查看: 4251|回復: 2
Keil報了好多錯主要在主函數C100: unprintable character 0xA3 skipped
ID:707584 發表于 2020-6-6 00:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
sj 22.c(69): warning C206: 'Read_Data': missing function-prototype
sj 22.c(69): error C267: 'Read_Data': requires ANSI-style prototype
sj 22.c(139): error C100: unprintable character 0xA3 skipped
sj 22.c(139): error C100: unprintable character 0xBB skipped
sj 22.c(140): error C141: syntax error near 'Format_DateTime'
sj 22.c(140): error C100: unprintable character 0xA3 skipped
sj 22.c(140): error C100: unprintable character 0xBB skipped
sj 22.c(141): error C141: syntax error near 'Format_DateTime'
sj 22.c(141): error C100: unprintable character 0xA3 skipped
sj 22.c(141): error C100: unprintable character 0xBB skipped
sj 22.c(143): error C141: syntax error near 'strcpy'
sj 22.c - 10 Error(s), 1 Warning(s).
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. #include<string.h>
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. //定義DS1302與MCU接口
  7. sbit I0=P1^0;//IO接口
  8. sbit SCLK=P1^1;//時鐘引腳
  9. sbit RST=P1^2;//復位線引腳
  10. //定義1602與單片機的接口
  11. sbit RS=P2^0;//指令數據選擇
  12. sbit RW=P2^1;//接地,執行寫操作
  13. sbit EN=P2^2;//信號使能
  14. uchar *WEEK[]=
  15. {
  16.         "SUN","MON","TUS","WEN","THU","FRI","SAT"
  17. };
  18. uchar LCD_DSY_BUFFER1[ ]={"DATA 00-00-00   "};
  19. uchar LCD_DSY_BUFFER2[ ]={"TIME 00:00:00   "};
  20. uchar DateTime[7];
  21. /************延時i毫秒函數****************/
  22. void DelayMS(uint ms)
  23. {
  24.         uchar i;
  25.         while(ms--)
  26.         {
  27.                 for(i=0;i<120;i++);
  28.         }
  29. }
  30. /************向DS1302寫入1字節數據*********/
  31. void Write_A_Byte_T0_DS1302(uchar x)
  32. {
  33.         uchar i;
  34.         for(i=0;i<8;i++)
  35.         {
  36.                 I0=x&0x01;SCLK=1;SCLK=0;
  37.                 x>>=1;     //x右移1位,高位補0
  38.         }
  39. }
  40. /************向DS1302讀出1字節數據*********/
  41. uchar Get_A_Byte_FROM_DS1302()
  42. {
  43.         uchar i,b=0x00;
  44.         for(i=0;i<8;i++)
  45.         {
  46.                 b=b|_crol_((uchar)I0,i);
  47.                 SCLK=1;SCLK=0;
  48.         }
  49.         return b/16*10+b%16;
  50. }
  51. /************讀取DS1302某地址的數據,先寫命令字,后讀數據*********/
  52. uchar Read_Data_Data(uchar addr)
  53. {
  54.         uchar dat;
  55.         RST=0;//復位
  56.         SCLK=0;//時鐘脈沖置0
  57.         RST=1;//啟動數據傳送
  58.         Write_A_Byte_T0_DS1302(addr);//寫入地址命令字
  59.         dat = Get_A_Byte_FROM_DS1302();//讀出一個字節的數據
  60.         SCLK=1;RST=0;
  61.         return dat;
  62. }
  63. void GetTime()
  64. {
  65.         uchar i,addr=0x81;
  66.         for(i=0;i<7;i++)
  67.         {
  68.                 DateTime[i]=Read_Data(addr); addr+=2;
  69.         }
  70. }
  71. /************讀出LCD狀態*********/
  72. uchar Read_LCD_State()
  73. {
  74.         uchar state;
  75.         RS=0;RW=1;EN=1;DelayMS(1);
  76.         state=P0;
  77.         EN = 0;DelayMS(1);
  78.         return state;
  79. }
  80. /************LCD忙檢查*********/
  81. void LCD_Busy_Wait()
  82. {
  83.         while((Read_LCD_State()&0x80)==0x80);//讀取忙標志BF,BF=1則一直等待
  84.         DelayMS(5);
  85. }
  86. /************向LCD寫數據*********/
  87. void Write_LCD_Data(uchar dat)
  88. {
