查看: 2156|回復(fù): 3
單片機(jī)萌新一只,想給這個這個電路加個報(bào)警電路,但自己打了一點(diǎn)發(fā)現(xiàn)行不通,求大....
本帖最后由 苯甲醇 于 2020-6-10 15:42 編輯
#include<reg51.h>
#include <intrins.h>
#define noACK 0    //繼續(xù)傳輸數(shù)據(jù),用于判斷是否結(jié)束通訊
#define ACK   1             //結(jié)束數(shù)據(jù)傳輸;
       //地址  命令  讀/寫
#define STATUS_REG_W 0x06   //000   0011    0
#define STATUS_REG_R 0x07   //000   0011    1
#define MEASURE_TEMP 0x03   //000   0001    1
#define MEASURE_HUMI 0x05   //000   0010    1
#define RESET        0x1e   //000   1111    0
enum {TEMP,HUMI};
sbit DATA = P2^5;
sbit SCK = P2^4;
sbit RS  = P2^0;
sbit RW  = P2^1;
sbit E  = P2^2;
sfr DBPort  = 0x80;     //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.數(shù)據(jù)端口
/********     DS1602函數(shù)聲明     ********/
void LCD_Initial();
void GotoXY(unsigned char x, unsigned char y);
void Print(unsigned char *str);
void LCD_Write(bit style, unsigned char input);
/********     SHT10函數(shù)聲明      ********/
void s_connectionreset(void);
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode);
void calc_sth10(float *p_humidity ,float *p_temperature);
//float calc_dewpoint(float h,float t);
//寫字節(jié)程序
char s_write_byte(unsigned char value)
unsigned char i,error=0;
for (i=0x80;i>0;i>>=1)             //高位為1,循環(huán)右移
  if (i&value) DATA=1;          //和要發(fā)送的數(shù)相與,結(jié)果為發(fā)送的位
     else DATA=0;
     SCK=1;
     _nop_();_nop_();_nop_();        //延時3us
     SCK=0;
DATA=1;                           //釋放數(shù)據(jù)線
SCK=1;
error=DATA;                       //檢查應(yīng)答信號,確認(rèn)通訊正常
SCK=0;
DATA=1;
return error;                     //error=1 通訊錯誤
//讀字節(jié)程序
char s_read_byte(unsigned char ack)
unsigned char i,val=0;
for(i=0x80;i>0;i>>=1)             //高位為1,循環(huán)右移
  SCK=1;
     if(DATA) val=(val|i);        //讀一位數(shù)據(jù)線的值
     SCK=0;
DATA=!ack;                        //如果是校驗(yàn),讀取完后結(jié)束通訊;
SCK=1;
SCK=0;
return val;
//啟動傳輸
void s_transstart(void)
// generates a transmission start
//       _____         ________
// DATA:      |_______|
//           ___     ___
// SCK : ___|   |___|   |______
    DATA=1; SCK=0;                   //準(zhǔn)備
    _nop_();
   SCK=1;
    _nop_();
    DATA=0;
    _nop_();
   SCK=0;
    SCK=1;
    _nop_();
   DATA=1;
   _nop_();
    SCK=0;
//連接復(fù)位
// communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
//       _____________________________________________________         ________
// DATA:                                                      |_______|
//          _    _    _    _    _    _    _    _    _        ___     ___
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______|   |___|   |______
unsigned char i;
for(i=0;i<9;i++)                  //DATA保持高,SCK時鐘觸發(fā)9次,發(fā)送啟動傳輸,通迅即復(fù)位
  SCK=1;
     SCK=0;
s_transstart();                   //啟動傳輸
//軟復(fù)位程序
char s_softreset(void)
// resets the sensor by a softreset
unsigned char error=0;
s_connectionreset();              //啟動連接復(fù)位
error+=s_write_byte(RESET);       //發(fā)送復(fù)位命令
/*讀狀態(tài)寄存器
char s_read_statusreg(unsigned char *p_value, unsigned char *p_checksum)
// reads the status register with checksum (8-bit)
s_transstart();                   //transmission start
error=s_write_byte(STATUS_REG_R); //send command to sensor
*p_value=s_read_byte(ACK);        //read status register (8-bit)
*p_checksum=s_read_byte(noACK);   //read checksum (8-bit)
return error;                     //error=1 in case of no response form the sensor
//寫狀態(tài)寄存器
char s_write_statusreg(unsigned char *p_value)
// writes the status register with checksum (8-bit)
