#include <REGX51.H>
uint PWM = 5; //最大20,pwm調速
uchar time = 0;
uint Shi_Jian;
uint a,b,c,FJL,LJL,RJL;
void Delay (uint t) //@11.0592MHz 100us
unsigned char i;
while (t)
i = 43;
while (--i);
t--;
void Timer_Init() //定時器 @11.0592MHZ 0.1ms
TMOD = 0x11;
TH0 = 0xFB;
TL0 = 0xAF;
TF0 = 0;
ET0 = 1; //允許中斷
EA = 1; //開啟總中斷
TR0 = 1; /開啟定時器
TF1 = 0;
TH1 = 0;
TL1 = 0;
void Timer0_Rountine() interrupt 1 //T0 中斷
time++;
TH0 = 0xFB;
TL0 = 0xAF;
if(time >= 20)
time = 0;
int Front_Ju_Li () //測前方距離
P2_0 = 1; //發送超聲波
Delay(1); //延時100us
P2_0 = 0; //關閉超聲波
while (!P2_1); //未接收到超聲波并等待
TR1 = 1; //開啟定時器
while (P2_1); //接收到超聲波并等待
TR1 = 0; //關閉定時器1
Shi_Jian = TH1*256 + TL1;
TH1 = 0;
TL1 = 0;
FJL = (Shi_Jian*1.7)/100; //單位 cm
return FJL;
int Zuo_Ju_Li () //測左邊距離
P2_2 = 1; //發送超聲波
Delay(1); //延時100us
P2_2 = 0; //關閉超聲波
while (!P2_3); //未接收到超聲波并等待
TR1 = 1; //開啟定時器
while (P2_3); //接收到超聲波并等待
TR1 = 0; //關閉定時器1
TH1 = 0;
TL1 = 0;
LJL = (Shi_Jian*1.7)/100; /單位 cm
return LJL;
int You_Ju_Li () //測右邊距離
P2_4 = 1; //發送超聲波
Delay(1); //延時100us
P2_4 = 0; //關閉超聲波
while (!P2_5); //未接收到超聲波并等待
TR1 = 1; //開啟定時器
while (P2_5); //接收到超聲波并等待
TR1 = 0; //關閉定時器1
TH1 = 0;
TL1 = 0;
RJL = (Shi_Jian*1.7)/100; //單位 cm
void Car_Stop () //停止
P1_0=0,P1_1=0,P1_2=0,P1_3=0,P1_4=0,P1_5=0,P1_6=0,P1_7=0;
void Car_Run () //前進
if (time <= PWM)
P1_0=1,P1_1=0,P1_2=0,P1_3=1,P1_4=0,P1_5=1,P1_6=0,P1_7=1;
Car_Stop ();
void Car_Zuozhuan () //左轉
if (time <= PWM)
P1_0=0,P1_1=1,P1_2=0,P1_3=1,P1_4=1,P1_5=0,P1_6=0,P1_7=1;
Car_Stop ();
void Car_Youzhuan () //右轉
if (time <= PWM)
P1_0=1,P1_1=0,P1_2=1,P1_3=0,P1_4=0,P1_5=1,P1_6=1,P1_7=0;
Car_Stop ();
void Car_Houtui () /后退
if (time <= PWM)
P1_0=0,P1_1=1,P1_2=1,P1_3=0,P1_4=1,P1_5=0,P1_6=1,P1_7=0;
Car_Stop ();
Timer_Init();
while (1)
do
Car_Run ();
a = Front_Ju_Li ();
}while(a >= 20);
Car_Stop ();
b = Zuo_Ju_Li ();
Delay(100);
c = You_Ju_Li ();
Delay(100);
if (b <= 15 && c <= 15) //進入狹小空間,后退
Car_Houtui ();
if (b <= c) //左邊距離小于右邊距離,右轉
Car_Youzhuan ();
if (c <= b) /右邊距離小于左邊距離,左轉
Car_Zuozhuan ();
Car_Stop ();
幫忙看一下程序有什么問題
