查看: 3574|回復(fù): 0
單片機串口發(fā)送實時時鐘的電路+程序設(shè)計
ID:774548 發(fā)表于 2020-6-10 10:33 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
這個程序?qū)崿F(xiàn)的是 流水燈先流水兩次,數(shù)碼管全亮全滅一次,顯示hello,然后顯示時鐘(我設(shè)置初值為23-58-40)開始走,當(dāng)時間為零點零分,鬧鐘燈會亮,打開串口發(fā)送助手,會發(fā)送實時時,串口zip是protues圖,發(fā)送zip是keil文件
  1. #include <reg51.h>
  2. #include<intrins.h>
  3. //聲明全局函數(shù)//
  4. void UsartConfiguration();
  5. unsigned char p;
  6. #define uint unsigned int
  7. #define uchar unsigned char
  8. uchar code duan[]={0x76,0x79,0x38,0x38,0x3f};  //顯示hello段選
  9. uchar wei[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  10. unsigned char code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};           //數(shù)字0-9
  11. int num,second,minute,hour,a;
  12. int i,j,k,m,n,s,t;
  13. unsigned char PuZh[16];/數(shù)組比較大,一個漢字占兩個字節(jié)
  14. unsigned char src[16] = {0,1,2,3,4,5,6,7,8,9};
  15. sbit stop=P3^5;
  16. sbit clear=P3^6;
  17. sbit start=P3^7;
  18. sbit hourjia=P2^0;
  19. sbit hourjian=P2^1;
  20. sbit minutejia=P2^2;
  21. sbit minutejian=P2^3;
  22. sbit clock=P2^4;    //設(shè)置鬧鐘
  23. sbit ledground=P2^5;
  24. void mDelay(unsigned int mDelay)    //延遲函數(shù)
  25. { unsigned int i;
  26. for(;mDelay>0;mDelay--)
  27. { for(i=0;i<124;i++)
  28. {;}
  29. }
  30. }
  31. void liushuideng()     //流水燈
  32. {
  33.                 int k=2;      //流水燈流水兩次
  34.   while(k--)
  35.    {     int i;
  36.             ledground=0;   //設(shè)置低電平
  37.       P0=0x01;//第一個燈亮
  38.       mDelay(500);
  39.       for(i=0;i<7;i++)
  40.         {
  41.                P0=P0<<1;
  42.          mDelay(100);
  43.                     }
  44.        ledground=1;//設(shè)置高電平,關(guān)掉流水燈
  45.    }
  46. }
  47. void shumaguan_init()    //數(shù)碼管初始化
  48. {
  49.         P0=0xff;//段選碼     全亮
  50.         P1=0x00;//位選碼
  51.         mDelay(900);
  52.         P0=~0xff;// 取反,全滅
  53.         P1=0x00;
  54.   mDelay(900);
  55. }
  56. void shumaguan()   //數(shù)碼管初始化
  57. {
  58.     uchar n;
  59.     int z=50;
  60.     while(z--)
  61.                 {
  62.     for(n=0;n<5;n++)
  63.        {
  64.                         P1=wei[n];
  65.                         P0=duan[n];
  66.       mDelay(1);
  67.        }
  68.                  }
  69. }
  70. void UsartConfiguration()
  71. {
  72.         SCON=0X50;                        //設(shè)置為工作方式1
  73.         TMOD=0X21;                        //設(shè)置計數(shù)器1為方式2 ,定時器0為方式1
  74.         PCON=0X80;                        //波特率加倍 SMOD=1
  75.         TH1=0XF3;                    //定時器初始值設(shè)置 TH1=256-2^SMOD*f0sc/(波特率*32*12)
  76.         TL1=0XF3;
  77.         TR1=1;                                            //打開定時器
  78. }
  79. void Interrupt_0()   interrupt 1
  80. {        TH0=-50000/256;
  81.         TL0=-50000%256;
  82.         num++;
  83.
