查看: 2660|回復: 1
AutoChips 7801的BMP085氣溫氣壓測量
BMP085是一款基于I2C接口的數字式氣溫、氣壓傳感器,具有體積少易于使用的特點。
BMP085MCU的連接關系為:
SCLK——PB7
SDIN——PB8
其余的兩個引腳則接3.3V工作電源
BMP085與開發板連接圖
定義GPIO輸入及輸出高低電平的語句為:
#define SCL_Set()        GPIO_SetPinLevel(GPIOB, GPIO_PIN7, GPIO_LEVEL_HIGH);  // PB7
#define SCL_Clr()        GPIO_SetPinLevel(GPIOB, GPIO_PIN7, GPIO_LEVEL_LOW);
#define SDA_Set()        GPIO_SetPinLevel(GPIOB, GPIO_PIN8, GPIO_LEVEL_HIGH);  // PB8
#define SDA_Clr()        GPIO_SetPinLevel(GPIOB, GPIO_PIN8, GPIO_LEVEL_LOW);
#define IIC_SDA_IN    GPIO_GetPinLevel(GPIOB, GPIO_PIN8)
#define IIC_INPUT_MODE_SET()   GPIO_SetDir(GPIOB, GPIO_PIN8, GPIO_IN);
#define IIC_OUTPUT_MODE_SET()  GPIO_SetDir(GPIOB, GPIO_PIN8, GPIO_OUT);
配置相關引腳為輸出功能的函數為:
  1. void IIC_Init(void)
  2. {
  3. GPIO_SetDir(GPIOB, GPIO_PIN7, GPIO_OUT);
  4. GPIO_SetDir(GPIOB, GPIO_PIN8, GPIO_OUT);
  5. }
輔助BMP085讀寫的基本函數有:
  1. void IIC_Start(void)
  2. {
  3. IIC_OUTPUT_MODE_SET();
  4. SDA_Set();
  5. SCL_Set();
  6. udelay(5);
  7. SDA_Clr();
  8. udelay(5);
  9. SCL_Clr();
  10. }
  11. void IIC_Stop(void)
  12. {
  13. IIC_OUTPUT_MODE_SET();
  14. SDA_Clr();
  15. SCL_Clr();
  16. udelay(5);
  17. SCL_Set();
  18. udelay(5);
  19. SDA_Set();
  20. udelay(5);
  21. }
  22. void IIC_Ack(void)
  23. {
  24. SCL_Clr();
  25. IIC_OUTPUT_MODE_SET();
  26. SDA_Clr();
  27. udelay(2);
  28. SCL_Set();
  29. udelay(2);
  30. SCL_Clr();
  31. }
  32. void IIC_NAck(void)
  33. {
  34. SCL_Clr();
  35. IIC_OUTPUT_MODE_SET();
  36. SDA_Set();
  37. udelay(2);
  38. SCL_Set();
  39. udelay(2);
  40. SCL_Clr();
  41. }
BMP085的初始化函數為:
  1. void Init_BMP085()
  2. {
  3. ac1 = Multiple_read(0xAA);
  4. ac2 = Multiple_read(0xAC);
  5. ac3 = Multiple_read(0xAE);
  6. ac4 = Multiple_read(0xB0);
  7. ac5 = Multiple_read(0xB2);
  8. ac6 = Multiple_read(0xB4);
  9. b1 =  Multiple_read(0xB6);
  10. b2 =  Multiple_read(0xB8);
  11. mb =  Multiple_read(0xBA);
  12. mc =  Multiple_read(0xBC);
  13. md =  Multiple_read(0xBE);
  14. }
氣溫的讀取函數為:
  1. long bmp085ReadTemp(void)
  2. {
  3. IIC_Start();
  4. IIC_Send_Byte(BMP085_SlaveAddress);
  5. while(IIC_Wait_Ack()){}
  6. IIC_Send_Byte(0xF4);
  7. while(IIC_Wait_Ack()){}
  8. IIC_Send_Byte(0x2E);
  9. while(IIC_Wait_Ack()){}
  10. IIC_Stop();
  11. mdelay(10);
  12. return (long) Multiple_read(0xF6);
  13. }
氣壓的讀取函數為:
  1. long bmp085ReadPressure(void)
  2. {
  3. long pressure = 0;
  4. IIC_Start();
  5. IIC_Send_Byte(BMP085_SlaveAddress);
  6. while(IIC_Wait_Ack()){}
  7. IIC_Send_Byte(0xF4);
  8. while(IIC_Wait_Ack()){}
  9. IIC_Send_Byte(0x34);
  10. while(IIC_Wait_Ack()){}
  11. IIC_Stop();
  12. mdelay(10);
  13. pressure = Multiple_read(0xF6);
  14. pressure &= 0x0000FFFF;
  15. return pressure;
  16. }
實現圖示輸出效果的主程序為:
  1. int main(void)
  2. {
  3. InitDelay();
  4. InitDebug();
  5. OLED_Init();
  6. OLED_Clear();
  7. OLED_ShowString(0,0,"AC8710 TEST",16);
  8. OLED_ShowString(0,2,"OLED Display",16);
  9. OLED_ShowString(0,4,"jinglixixi",16);
  10. OLED_ShowString(0,6,"2020.6.6",16);
  11. IIC_Init(); //BMP085
  12. Init_BMP085();
  13. while(1)
  14. {
  15. bmp085Convert();
  16. printf("temperature: %d C\r\n", temperature/10);
  17. printf("pressure: %d KPa\r\n", pressure/100);
  18. ConvAltitude();
  19. mdelay(1000);
  20. }
  21. }
測量效果圖
ID:776997 發表于 2020-6-17 22:36 | 只看該作者
感謝鼓勵
