#include <reg52.h> //包含頭文件,一般情況不需要改動(dòng),頭文件包含特殊功能寄存器的定義
#include "intrins.h"
#define u8 unsigned char
#define u16 unsigned int
uchar yushe_wendu=50; //溫度預(yù)設(shè)值
uchar yushe_yanwu=100; //光照預(yù)設(shè)值
uchar yushe_tianranqi=100; //天然氣預(yù)設(shè)值
uint wendu; //溫度值全局變量
uchar yanwu; //用于讀取ADC數(shù)據(jù)
uchar tianranqi; //用于讀取ADC數(shù)據(jù)
uint times = 0; //變量times,計(jì)數(shù),用于液晶切換顯示
uchar shezhi_flag = 0; //變量標(biāo)志位,用于切換顯示設(shè)置天然氣預(yù)設(shè)值
uchar Mode=0; //=1是設(shè)置溫度閥值 =2是設(shè)置光照閥值 =0是正常監(jiān)控模式
uint Buzzer=0;
uint count = 0;
sbit Led_Yellow =P2^4; //黃燈
sbit speaker =P2^0; //蜂鳴器
sbit cg=P2^3; //總開(kāi)關(guān)
sbit c1_k=P1^1; //窗簾1開(kāi)關(guān)
sbit c2_k=P1^4; //窗簾2開(kāi)關(guān)
void delay_ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<110;j++);
sbit LCDRS = P2^7;
sbit LCDEN = P2^6;
sbit D0 = P0^0;
sbit D1 = P0^1;
sbit D2 = P0^2;
sbit D3 = P0^3;
sbit D4 = P0^4;
sbit D5 = P0^5;
sbit D6 = P0^6;
sbit D7 = P0^7;
void LCDdelay(uint z) //該延時(shí)大約100us(不精確,液晶操作的延時(shí)不要求很精確)
uint x,y;
for(x=z;x>0;x--)
for(y=10;y>0;y--);
void LCD_WriteData(u8 dat)
if(dat&0x01)D0=1;else D0=0;
if(dat&0x02)D1=1;else D1=0;
if(dat&0x04)D2=1;else D2=0;
if(dat&0x08)D3=1;else D3=0;
if(dat&0x10)D4=1;else D4=0;
if(dat&0x20)D5=1;else D5=0;
if(dat&0x40)D6=1;else D6=0;
if(dat&0x80)D7=1;else D7=0;
void write_com(uchar com)
LCDRS=0;
LCD_WriteData(com);
LCDdelay(5);
LCDEN=1;
LCDdelay(5);
LCDEN=0;
void write_data(uchar date)
LCDRS=1;
LCD_WriteData(date);
LCDdelay(5);
LCDEN=1;
LCDdelay(5);
LCDEN=0;
void SelectPosition(unsigned char x,unsigned char y)
if (x == 0)
write_com(0x80 + y); //表示第一行
write_com(0xC0 + y); //表示第二行
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
SelectPosition(x,y) ;
while (*s)
write_data( *s);
s ++;
void LCD_Write_Char(u8 x,u8 y,u16 s,u8 l)
if(l>=5)
write_data(0x30+s/10000%10); //萬(wàn)位
if(l>=4)
write_data(0x30+s/1000%10); //千位
if(l>=3)
write_data(0x30+s/100%10); //百位
if(l>=2)
write_data(0x30+s/10%10); //十位
if(l>=1)
write_data(0x30+s%10); //個(gè)位
void Init1602()
uchar i=0;
write_com(0x38);//屏幕初始化
write_com(0x0c);//打開(kāi)顯示 無(wú)光標(biāo) 無(wú)光標(biāo)閃爍
write_com(0x06);//當(dāng)讀或?qū)懸粋(gè)字符是指針后一一位
write_com(0x01);//清屏
void Display_1602(yushe_wendu,yushe_yanwu,c,temp)
//顯示預(yù)設(shè)溫度
LCD_Write_Char(0,6,yushe_wendu,2) ;
//顯示預(yù)設(shè)光照
LCD_Write_Char(0,13,yushe_yanwu,3) ;
//時(shí)時(shí)溫度
LCD_Write_Char(1,6,c/10,2) ;