  84.         if(num%5==0)
  85.         {        if(minutejia==0)
  86.           {minute++;mDelay(2);if(minute>59) minute=0;}
  87.     if(minutejian==0)
  88.                  { minute--;mDelay(2);if(minute<0) minute=59;}
  89.                 if(hourjia==0)
  90.                 {hour++;mDelay(2);if(hour>23) hour=0;}
  91.                 if(hourjian==0)
  92.           {hour--;mDelay(2);if(hour<0) hour=23;}
  93.         }
  94.         if(num==20)
  95. {        num=0;
  96.     second=second+1;
  97.           if(second>59)
  98.           {second=0;minute=minute+1;}
  99.                 if(minute>59)
  100.                 {minute=0;hour=hour+1;}
  101.                 if(hour>23)
  102.            hour=0;
  103. }
  104.
  105.
  106. }
  107. void main()
  108. {
  109.          clock=0;
  110.   liushuideng();
  111. shumaguan_init();
  112.          shumaguan();
  113.                 a=-50000;                         //a=(-t*f)/12    設(shè)置=50ms   a=[(-50*10^-3)*12*10^6]/12=-50000
  114.         TH0=-50000/256;   //高八位
  115.         TL0=-50000%256;   //低八位
  116.         EA=1;             //總開關(guān)
  117.         ET0=1;            //打開定時器0中斷
  118.         TR0=1;            //打開定時器0
  119. hour=23;            //設(shè)置時鐘初值
  120. minute=58;
  121. second=40;
  122. UsartConfiguration();
  123. while(1)
  124. {
  125.
  126.
  127.                 for(p=0; p<16; p++)
  128.                 {
  129.                         SBUF = PuZh[p];   //將要發(fā)送的數(shù)據(jù)放入到發(fā)送寄存器
  130.                         while(!TI);                  //等待發(fā)送數(shù)據(jù)完成        查詢法
  131.                         TI=0;                          //清除發(fā)送標(biāo)志位
  132.                 }
  133.                 mDelay(3);                  //延時一下再發(fā)
  134.         if(stop==0)  {  TR0=0;}    //暫停
  135.                 if(clear==0)             //清零
  136.                 {
  137.
  138.                         hour=0;
  139.                         second=0;
  140.                         minute=0;
  141.                         TR0=0;
  142.     }
  143.                 if(start==0)        //啟動
  144.                 {TR0=1;}
  145.
  146.             j=second%10;
  147.             k=second/10;
  148.                   m=minute%10;
  149.             n=minute/10;
  150.                   s=hour%10;
  151.             t=hour/10;
  152. PuZh[0] = src[hour/10]+0x30;
  153. PuZh[1] = src[hour% 10]+0x30;
  154. PuZh[2] = 0x2D;
  155. PuZh[3] = src[minute/ 10]+0x30;
  156. PuZh[4] = src[minute% 10]+0x30;
  157.
  158.   if(hour==0&&minute==0)      //定鬧鐘,當(dāng)時間為零點零分,鬧鐘燈亮起
  159.   clock=1;
  160.   else
  161.   clock=0;
  162.
  163.                         P1=0x7f;  //0111 1111
  164.                   P0=tab[j];
  165.                   mDelay(1);
  166.       P1=0xbf;  //1011 1111
  167.                         P0=tab[k];
  168.       mDelay(1);
  169.
  170.                         P1=0xdb;  //1101 1111
  171.                         P0=0x40;
  172.                         mDelay(1);
  173.
  174.
  175.                                 P1=0xef;  //1110 1111
  176.                                 P0=tab[m];
  177.                                 mDelay(1);
  178.                                 P1=0xf7;   //1111 0111
  179.                                 P0=tab[n];
  180.                                 mDelay(1);
  181.
  182.
  183.
  184.                                 P1=0xfd;  //1111 1101
  185.                                 P0=tab[s];
  186.                                 mDelay(1);
  187.                                 P1=0xfe;  //1111 1110
  188.                                 P0=tab[t];
  189.                                 mDelay(1);
  190.                 }
  191. }
串口.zip
22.76 KB, 下載次數(shù): 17, 下載積分: 黑幣 -5
發(fā)送.zip
48.46 KB, 下載次數(shù): 16, 下載積分: 黑幣 -5
參與人數(shù) 1黑幣 +50 收起 理由
