想通過調節滑動變阻器阻值改變數碼管顯示電壓的數值,同時改變直流電機占空比,實現調速。不知道為什么上電之后紅燈不亮;按下停止鍵之后紅燈依然不亮;電機轉動時黃燈閃爍沒有規律。求大佬幫幫忙。
單片機程序如下:
#include <reg51.h>
#define YS 1000
uchar code zixingma[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar code weixuan[]={0x10,0x20,0x40,0x80};
sbit pwm=P2^0;
sbit P21=P2^1;
sbit ST=P3^0;
sbit OE=P3^1;
sbit EOC=P3^2;
sbit ALE=P3^3;
sbit P07=P0^7;
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
void key_scan(void);
void caiji(void);
void qidong();
void tingzhi();
uchar flag,k,n;
void t_0() interrupt 1
TH0=(65536-500)/256;
TL0=(65536-500)%256;
k++;
void delay5ms(void)
unsigned char i,j;
for(i=10;i>0;i--)
for(j=248;j>0;j--);
void delay(uchar t)
while(t--);
void disp(uint num)
uchar i,zheng,dian1,dian2,dian3;
zheng=num/1000;
dian1=num%1000/100;
dian2=num%100/10;
dian3=num%100%10;
for(i=0;i<4;i++)
P1=0xff;
switch(i)
case 0:P2=weixuan[ i];P0=zixingma[zheng];P07=0;break;
case 1:P2=weixuan[ i];P0=zixingma[dian1];break;
case 2:P2=weixuan[ i];P0=zixingma[dian2];break;
case 3:P2=weixuan[ i];P0=zixingma[dian3];break;
delay(200);
uint ADC0809(void)
uint n;
OE=0;
ST=0;
ALE=0;
ST=1;
ALE=1;
ST=0;
ALE=0;
delay(10);
while(!EOC);
OE=1;
n=P1;
OE=0;
return n;
k=0;
flag=0;
P21=1;
TMOD=0x01;
EA=1;
ET0=1;
TR0=1;
pwm=0;
key_scan();
switch(flag)
case 0:disp(ADC0809()*0);break;
case 1:caiji();disp(ADC0809()*19.6078);break;
case 2:qidong();break;
case 3:tingzhi();break;
void key_scan()
if(key1==0)
delay5ms();
if(key1==0)
flag=1;
while(key1==1)
delay5ms();
if(key2==0)
delay5ms();
if(key2==0)
flag=0;
while(key2==1)
delay5ms();
if(key3==0)
delay5ms();
if(key3==0)
flag=2;
while(key3==1)
delay5ms();
if(key4==0)
delay5ms();
if(key4==0)
flag=3;
while(key4==1)
delay5ms();
void caiji()
uint ADC0809(void);
void qidong()
pwm=1;
P21=0;
n=ADC0809()*20;
if(k>100)
k=0;
if(k<n)
pwm=0;
pwm=1;
void tingzhi()
pwm=0;
P21=1;
disp(ADC0809()*0);