write_data('.');
LCD_Write_Char(1,9,c%10,1) ;
//時(shí)時(shí)光照
LCD_Write_Char(1,13,temp,3) ;
ADC0832相關(guān)函數(shù)
sbit ADCS =P1^5; //ADC0832 片選
sbit ADCLK =P1^2; //ADC0832 時(shí)鐘
sbit ADDI =P1^3; //ADC0832 數(shù)據(jù)輸入 /*因?yàn)閱纹瑱C(jī)的管腳是雙向的,且ADC0832的數(shù)據(jù)輸入輸出不同時(shí)進(jìn)行,
sbit ADDO =P1^3; //ADC0832 數(shù)據(jù)輸出 /*為節(jié)省單片機(jī)引腳,簡(jiǎn)化電路所以輸入輸出連接在同一個(gè)引腳上
// 函數(shù): unsigned int Adc0832(unsigned char channel)
// 應(yīng)用: temp=Adc0832(0);
// 描述: 讀取0通道的AD值
// 參數(shù): channel:通道0和通道1選擇
// 返回: 選取通道的AD值
// 版本: VER1.0
// 日期: 2015-05-29
// 備注:
uchar i=0;
uchar j;
uint dat=0;
uchar ndat=0;
uchar Vot=0;
if(channel==0)channel=2;
if(channel==1)channel=3;
ADDI=1;
_nop_();
_nop_();
ADCS=0;//拉低CS端
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿1
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=channel&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿2
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=(channel>>1)&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿3
ADDI=1;//控制命令結(jié)束
_nop_();
_nop_();
dat=0;
for(i=0;i<8;i++)
dat|=ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
ADCLK=0;//形成一次時(shí)鐘脈沖
_nop_();
_nop_();
dat<<=1;
if(i==7)dat|=ADDO;
for(i=0;i<8;i++)
j=0;
j=j|ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
_nop_();
_nop_();
j=j<<7;
ndat=ndat|j;
if(i<7)ndat>>=1;
ADCS=1;//拉低CS端
ADCLK=0;//拉低CLK端
ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
dat<<=8;
dat|=ndat;
return(dat); //return ad data
DS18B20相關(guān)函數(shù)
sbit DQ = P1^0; //ds18b20的數(shù)據(jù)引腳
/*****延時(shí)子程序:該延時(shí)主要用于ds18b20延時(shí)*****/
void Delay_DS18B20(int num)
while(num--) ;
/*****初始化DS18B20*****/
void Init_DS18B20(void)
unsigned char x=0;
DQ = 1; //DQ復(fù)位
Delay_DS18B20(8); //稍做延時(shí)
DQ = 0; //單片機(jī)將DQ拉低
Delay_DS18B20(80); //精確延時(shí),大于480us
DQ = 1; //拉高總線
Delay_DS18B20(14);
x = DQ; //稍做延時(shí)后,如果x=0則初始化成功,x=1則初始化失敗
Delay_DS18B20(20);
/*****讀一個(gè)字節(jié)*****/
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 給脈沖信號(hào)
dat>>=1;
DQ = 1; // 給脈沖信號(hào)
if(DQ)
dat|=0x80;
Delay_DS18B20(4);
return(dat);
/*****寫(xiě)一個(gè)字節(jié)*****/
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
Delay_DS18B20(5);
DQ = 1;
dat>>=1;
/*****讀取溫度*****/
unsigned int ReadTemperature(void)
unsigned char a=0;
unsigned char b=0;
unsigned int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC); //跳過(guò)讀序號(hào)列號(hào)的操作