error+=s_write_byte(STATUS_REG_W);//send command to sensor
error+=s_write_byte(*p_value);    //send value of status register
return error;                     //error>=1 in case of no response form the sensor
//溫濕度測量
// 進(jìn)行溫度或者濕度轉(zhuǎn)換,由參數(shù)mode決定轉(zhuǎn)換內(nèi)容;
// enum {TEMP,HUMI};   //已經(jīng)在頭文件中定義
unsigned error=0;
unsigned int i;
switch(mode)                     //選擇發(fā)送命令
  case TEMP : error+=s_write_byte(MEASURE_TEMP); break;     //測量溫度
     case HUMI : error+=s_write_byte(MEASURE_HUMI); break;     //測量濕度
     default     : break;
for (i=0;i<65535;i++) if(DATA==0) break; //等待測量結(jié)束
if(DATA) error+=1;                // 如果長時間數(shù)據(jù)線沒有拉低,說明測量錯誤
*(p_value) =s_read_byte(ACK);    //讀第一個字節(jié),高字節(jié) (MSB)
*(p_value+1)=s_read_byte(ACK);    //讀第二個字節(jié),低字節(jié) (LSB)
*p_checksum =s_read_byte(noACK); //read CRC校驗(yàn)碼
return error;      // error=1 通訊錯誤
//溫濕度值標(biāo)度變換及溫度補(bǔ)償
const float C1=-4.0;              // 12位濕度精度 修正公式
const float C2=+0.0405;           // 12位濕度精度 修正公式
const float C3=-0.0000028;        // 12位濕度精度 修正公式
const float T1=+0.01;             // 14位溫度精度 5V條件  修正公式
const float T2=+0.00008;          // 14位溫度精度 5V條件  修正公式
float rh=*p_humidity;             // rh:      12位 濕度
float t=*p_temperature;           // t:       14位 溫度
float rh_lin;                     // rh_lin: 濕度 linear值
float rh_true;                    // rh_true: 濕度 ture值
float t_C;                        // t_C   : 溫度 ℃
t_C=t*0.01 - 40;                  //補(bǔ)償溫度
rh_lin=C3*rh*rh + C2*rh + C1;     //相對濕度非線性補(bǔ)償
rh_true=(t_C-25)*(T1+T2*rh)+rh_lin;   //相對濕度對于溫度依賴性補(bǔ)償
if(rh_true>100)rh_true=100;       //濕度最大修正
if(rh_true<0.1)rh_true=0.1;       //濕度最小修正
*p_temperature=t_C;               //返回溫度結(jié)果
*p_humidity=rh_true;              //返回濕度結(jié)果
//從相對溫度和濕度計(jì)算露點(diǎn)
/*float calc_dewpoint(float h,float t)
float logEx,dew_point;
logEx=0.66077+7.5*t/(237.3+t)+(log10(h)-2);
dew_point = (logEx - 0.66077)*237.3/(0.66077+7.5-logEx);
return dew_point;
//DS1602程序(1602.c):
//#include<tou.h>
//內(nèi)部等待函數(shù)**************************************************************
unsigned char LCD_Wait(void)
    RS=0;
    RW=1;    _nop_();
    E=1;    _nop_();
    E=0;
    return DBPort;
//向LCD寫入命令或數(shù)據(jù)********************************************************
#define LCD_COMMAND         0      // Command
#define LCD_DATA            1      // Data
#define LCD_CLEAR_SCREEN    0x01      // 清屏
#define LCD_HOMING          0x02      // 光標(biāo)返回原點(diǎn)
    E=0;
    RS=style;
    RW=0;        _nop_();
    DBPort=input;   _nop_();//注意順序
    E=1;        _nop_();//注意順序
    E=0;        _nop_();
    LCD_Wait();
//設(shè)置顯示模式************************************************************
#define LCD_SHOW            0x04    //顯示開
#define LCD_HIDE            0x00    //顯示關(guān)
#define LCD_CURSOR          0x02    //顯示光標(biāo)
#define LCD_NO_CURSOR       0x00    //無光標(biāo)
#define LCD_FLASH           0x01    //光標(biāo)閃動
#define LCD_NO_FLASH        0x00    //光標(biāo)不閃動
void LCD_SetDisplay(unsigned char DisplayMode)
    LCD_Write(LCD_COMMAND, 0x08|DisplayMode);
//設(shè)置輸入模式************************************************************
#define LCD_AC_UP       0x02
#define LCD_AC_DOWN         0x00      // default
#define LCD_MOVE            0x01      // 畫面可平移
#define LCD_NO_MOVE         0x00      //default
void LCD_SetInput(unsigned char InputMode)
    LCD_Write(LCD_COMMAND, 0x04|InputMode);
//初始化LCD************************************************************
