一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
2020-6-5 22:00 上傳
圖1
二,調整原理圖大小,適合可視,另存工程文件。(如下圖2,3,4所示)
2020-6-5 22:00 上傳
圖2
2020-6-5 22:00 上傳
圖3
2020-6-5 22:00 上傳
圖4
三,點擊Source Code標簽。(如下圖5所示)
2020-6-5 22:00 上傳
圖5
四,編輯main.c 代碼如Proteus8.9 VSM Studio IAR編譯器仿真AT89C51RD2系列022_lcdNokia3310_5510 (如下圖6所示)
2020-6-5 22:00 上傳
圖6
五,Main.c 代碼:
/* Main.c file generated by New Project wizard
* Coder: Ziegler Yin
* Created: 周日 5月 3 2020
* Processor: AT89C51RD2
* Compiler: IAR for 8051 (C)
#include "Nokia.h"
char mt1[]=" Welcome to ";
char mt2[]="Kaillen Work ";
char mt3[]=" www*wark*top ";
char mt4[]="Nokia3310_5110";
char mt5[]=" Code Made ";
char mt6[]=" _-Ziegler Yin ";
int main(void) {
LCD_init(); //初始化液晶
LCD_clear();
SCLK =1;
while(1) {
LCD_write_english_string(0, 0, mt1);
LCD_write_english_string(0, 1, mt2);
LCD_write_english_string(0, 2, mt3);
LCD_write_english_string(0, 3, mt4);
LCD_write_english_string(0, 4, mt5);
LCD_write_english_string(0, 5, mt6);
nokia_5110.h:
*Coder: Ziegler Yin
* Compiler: Keil for 8051
#ifndef __NOKIA_H_
#define __NOKIA_H_
#include <stdio.h>
#include <ioAT89C51.h>
#include <intrinsics.h>
#define u8 unsigned char
#define u16 unsigned int
#define SCLK (P2_bit.P2_5)
#define SDIN (P2_bit.P2_4)
#define LCD_DC (P2_bit.P2_3)
#define LCD_CE (P2_bit.P2_2)
#define LCD_RST (P2_bit.P2_1)
#define delay_time 25664
static u8 ft[][6] =
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // sp
{ 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00 }, // !
{ 0x00, 0x00, 0x07, 0x00, 0x07, 0x00 }, // "
{ 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14 }, // #
{ 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12 }, // $
{ 0x00, 0x62, 0x64, 0x08, 0x13, 0x23 }, // %
{ 0x00, 0x36, 0x49, 0x55, 0x22, 0x50 }, // &
{ 0x00, 0x00, 0x05, 0x03, 0x00, 0x00 }, // '
{ 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00 }, // (
{ 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00 }, // )
{ 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14 }, // *
{ 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08 }, // +
{ 0x00, 0x00, 0x00, 0xA0, 0x60, 0x00 }, // ,
{ 0x00, 0x08, 0x08, 0x08, 0x08, 0x08 }, // -
{ 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 }, // .
{ 0x00, 0x20, 0x10, 0x08, 0x04, 0x02 }, // /
{ 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E }, // 0
{ 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00 }, // 1
{ 0x00, 0x42, 0x61, 0x51, 0x49, 0x46 }, // 2
{ 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31 }, // 3
{ 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10 }, // 4
{ 0x00, 0x27, 0x45, 0x45, 0x45, 0x39 }, // 5
{ 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30 }, // 6
{ 0x00, 0x01, 0x71, 0x09, 0x05, 0x03 }, // 7
{ 0x00, 0x36, 0x49, 0x49, 0x49, 0x36 }, // 8
{ 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E }, // 9
{ 0x00, 0x00, 0x36, 0x36, 0x00, 0x00 }, // :
{ 0x00, 0x00, 0x56, 0x36, 0x00, 0x00 }, // ;
{ 0x00, 0x08, 0x14, 0x22, 0x41, 0x00 }, // <
{ 0x00, 0x14, 0x14, 0x14, 0x14, 0x14 }, // =
{ 0x00, 0x00, 0x41, 0x22, 0x14, 0x08 }, // >
{ 0x00, 0x02, 0x01, 0x51, 0x09, 0x06 }, // ?