WriteOneChar(0x44); //啟動(dòng)溫度轉(zhuǎn)換
Init_DS18B20();
WriteOneChar(0xBE); //讀取溫度寄存器
a=ReadOneChar(); //讀低8位
b=ReadOneChar(); //讀高8位
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5; //放大10倍輸出并四舍五入
return(t);
/*****校準(zhǔn)溫度*****/
u16 check_wendu(void)
u16 c;
c=ReadTemperature()-5; //獲取溫度值并減去DS18B20的溫漂誤差
if(c<1) c=0;
if(c>=900) c=0;
return c;
按鍵檢測(cè)相關(guān)函數(shù)
//按鍵
sbit Key1=P1^6; //設(shè)置鍵
sbit Key2=P1^7; //加按鍵
sbit Key3=P3^2; //減按鍵
#define KEY_SET 1 //設(shè)置
#define KEY_ADD 2 //加
#define KEY_MINUS 3 //減
// 函數(shù): u8 Key_Scan()
// 應(yīng)用: temp=u8 Key_Scan();
// 描述: 按鍵掃描并返回按下的鍵值
// 參數(shù): NONE
// 返回: 按下的鍵值
// 版本: VER1.0
// 日期: 2015-05-29
// 備注: 該函數(shù)帶松手檢測(cè),按下鍵返回一次鍵值后返回0,直至第二次按鍵按下
u8 Key_Scan()
static u8 key_up=1;//按鍵按松開(kāi)標(biāo)志
if(key_up&&(Key1==0||Key2==0||Key3==0))
delay_ms(10);//去抖動(dòng)
key_up=0;
if(Key1==0) return 1;
else if(Key2==0)return 2;
else if(Key3==0)return 3;
else if(Key1==1&&Key2==1&&Key3==1)
key_up=1;
return 0;// 無(wú)按鍵按下
/*************定時(shí)器0初始化程序***************/
void time_init()
TMOD=0X01; //定時(shí)器0、工作方式1
TH0=(65536-10000)/256;
TL0=(65536-10000)%256;
EA=1; //開(kāi)總中斷
ET0=1; //開(kāi)定時(shí)器0中斷
TR0=1; //允許定時(shí)器0定時(shí)
/*************定時(shí)器0中斷服務(wù)程序***************/
void time0_int() interrupt 1
TH0 = (65536-1000)/256;
TL0 = (65536-1000)%256; // 50ms 12M
count++;
if(count>80)
count = 0;
wendu=check_wendu(); //讀取溫度值
yanwu=Adc0832(0); //讀取光照值
tianranqi=Adc0832(1); //讀取天然氣值
if((wendu>=(yushe_wendu*10))||(tianranqi>yushe_tianranqi)) //溫度大于等于預(yù)設(shè)溫度值時(shí)(為什么是大于預(yù)設(shè)值*10:因?yàn)槲覀円@示的溫度是有小數(shù)點(diǎn)后一位,是一個(gè)3位數(shù),25.9°C時(shí)實(shí)際讀的數(shù)是259,所以判斷預(yù)設(shè)值時(shí)將預(yù)設(shè)值*10)
speaker=0; //打開(kāi)蜂鳴器報(bào)警
Led_Yellow=0; //打開(kāi)溫度報(bào)警燈
else //溫度值小于預(yù)設(shè)值時(shí)
speaker=1;
Led_Yellow=1; //關(guān)閉報(bào)警燈
if(yanwu>=yushe_yanwu+20) //光照值大于等于預(yù)設(shè)值時(shí)
cg = 0;
c1_k = 1;
c2_k = 0;
delay_ms(50);
c1_k = 0;
c2_k = 0;
if(yanwu<=yushe_yanwu-20) //光照值大于等于預(yù)設(shè)值時(shí)
cg = 0;
c1_k = 0;
c2_k = 1;
delay_ms(50);
c1_k = 0;
c2_k = 0;
void main (void)
u8 key;
cg = 1;
c1_k = 0;
c2_k = 0;
speaker = 1;
Led_Yellow = 1;
wendu=check_wendu(); //初始化時(shí)調(diào)用溫度讀取函數(shù) 防止開(kāi)機(jī)85°C
time_init();
Init1602(); //調(diào)用初始化顯示函數(shù)
while (1) //主循環(huán)
key=Key_Scan(); //按鍵掃描
if(key==KEY_SET)
Mode++;
switch(Mode) //判斷模式的值
