單片機(jī)源程序如下:
#include"reg51.h"
#include"intrins.h"
#include"lcd.h"
#define dula P0 //段選
#define wela P2 //位選
sbit P20=P3^4;
sbit P21=P3^5;
uint v_low=50,v_mid=100,v_high=200; //高中低速度
uchar flag=0;/***高低電平標(biāo)志***/
bit direction=0;/***方向標(biāo)志***/
static uint constant=380-50;//可以改變占空比
uint count_ms,count_s;
/****函數(shù)聲明****/
void delay(uchar i);
void reverse(void);
uchar k; //按鍵值
uchar kflag=1; //標(biāo)志位
uchar tflag; //標(biāo)志位
uchar dis[4]; //顯示
const unsigned char table[]={ //數(shù)字不帶小數(shù)點(diǎn)
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,
0x40,0x76,0x38};
/***定時(shí)器t0***/
void time0(void) interrupt 1 using 1
static uint i;
i++;
if(kflag==1) //低-中-高 自然風(fēng)
count_ms++;
if(count_ms>10000)
count_ms=0;
count_s++;
if(count_s==1) {constant=380-v_low;dis[0]=v_low/1000; //低
dis[1]=v_low/100;
dis[2]=v_low%100/10;
dis[3]=v_low%10;}
else if(count_s==30) {constant=380-v_mid;dis[0]=v_mid/1000;//中
dis[1]=v_mid/100;
dis[2]=v_mid%100/10;
dis[3]=v_mid%10;}
else if (count_s==60) {constant=380-v_high;dis[0]=v_high/1000;//高
dis[1]=v_high/100;
dis[2]=v_high%100/10;
dis[3]=v_high%10;}
else if (count_s>90) {count_s=0;}
/**頻率為固定的1kHZ左右,只是占空比發(fā)生變化**/
if(i<=constant)
flag=1;
if(i<=380&&i>constant)
flag=2;
if(i==380)
i=0;
TH0=0xff;
TL0=0xe7;
延時(shí)函數(shù) 毫秒
void delay_ms(unsigned int timer)
unsigned int i,j;
for(i=0; i<timer; i++)
for(j=0; j<110; j++);
/****改變轉(zhuǎn)向標(biāo)志*****/
void int1_srv (void) interrupt 2 using 2
if(INT1==0)
while(!INT1);
direction=!direction;
/****延時(shí)****/
void delay(uchar i)
while(i--)
_nop_();
顯示函數(shù)
void display(unsigned int first,unsigned int second,unsigned int third,unsigned int forth) //顯示函數(shù)
wela = 0xfe; //位選1
dula = table[first]; //段選1
delay_ms(2); //延時(shí)
dula = 0x00; //清零
wela = 0xfd; //位選2
dula = table[second];//段選2
dula = 0x00;//清零
wela = 0xfb; //位選3
dula = table[third];//段選3
dula = 0x00;//清零
wela = 0xf7; //位選4
dula = table[forth];//段選4
dula = 0x00; //清零
void Getch (void) //按鍵掃描
unsigned char X,Y,Z;
P1=0x0f; //對(duì)P1置數(shù) 行掃描
if(P1!=0x0f) //有按鍵按下
delay_ms(10); //延時(shí)消抖
X=P1; //保存行掃描有按鍵按下的狀態(tài)
P1=0xf0; //列掃描
Y=P1; //保存列掃描有按鍵按下的狀態(tài)
Z=X|Y; //取出按鍵值
switch ( Z ) //判斷是哪個(gè)按鍵按下
case 0xee: k=0; break; //給按鍵賦值
case 0xed: k=1; break;
case 0xeb: k=2; break;
case 0xe7: k=3; break;
case 0xde: k=4; break;
case 0xdd: k=5; break;
case 0xdb: k=6; break;
case 0xd7: k=7; break;
case 0xbe: k=8; break;
case 0xbd: k=9; break;
case 0xbb: k=10;break;
case 0xb7: k=11;break;
case 0x7e: k=12;break;
case 0x7d: k=13;break;
case 0x7b: k=14;break;
case 0x77: k=15;break;
while(P1!=0xf0); //按鍵抬起有效
void sel_mode(void)
if (k==10){kflag=1;} //自然風(fēng)
if (k==11){kflag=2;} //連續(xù)風(fēng)
if(kflag==2)
if(k==12) {tflag=1;constant=380-v_low;dis[0]=1; //di低
dis[1]=v_low/100;
dis[3]=v_low%10;}
if(k==13) {tflag=2;constant=380-v_mid;dis[0]=1; //中
dis[1]=v_mid/100;
dis[3]=v_mid%10;}
if(k==14) {tflag=3;constant=380-v_high;dis[0]=1; //高
dis[1]=v_high/100;
dis[3]=v_high%10;}
//按鍵設(shè)置 開機(jī)后自動(dòng)是自然風(fēng) 按B切換成固定風(fēng) 在固定風(fēng)模式下
//按C是低風(fēng) 此時(shí)可調(diào)整轉(zhuǎn)速 連續(xù)輸入三位0-9的數(shù)字 注意不能超過100
//按D是中風(fēng) 此時(shí)可調(diào)整轉(zhuǎn)速 連續(xù)輸入三位0-9的數(shù)字 注意不能超過200
//按E是高風(fēng) 此時(shí)可調(diào)整轉(zhuǎn)速 連續(xù)輸入三位0-9的數(shù)字 注意不能超過350
void set_mode(void)
static uchar num=0;
static uchar temp[3];
if(tflag==1)//按C是低風(fēng)
if(k<10)
temp[num]=k;
num++;
if(num>=3) // 連續(xù)輸入三位0-9的數(shù)字
v_low=temp[0]*100+temp[1]*10+ temp[2] ; //算出數(shù)值
num=0;
tflag=0;
constant=380-v_low;
dis[0]=1; //di低
dis[1]=v_low/100;
dis[3]=v_low%10;
k=22;
if(tflag==2)//按D是中風(fēng)
if(k<10)
temp[num]=k;
num++;
v_mid=temp[0]*100+temp[1]*10+ temp[2] ; //算出數(shù)值
num=0;
tflag=0;
constant=380-v_mid;
dis[0]=1; //di低
dis[1]=v_mid/100;
dis[3]=v_mid%10;
k=22;
if(tflag==3)//按E是高風(fēng)
if(k<10)
temp[num]=k; //連續(xù)輸入三位0-9的數(shù)字
num++;
if(num>=3)
v_high=temp[0]*100+temp[1]*10+ temp[2] ; //算出數(shù)值
num=0;
tflag=0;
dis[0]=1; //di低
dis[1]=v_high/100;
dis[3]=v_high%10;
k=22;
EA=1;
TMOD=0x01;
ET0=1;
TR0=1;
EX0=1;
IT0=1;
EX1=1;
IT1=1;
TH0=0xff;
TL0=0xe7;//25us
LCD_Initial();
delay(10);
Getch();////按鍵掃描
sel_mode();//設(shè)置模式
set_mode();//設(shè)置轉(zhuǎn)速
reverse();
display(dis[0],dis[1],dis[2],dis[3]); //顯示函數(shù)
全部資料51hei下載地址:
單片機(jī)自然風(fēng).rar
(107.64 KB, 下載次數(shù): 77)
2020-6-5 13:10 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
