_value);
                TIM_SetCompare3(TIM1,pwm_value);
                TIM_SetCompare4(TIM1,pwm_value);