case 0: //監(jiān)控模式
times++; //計(jì)數(shù)
if( times >= 500 ) //大于500,清零
times = 0;
if( times <= 300 ) //小于300,顯示光強(qiáng)、溫度信息
if( times == 1 )
LCD_Write_String(0,0,"SET T:00 L:000"); //開(kāi)機(jī)界面
LCD_Write_String(1,0,"NOW T:00.0 L:000");
Display_1602(yushe_wendu,yushe_yanwu,wendu,yanwu); //顯示預(yù)設(shè)溫度,預(yù)設(shè)光照,溫度值,光照值
break;
else //大于300,顯示天然氣信息
if( times == 301 )
LCD_Write_String(0,0,"SET yanwu:00 "); //開(kāi)機(jī)界面
LCD_Write_String(1,0,"NOW yanwu:00.0 ");
// Display_1602(yushe_wendu,yushe_yanwu,wendu,yanwu); //顯示預(yù)設(shè)溫度,預(yù)設(shè)光照,溫度值,光照值
LCD_Write_Char(0,10,yushe_tianranqi,3) ;//顯示預(yù)設(shè)光照
LCD_Write_Char(1,10,tianranqi,3) ;//顯示預(yù)設(shè)光照
write_com( 0x80+0x40+10);
write_data( tianranqi/100+0x30);
write_data( tianranqi%100/10+0x30);
write_data( tianranqi%10+0x30);
write_data( ' ');
break;
case 1://預(yù)設(shè)溫度模式
SelectPosition(0,5) ; //指定位置
write_com(0x0d); //陰影閃爍
if(key==KEY_ADD) //加鍵按下
yushe_wendu++; //預(yù)設(shè)溫度值(閥值)加1
if(yushe_wendu>=99) //當(dāng)閥值加到大于等于99時(shí)
yushe_wendu=99; //閥值固定為99
LCD_Write_Char(0,6,yushe_wendu,2) ;//顯示預(yù)設(shè)溫度
if(key==KEY_MINUS) //減鍵按下
if(yushe_wendu<=1) //當(dāng)溫度上限值減小到1時(shí)
yushe_wendu=1; //固定為1
yushe_wendu--; //預(yù)設(shè)溫度值減一,最小為0
break; //執(zhí)行后跳出switch
case 2: //預(yù)設(shè)光照模式
SelectPosition(0,12) ; //指定位置
write_com(0x0d); //打開(kāi)顯示 無(wú)光標(biāo) 光標(biāo)閃爍
if(yushe_yanwu>=255) //當(dāng)閥值加到大于等于255時(shí)
yushe_yanwu=254; //閥值固定為254
yushe_yanwu++; //預(yù)設(shè)光照值(閥值)加1,最大為255
LCD_Write_Char(0,13,yushe_yanwu,3) ;//顯示預(yù)設(shè)光照
if(yushe_yanwu<=1) //當(dāng)光照上限值減小到1時(shí)
yushe_yanwu=1; //固定為1
yushe_yanwu--; //預(yù)設(shè)溫度值減一,最小為0
break;
case 3: //預(yù)設(shè)天然氣設(shè)置
if( shezhi_flag == 0 )
LCD_Write_String(0,0,"SET yanwu: "); //界面
LCD_Write_String(1,0,"NOW yanwu: ");
shezhi_flag = 1;
LCD_Write_Char(0,10,yushe_tianranqi,3) ;//顯示天然氣設(shè)置
LCD_Write_Char(1,10,tianranqi,3) ;//顯示預(yù)設(shè)天然氣設(shè)置
write_data( ' ');
SelectPosition(0,9) ; //指定位置
if(yushe_tianranqi>=255) //當(dāng)閥值加到大于等于255時(shí)
yushe_tianranqi=254; //閥值固定為254
yushe_tianranqi++; //預(yù)設(shè)天然氣設(shè)置(閥值)加1,最大為255
LCD_Write_Char(0,10,yushe_tianranqi,3) ;//顯示預(yù)設(shè)天然氣設(shè)置
if(yushe_tianranqi<=1) //當(dāng)天然氣設(shè)置上限值減小到1時(shí)
yushe_tianranqi=1; //固定為1
yushe_tianranqi--; //預(yù)設(shè)溫度值減一,最小為0
break;
default :
Mode=0; //恢復(fù)正常模式
shezhi_flag = 0;
times = 0;
break;
