查看: 2058|回復: 2
單片機小白關于使用AT24C02的問題
在截圖中要求的基礎上實現按9清除 按10存儲在AT24C02中 按返回數碼管重新顯示之前點確認存在芯片中的數,大佬看一下程序邏輯哪兒有問題
  1. #include<reg51.h>
  2. #include<AT24C02.h>
  4. #define        uint unsigned int
  5. sbit P3_2=P3^2;
  6. uchar code led_mod[]={0x3f,0x06,0x5b,0x4f,0x66,
  7. 0x6d,0x7d,0x07,0x7f,0x6f,0x00};
  8. uchar code BitCode[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  9. uchar huanchong[]={10,10,10,10,10,10,10,10};
  10. uchar convert[]={10,10,10,10,10,10,10,10};
  11. uchar a=0;
  12. sbit        SDA = P3^1;
  13. sbit        SCL = P3^0;
  14. #define E2PROM_ADDR  0x12
  15. void dnms(uchar n)
  16. {
  17.         uchar i;
  18.         for(i=0;i<n;i++)
  19.                 delay1ms();
  20. }
  21. void int0()  interrupt 0
  22. {
  23.         uchar code RowCode[]={0xfe,0xfd,0xfb,0xf7};
  24.         uchar temp,row,column,i,y,z;
  25.         uchar m,n;
  26.         P1=0xf0;
  27.         temp = P1 & 0xf0;
  28.             if (temp != 0xf0)
  29.                         {
  30.        P2=0xff;
  31.        switch (temp)
  32.                    {
  33.                                  case 0x70: column = 3; break;
  34.                                  case 0xb0: column = 2; break;
  35.                                  case 0xd0: column = 1; break;
  36.                                  case 0xe0: column = 0; break;
  37.                                  default: break;
  38.                          }
  39.                          for (i=0;i<4;i++)
  40.                          {
  41.                                  P1 = RowCode[i];
  42.                                  temp = P1 & 0xf0;
  43.                                  if (temp !=0xf0)
  44.                                  {
  45.                                          row = i;break;
  46.                                  }
  47.                          }
  48.                          y= row *4 + column;
  49.                          if(y<10)
  50.                          {
  51.                                  if(a<8)
  52.                                  {
  53.                                          huanchong[a++]=y;
  54.                              m=a;
  55.                                          for(n=0;n<a;n++)
  56.                        {
  57.                                 convert[n]=huanchong[--m];
  58.
  59.                              }
  60.                                  }
  61.                          }
  62.              if(y==10)
  63.                          {
  64.                                  P2=0xff;
  65.                                  a=0;
  66.                                  for(z=0;z<8;z++)
  67.                                  {
  68.                                          huanchong[z]=10;
  69.                                          convert[z]=10;
  70.                                  }
  71.                    }
  72.                         while((P1 & 0xf0) !=0xf0);
  73.          }
  74.
  75. }
  76. void start()
  77. {
  78.         SDA = 1;
  79.         SCL = 1;
  80.         NOP4();
  81.         SDA = 0;
  82.         NOP4();
  83.         SCL = 0;
  84. }
  85. void stop()
  86. {
  87.         SDA = 0;
  88.         SCL = 1;
  89.         NOP4();
  90.         SDA = 1;
  91.         NOP4();
  92.         SDA = 0;
  93.         SCL = 0;
  94. }
  95. void Write_E2PROM(uchar add,uchar dat)
  96. {
  97.         start();
  98.         Write_E2PROM(E2PROM_ADDR);
  99.   Write_E2PROM(add);
  100.         Write_E2PROM(dat);
  101.         stop();
  102.         dnms(4);
  103. }
  104. uchar        Read_E2PROM(uchar set_addr)
  105. {
  106.         start();
  107.         Read_E2PROM(E2PROM_ADDR);
  108.         Read_E2PROM(set_addr);
  109.         return (Read_E2PROM());
  110. }
  111. void BufToSeg(void)
  112. {
  113.         uchar i=0;
  114.         uchar x;
  115.   for(i=0;i<8;i++)
  116.          {
  117.
  118.            P0=led_mod[10];
  119.                  P2= BitCode[i];
  120.                  P0=led_mod[convert[i]];
  121.                  if(P1=0x7b){
  122.                   Write_E2PROM(0x00,convert[i]);
  123.                  }
  124.                  if(P1=0xe7){
  125.                         x=Read_E2PROM(0x00);
  126.                         P0=led_mod[10];
  127.                         P2= BitCode[x];
  128.                   P0=led_mod[convert[x]];
  129.                  }
  130.         }
  131. }
  132. void main(void)
  133. {
  134.         EA=1;
  135.         EX0=1;
  136.         IT0=1;
  137.         while(1)
  138.         {
  139.                 P1=0x0f;
  140.                 BufToSeg();
  141.         }
  142. }
ID:584814 發表于 2020-6-6 08:44 | 只看該作者
自己把程序逐行注釋一下然后就全明白了
ID:769497 發表于 2020-6-6 19:46 | 只看該作者
請問24c02是咋用的