void LCD_Initial()
    E=0;
    LCD_Write(LCD_COMMAND,0x38);           //8位數(shù)據(jù)端口,2行顯示,5*7點(diǎn)陣
    LCD_SetDisplay(LCD_SHOW|LCD_NO_CURSOR);    //開啟顯示, 無光標(biāo)
    LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN);   //清屏
    LCD_SetInput(LCD_AC_UP|LCD_NO_MOVE);       //AC遞增, 畫面不動
//液晶字符輸入的位置************************
    if(y==0)
        LCD_Write(LCD_COMMAND,0x80|x);
    if(y==1)
        LCD_Write(LCD_COMMAND,0x80|(x-0x40));
//將字符輸出到液晶顯示
    while(*str!='\0')
        LCD_Write(LCD_DATA,*str);
        str++;
//主函數(shù)(main.c):
//#include<tou.h>
typedef union     //定義共用同類型
unsigned int i;
float f;
} value;
//延時函數(shù)
void delay(int z)  //z為毫秒數(shù)
int x,y;
for(x=z;x>0;x--)
  for(y=125;y>0;y--);
unsigned int temp,humi;
value humi_val,temp_val;  //定義兩個共同體,一個用于濕度,一個用于溫度
// float dew_point;       //用于記錄露點(diǎn)值
unsigned char error;      //用于檢驗(yàn)是否出現(xiàn)錯誤
unsigned char checksum;   //CRC
uchar wendu[6];      //用于記錄溫度
uchar shidu[6];      //用于記錄濕度
LCD_Initial();        //初始化液晶
    GotoXY(0,0);        //選擇溫度顯示位置
    Print("TEMP:     %C");      //5格空格
    GotoXY(0,1);        //選擇濕度顯示位置
    Print("HUMI:     %RH");      //5格空格
  error=0;        //初始化error=0,即沒有錯誤
  error+=s_measure((unsigned char*)&temp_val.i,&checksum,TEMP); //溫度測量
  error+=s_measure((unsigned char*)&humi_val.i,&checksum,HUMI); //濕度測量
     if(error!=0) s_connectionreset();                 ////如果發(fā)生錯誤,系統(tǒng)復(fù)位
   humi_val.f=(float)humi_val.i;                   //轉(zhuǎn)換為浮點(diǎn)數(shù)
       temp_val.f=(float)temp_val.i;                   //轉(zhuǎn)換為浮點(diǎn)數(shù)
       calc_sth10(&humi_val.f,&temp_val.f);            //修正相對濕度及溫度
//     dew_point=calc_dewpoint(humi_val.f,temp_val.f); //計(jì)算e dew_point
      temp=temp_val.f*10;
       humi=humi_val.f*10;
       GotoXY(5,0);      //設(shè)置溫度顯示位置
        wendu[0]=temp/1000+'0';       //溫度百位
        wendu[1]=temp%1000/100+'0';      //溫度十位
      wendu[2]=temp%100/10+'0';   //溫度個位
        wendu[3]=0x2E;      //小數(shù)點(diǎn)
      wendu[4]=temp%10+'0';    //溫度小數(shù)點(diǎn)后第一位
   Print(wendu);      //輸出溫度
      GotoXY(5,1);      //設(shè)置濕度顯示位置
   shidu[0]=humi/1000+'0';       //濕度百位
        shidu[1]=humi%1000/100+'0';      //濕度十位
      shidu[2]=humi%100/10+'0';   //濕度個位
        shidu[3]=0x2E;      //小數(shù)點(diǎn)
      shidu[4]=humi%10+'0';    //濕度小數(shù)點(diǎn)后第一位
   Print(shidu);      //輸出濕度
  delay(800);                             //等待足夠長的時間,以現(xiàn)行下一次轉(zhuǎn)換
自己想加進(jìn)去的報(bào)警電路編程:
sbit led     = P3^7;  //超限指示燈
sbit led1    = P3^2;  //正常指示燈
sbit buzz    = P2^3;  //蜂鳴器
sbit key_set = P1^5;  //設(shè)置鍵
void Delay_1ms(uint i);
void display1(void)
        if(SHT10_Check()==1)                //判斷校驗(yàn)和是否正確
  if(temp<=16||temp>35||humi<=40||humi>80) //判斷是否超出設(shè)置的溫濕度上下限
                        buzz=0;                 //超出的話蜂鳴器響起
                        led=0;                 //點(diǎn)亮報(bào)警燈
                        led1=1;
                else                     //否者溫濕度都處于限值范圍內(nèi)
                        buzz=1;                 //關(guān)閉蜂鳴器
                        led=1;
                        led1=0;                 //點(diǎn)亮正常燈
添加了自己的那個代碼后編譯一下出現(xiàn)下面這樣的情況
批注 2020-06-10 154039.png (26.27 KB, 下載次數(shù): 81)
批注 2020-06-10 153552.png (80 KB, 下載次數(shù): 74)
ID:584814 發(fā)表于 2020-6-11 07:09 | 只看該作者
刪除,或改寫。
ID:772955 發(fā)表于 2020-6-11 14:10 | 只看該作者
刪除之后會出現(xiàn)新的錯誤
ID:24758 發(fā)表于 2020-6-11 17:17 | 只看該作者
你程序前面沒有對uint的聲明。
另外你改過來后,可能會出現(xiàn)新的問題,因?yàn)檫@是兩個程序,你不能硬生生的搬過來,塞到原程序里面,需要對新程序中的變量和函數(shù)聲明。