  89.         LCD_Busy_Wait();//忙檢測確保上一指令完成,也可用適當的延時替代此行
  90.         RS=1;RW=0;EN=0;P0=dat;EN=1;DelayMS(1);EN=0;
  91. }
  92. void Write_LCD_Command(uchar cmd)
  93. {
  94.         LCD_Busy_Wait();
  95.         RS=0;RW=0;EN=0;P0=cmd;EN=1;DelayMS(1);EN=0;
  96. }
  97. /************初始化LCD函數*********/
  98. void Init_LCD()
  99. {
  100.         Write_LCD_Command(0x38);//8位數據接口,2行顯示,5*7點陣字符
  101.         DelayMS(1);//延時保證上一指令完成
  102.         Write_LCD_Command(0x01);//清DDRAM和AC值
  103.         DelayMS(1);
  104.         Write_LCD_Command(0x06);//數據讀寫操作畫面不動,AC自動加1
  105.         DelayMS(1);
  106.         Write_LCD_Command(0x0c);//開顯示,關光標和閃爍
  107.         DelayMS(1);
  108. }
  109. void Set_LCD_P0S(uchar p)
  110. {
  111.         Write_LCD_Command(p|0x80);
  112. }
  113. void Display_LCD_String(uchar p,uchar *s)
  114. {
  115.         uchar i;
  116.         Set_LCD_P0S(p);
  117.         for(i=0;i<16;i++)
  118.         {
  119.                 Write_LCD_Data(s[i]);
  120.                 DelayMS(1);
  121.         }
  122. }
  123. /************格式化日期時間函數*********/
  124. void Format_DateTime(uchar d,uchar *a)
  125. {
  126.         a[0]=d/10+'0';
  127.         a[1]=d%10+'0';
  128. }
  129. /************主函數*********/
  130. void main()
  131. {
  132.         Init_LCD();//初始化液晶
  133.         while(1)
  134.         {
  135.                 GetTime();//獲取當前時間
  136.                 Format_DateTime(DateTime[6],LCD_DSY_BUFFER1+5);//通道號顯示
  137.                 Format_DateTime(DateTime[4],LCD_DSY_BUFFER1+8);
  138.                 Format_DateTime(DateTime[3],LCD_DSY_BUFFER1+11);
  139.
  140.                 strcpy(LCD_DSY_BUFFER1+13,WEEK[DateTime[5]]);
  141.
  142.                 Format_DateTime(DateTime[2],LCD_DSY_BUFFER1+5);
  143.                 Format_DateTime(DateTime[1],LCD_DSY_BUFFER1+8);
  144.                 Format_DateTime(DateTime[0],LCD_DSY_BUFFER1+11);
  145.
  146.                 Display_LCD_String(0x00,LCD_DSY_BUFFER1);//液晶顯示
  147.                 Display_LCD_String(0x40,LCD_DSY_BUFFER2);
  148.         }
  149. }
ID:487821 發表于 2020-6-6 09:54 | 只看該作者
uchar Read_Data_Data(uchar addr),此函數與 DateTime[i]=Read_Data(addr); addr+=2;這使用的函數名不一致;   GetTime();//獲取當前時間
這里的分號用成了中文了,改一下就好了
ID:487821 發表于 2020-6-6 09:55 | 只看該作者
#include<reg52.h>
#include<intrins.h>
#include<string.h>
//定義DS1302與MCU接口
sbit I0=P1^0;//IO接口
//定義1602與單片機的接口
sbit EN=P2^2;//信號使能
uchar *WEEK[]=
uchar DateTime[7];
        uchar i;
        while(ms--)
                for(i=0;i<120;i++);
        uchar i;
        for(i=0;i<8;i++)
                x>>=1;     //x右移1位,高位補0
        uchar i,b=0x00;
        for(i=0;i<8;i++)
                SCLK=1;SCLK=0;
uchar Read_Data(uchar addr)
        uchar dat;
        RST=0;//復位
        SCLK=0;//時鐘脈沖置0
        RST=1;//啟動數據傳送
        SCLK=1;RST=0;
        return dat;
void GetTime()
        uchar i,addr=0x81;
        for(i=0;i<7;i++)
        uchar state;
        state=P0;
        EN = 0;DelayMS(1);
        return state;
        DelayMS(5);
        LCD_Busy_Wait();
void Init_LCD()
        DelayMS(1);
        DelayMS(1);
        DelayMS(1);
        uchar i;
        Set_LCD_P0S(p);
        for(i=0;i<16;i++)
                DelayMS(1);
        a[0]=d/10+'0';
        a[1]=d%10+'0';
        Init_LCD();//初始化液晶
                GetTime();//獲取當前時間
//給你改好了,你試試
