查看: 3757|回復: 11
單片機可調電子時鐘想加一個蜂鳴器 求方法
ID:770620 發表于 2020-6-14 12:05 | 顯示全部樓層 |閱讀模式
上面是加了蜂鳴器的電路圖
實驗的要求是:
目前前三點已經可以通過下面的編程達到要求,第四點,我在電路圖上加了蜂鳴器,但是不會寫程序,急!!!!!!
編程:#include <reg51.h>
sbit set=P1^0;
sbit save=P1^5;
sbit rselect=P1^1;
sbit lselect=P1^2;
sbit add=P1^3;
sbit reduce=P1^4;
uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar disp_buf[6];
uchar disp_bit=0;
uint hour,min,sec;
uint select_num=0;
uint hour_adj,min_adj,sec_adj;
uchar count;
uchar key_num=0;
void key_scan()
if(!set)
  hour_adj=hour;
  min_adj=min;
  sec_adj=sec;
  key_num++;
while(!set);
if(key_num%2==1)
  if(rselect==0)
   select_num++;
   if(select_num==4)
   select_num=1;
  while(!rselect);
  if(lselect==0)
   select_num--;
   if(select_num<=0)
   select_num=3;
  while(!lselect);
if(!add&&(key_num%2))
  switch(select_num)
   case 1 :
    hour_adj++;
    if(hour_adj==24)
    hour_adj=0;
    break;
   case 2 :
    min_adj++;
    if(min_adj==60)
    min_adj=0;
    break;
   case 3 :
    sec_adj++;
    if(sec_adj==60)
    sec_adj=0;
    break;
   default:break;
  while(!add);
if(!reduce&&(key_num%2))
  switch(select_num)
   case 1 :
    hour_adj--;
    if(hour_adj<=0)
    hour_adj=23;
    break;
   case 2 :
    min_adj--;
    if(min_adj<=0)
    min_adj=59;
    break;
   case 3 :
    sec_adj--;
    if(sec_adj<=0)
    sec_adj=59;
    break;
   default:break;
  while(!reduce);
if(!save&&(key_num%2))
  select_num=0;
  hour=hour_adj;
  min=min_adj;
  sec=sec_adj;
  while(!save);
/*Ö÷º¯Êý*/
TMOD=0x11;
TH0=0xf7;
TL0=0x00;
TH1=0x4c;
TH0=0x00;
ET0=1;
ET1=1;
EA=1;
TR0=1;
TR1=1;
PT1=1;
hour=20;
min=02;
sec=07;
count=0;
  key_scan();
  if(key_num%2)
  switch(select_num)
   case 1 :
     if(count<=10)
     disp_buf[0]=hour_adj/10;
     disp_buf[1]=hour_adj%10;
     disp_buf[0]=0x40;
     disp_buf[1]=0x40;
    disp_buf[2]=min_adj/10;
    disp_buf[3]=min_adj%10;
    disp_buf[4]=sec_adj/10;
    disp_buf[5]=sec_adj%10;
    break;
   case 2 :
     if(count<=10)
     disp_buf[2]=0x40;
     disp_buf[3]=0x40;
    break;
   case 3 :
     if(count<=10)
     disp_buf[4]=0x40;
     disp_buf[5]=0x40;
    break;
   default :  break;
  if(key_num%2==0)
   disp_buf[0]=hour/10;
   disp_buf[1]=hour%10;
   disp_buf[2]=min/10;
   disp_buf[3]=min%10;
   disp_buf[4]=sec/10;
   disp_buf[5]=sec%10;
void timer0() interrupt 1
TH0=0xf7;
TL0=0x00;
P2=~(0x01<<disp_bit);
P0=tab[disp_buf[disp_bit]];
disp_bit++;
if(disp_bit==6) disp_bit=0;
void timer1() interrupt 3
TH1=0x4c;
TL1=0x00;
if(++count==20)
  count=0;
  if(++sec==60)
   sec=0;
   if(++min==60)
    min=0;
    if(++hour==24)
     hour=0;
ID:332444 發表于 2020-6-14 12:44 | 顯示全部樓層
判斷分鐘值為零則輸出頻率驅動蜂鳴器即可。
ID:332444 發表于 2020-6-14 12:47 | 顯示全部樓層
ID:610681 發表于 2020-6-14 13:06 | 顯示全部樓層
復雜的都寫出來了,蜂鳴器程序加不上?!?!
ID:635913 發表于 2020-6-14 17:03 | 顯示全部樓層
先定義sbit speak=P1^5;
然后給speak給值,給1響0不想即可。
或者你參考一下http://m.raoushi.com/bbs/dpj-189899-1.html
ID:770620 發表于 2020-6-14 23:14 來自觸屏版 | 顯示全部樓層
來51學習的 發表于 2020-6-14 13:06
這個是書上的,不是我自己寫的,嗚嗚嗚我要是能寫出來,蜂鳴器也肯定也會加的
ID:770620 發表于 2020-6-14 23:22 來自觸屏版 | 顯示全部樓層
未來可期鴨 發表于 2020-6-14 17:03
先定義sbit speak=P1^5;
或者你參考一下http://m.raoushi.com/bbs/dp ...
謝謝謝謝謝謝謝
ID:1032257 發表于 2022-6-5 10:54 來自觸屏版 | 顯示全部樓層
匯編語言澤呢么實現啊大佬們
ID:855733 發表于 2022-6-6 15:26 | 顯示全部樓層
在分鐘復位的下面加一條P1.6=1應該就可以了 if(++min==60)
    min=0;
P1^6=1;
ID:855733 發表于 2022-6-6 15:32 | 顯示全部樓層
你的蜂鳴器電路圖三極管是不是用錯了呀?
ID:1032822 發表于 2022-6-7 10:10 | 顯示全部樓層
你用一個引腳做輸出到蜂鳴器,再加一小段代碼(比如除盡時或輸出0時響起來就行了)
ID:1032872 發表于 2022-6-7 13:00 | 顯示全部樓層
加個引腳引到蜂鳴器上
