查看: 4268|回復(fù): 2
error C141: syntax error near 'sbit'怎么修改啊
ID:777780 發(fā)表于 2020-6-13 00:19 | 顯示全部樓層 |閱讀模式
1黑幣
uchar i;
while(ms--)
for(i=0;i<123;i++);
void Timer0() interrupt 1
TH0= (65535-50000)/256;
TL0=(65535-50000)%256;
if(fIR==0)
if(++times==SetTime)
times = 0;
TR0=0;
LAMP=1;
void main(void)
P2=0xff;P3=0xff;P1=0xff;
SetTime=SetSecond*20;
TMOD = 0x01;
TH0=(65535-50000)/256;
EA=1;
ET0=1;
TR0=0;
if(IR==0)
delayms(20);
if(IR==0)
fIR=1;TR0=1;
LAMP=0;
else fIR=0;
Build target 'Target 1'
compiling hhh.c...
HHH.C(12): error C141: syntax error near 'sbit'
HHH.C(12): error C202: 'IR': undefined identifier
HHH.C(12): error C202: 'i': undefined identifier
HHH.C(15): error C202: 'i': undefined identifier
HHH.C(44): error C202: 'IR': undefined identifier
HHH.C(47): error C202: 'IR': undefined identifier
Target not created
ID:155507 發(fā)表于 2020-6-15 10:03 | 顯示全部樓層
需要加入頭文件
#include <reg52.h>
ID:780424 發(fā)表于 2020-6-15 23:07 | 顯示全部樓層
#include <reg51.h>
