查看: 2425|回復: 0
51單片機流水燈Proteus仿真程序
ID:775021 發表于 2020-6-11 16:48 | 顯示全部樓層 |閱讀模式
仿真原理如下圖: E)R8PTO%}BRYSOAP7G6IPYP.png
通過中斷來控制流水燈的運作情況;代碼如下:
#include<reg51.h>
#include<intrins.h>
sbit ex        =P3^2;
unsigned char num=0;
unsigned char count=0;
unsigned char count1=0;
void init()
        TMOD=0X01;
    TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        ET0=1;
    IT0=1;
        IT1=1;
        TR0=1;
        EX0=1;
        EX1=1;
        EA=1;
        ex=1;
void display(){
        if(count1==6){
           count1=0;
void delay(unsigned int n)
                unsigned int i=0,j=0;
                for(i=0;i<n;i++)
                    for(j=0;j<120;j++);
void led()
    int i=0;
    for(i=0;i<8;i++)
           P1=(0x01<<i);
                delay(125);
void led1(){
            int i=0;
    for(i=0;i<8;i++)
           P1=(0x80>>i);
                delay(125);
{        init();
        display();
        if(num%2!=0){
            if(count1<3){
               led();
                 else {
                  led1();
        else{
          P1=0x00;
          P2=0x3f;
          count1=0;
void interrupt0() interrupt 0
    num++;
void Time_isr()interrupt 1
         count++;
         if(count==20){
           count1++;
           count=0;
全部資料51hei下載地址:
bw.zip (64.98 KB, 下載次數: 19)
