查看: 2565|回復(fù): 2
51單片機(jī)基礎(chǔ)紅外循跡避障求助帖,避障有一步卡住了!
ID:773142 發(fā)表于 2020-6-12 22:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
5黑幣
以下我的程序,我的問題是 當(dāng)我的小車避障模塊感應(yīng)到了障礙物,他也不執(zhí)行我的命令 繼續(xù)行駛
#include"reg52.h"
#include"intrins.h"
sbit IN1=P1^1;         //引腳定義
sbit IN2=P1^2;
sbit ENA=P2^6;
sbit IN3=P1^3;
sbit IN4=P1^4;
sbit ENB=P2^1;
sbit red_right=P0^3;
sbit red_left=P0^2;
sbit red_forehead=P0^1;
#define leftmoto_go IN1=1;IN2=0;
#define rightmoto_go IN3=1;IN4=0;
#define leftmoto_back IN1=0;IN2=1;
#define rightmoto_back IN3=0;IN4=1;
#define letfmoto_stop IN1=0,IN2=0;
#define rightmoto_stop IN3=0,IN4=0;
typedef unsigned int u16;
typedef unsigned char u8;
u8 pwm_left_val=230;
u8 pwm_right_val=230;
u8 pwm_t;
void delay(u16 a)
  while(a--);
void forward()          //前進(jìn)
leftmoto_go;rightmoto_go;
void stop()                  //停止
  letfmoto_stop;rightmoto_stop;
void backward()          //后退
  leftmoto_back;rightmoto_back;
void right_turn()  //右轉(zhuǎn)
leftmoto_go;rightmoto_back;
}void left_turn()         //左轉(zhuǎn)
rightmoto_go;leftmoto_back;
void Timer0() interrupt 1         //PWM調(diào)速
pwm_t++;
if(pwm_t==255)
  pwm_t=ENA=ENB=0;
if(pwm_left_val==pwm_t)
  ENA=1;
  if(pwm_right_val==pwm_t)
  ENB=1;
  TMOD|=0x02;
  TH0=250;
  TL0=250;
  TR0=1;
  ET0=1;
  EA=1;
   if(red_right==0&&red_left==0&&red_forehead==1)         //沒有檢測到黑線,直行
                      forward();
   else if(red_right==1&&red_left==0&&red_forehead==1)   //右邊檢測到黑線,右轉(zhuǎn)
            right_turn();
   else if(red_right==0&&red_left==1&&red_forehead==1)   //左邊檢測到黑線,左轉(zhuǎn)
             left_turn();
   if(red_forehead==0)         //車頭檢測到障礙物,避障
             stop();
          delay(5000);
          left_turn();
          delay(5000);
          forward();
          delay(10000);
          right_turn();
          delay(5000);
          forward();
          delay(10000);
          right_turn();
          delay(5000);
          if(red_right==0&&red_left==0)
                      forward();
   if(red_right==1&&red_left==0)
            right_turn();
   if(red_right==0&&red_left==1)
             left_turn();
ID:332444 發(fā)表于 2020-6-13 05:52 | 只看該作者
未見測距代碼,如何避障執(zhí)行命令?
ID:764088 發(fā)表于 2020-6-16 10:29 | 只看該作者
采用debug 模式,看碰到故障物時,1)是否 程序進(jìn)入 滿足您的相應(yīng)條件中
2)如已滿足,看執(zhí)行命令函數(shù)是否實施; 根據(jù)上述來改吧