{ 0x00, 0x32, 0x49, 0x59, 0x51, 0x3E }, // @
{ 0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C }, // A
{ 0x00, 0x7F, 0x49, 0x49, 0x49, 0x36 }, // B
{ 0x00, 0x3E, 0x41, 0x41, 0x41, 0x22 }, // C
{ 0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C }, // D
{ 0x00, 0x7F, 0x49, 0x49, 0x49, 0x41 }, // E
{ 0x00, 0x7F, 0x09, 0x09, 0x09, 0x01 }, // F
{ 0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A }, // G
{ 0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F }, // H
{ 0x00, 0x00, 0x41, 0x7F, 0x41, 0x00 }, // I
{ 0x00, 0x20, 0x40, 0x41, 0x3F, 0x01 }, // J
{ 0x00, 0x7F, 0x08, 0x14, 0x22, 0x41 }, // K
{ 0x00, 0x7F, 0x40, 0x40, 0x40, 0x40 }, // L
{ 0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F }, // M
{ 0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F }, // N
{ 0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E }, // O
{ 0x00, 0x7F, 0x09, 0x09, 0x09, 0x06 }, // P
{ 0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E }, // Q
{ 0x00, 0x7F, 0x09, 0x19, 0x29, 0x46 }, // R
{ 0x00, 0x46, 0x49, 0x49, 0x49, 0x31 }, // S
{ 0x00, 0x01, 0x01, 0x7F, 0x01, 0x01 }, // T
{ 0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F }, // U
{ 0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F }, // V
{ 0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F }, // W
{ 0x00, 0x63, 0x14, 0x08, 0x14, 0x63 }, // X
{ 0x00, 0x07, 0x08, 0x70, 0x08, 0x07 }, // Y
{ 0x00, 0x61, 0x51, 0x49, 0x45, 0x43 }, // Z
{ 0x00, 0x00, 0x7F, 0x41, 0x41, 0x00 }, // [
{ 0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55 }, // 55
{ 0x00, 0x00, 0x41, 0x41, 0x7F, 0x00 }, // ]
{ 0x00, 0x04, 0x02, 0x01, 0x02, 0x04 }, // ^
{ 0x00, 0x40, 0x40, 0x40, 0x40, 0x40 }, // _
{ 0x00, 0x00, 0x01, 0x02, 0x04, 0x00 }, // '
{ 0x00, 0x20, 0x54, 0x54, 0x54, 0x78 }, // a
{ 0x00, 0x7F, 0x48, 0x44, 0x44, 0x38 }, // b
{ 0x00, 0x38, 0x44, 0x44, 0x44, 0x20 }, // c
{ 0x00, 0x38, 0x44, 0x44, 0x48, 0x7F }, // d
{ 0x00, 0x38, 0x54, 0x54, 0x54, 0x18 }, // e
{ 0x00, 0x08, 0x7E, 0x09, 0x01, 0x02 }, // f
{ 0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C }, // g
{ 0x00, 0x7F, 0x08, 0x04, 0x04, 0x78 }, // h
{ 0x00, 0x00, 0x44, 0x7D, 0x40, 0x00 }, // i
{ 0x00, 0x40, 0x80, 0x84, 0x7D, 0x00 }, // j
{ 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00 }, // k
{ 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00 }, // l
{ 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78 }, // m
{ 0x00, 0x7C, 0x08, 0x04, 0x04, 0x78 }, // n
{ 0x00, 0x38, 0x44, 0x44, 0x44, 0x38 }, // o
{ 0x00, 0xFC, 0x24, 0x24, 0x24, 0x18 }, // p
{ 0x00, 0x18, 0x24, 0x24, 0x18, 0xFC }, // q
{ 0x00, 0x7C, 0x08, 0x04, 0x04, 0x08 }, // r
{ 0x00, 0x48, 0x54, 0x54, 0x54, 0x20 }, // s
{ 0x00, 0x04, 0x3F, 0x44, 0x40, 0x20 }, // t
{ 0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C }, // u
{ 0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C }, // v
{ 0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C }, // w
{ 0x00, 0x44, 0x28, 0x10, 0x28, 0x44 }, // x
{ 0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C }, // y
{ 0x00, 0x44, 0x64, 0x54, 0x4C, 0x44 }, // z
{ 0x14, 0x14, 0x14, 0x14, 0x14, 0x14 } // horiz lines
static u8 write_chinese[][24]={
//測
{0x89,0xF2,0x00,0xFF,0x01,0xF9,0xFF,0x00,0xFC,0x00,0xFF,0x00,0x00,0x07,0x04,0x04,0x02,0x01,0x02,0x04,0x01,0x04,0x07,0x00},
//試
{0x11,0xF6,0x00,0x04,0x24,0xE4,0x24,0x24,0xFF,0x05,0x06,0x00,0x00,0x07,0x02,0x01,0x02,0x03,0x01,0x01,0x01,0x02,0x07,0x00},
//程
{0x8A,0x6A,0xFF,0x49,0x20,0xAF,0xA9,0xE9,0xA9,0xAF,0x20,0x00,0x01,0x00,0x07,0x00,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0x00},
//序
{0x00,0xFE,0x42,0x4A,0x4A,0x5B,0xEA,0x5A,0x4A,0xC2,0x42,0x00,0x06,0x01,0x00,0x00,0x04,0x04,0x07,0x00,0x00,0x00,0x00,0x00},
void delay_1us(void);
void delay_1ms(void);
void delay_nms(u16 n);
void LCD_init(void);
void LCD_clear(void);
void LCD_set_XY(u8 X, u8 Y);
void LCD_write_char(u8 c);
void LCD_write_english_string(u8 X, u8 Y, char *st); //u8 X, u8 Y, char *s
void LCD_write_chinese_string(u8 X, u8 Y, u8 ch_with,u8 num, u8 line,u8 row);
void LCD_draw_bmp_pixel(u8 X, u8 Y, u8 *map, u8 Pix_x, u8 Pix_y);
void LCD_write_byte(u8 dat, u8 command);
#endif
六,點擊構建工程按鈕,編譯工程。(如下圖7所示)
2020-6-5 22:00 上傳
圖7
七,點擊窗口左下方仿真按鈕,可見lcdNokia3310_5510屏上信息顯示在屏。 (如下圖8,9,10所示)
2020-6-5 22:00 上傳
圖8
2020-6-5 22:00 上傳
圖9
2020-6-5 22:00 上傳
圖10
附件Proteus8.9 VSM Studio IAR編譯器仿真AT89C51RD2系列022_lcdNokia3310_5510在已安裝Proteus8.9的計算機文件夾中打開即可
需要進一步了解,請加入QQ群:976235464
