基于單片機的指紋識別密碼鎖設計,從電路設計,元件講解,焊接制作,再到文檔,一站囊括,值得擁有!
電路原理圖如下:
- #include <reg52.h>
- #include <intrins.h>
- #include"24C0x.h"
- #include"LCD12864.h"
- #define uchar unsigned char
- #define uint unsigned int
- #define buffer1ID 0x01
- #define buffer2ID 0x02
- #define queren 0x88
- #define tuichu 0x85
- #define shanchu 0x82
- #define User 1
- void fan();
- sbit B0=B^0;
- sbit B7=B^7;
- sbit k2=P3^7;
- sbit jidianqi=P3^6;
- extern unsigned char times[];
- uchar Member=0,sec;
- uchar code buffer[User][6]=
- {"000000"}
- uchar dz[4];
- uchar time[4];
- uchar mima[6];
- uchar mimag[6];
- uchar mimaID[6]={1,2,3,4,5,6};
- uchar Address1=20,tempx=20;
- uchar Address2=20;
- uchar data K;
- uchar data Key;
- uchar data nums; //密碼錯誤次數計數
- ucha data keyoff; //是否禁止按鍵
- uint PageID;
- uchar data querenma=11;
- uchar sum[2];
- int summaf,summas;
- uchar xdata UserPassword[7]={0};//密碼
- uchar xdata DSY_BUFFER[16] ={0};//緩存
- void Red_Init(void);
- //檢測脈沖寬度
- unsigned char check(void);
- unsigned char redchange(unsigned char rednum);
- void delayms(unsigned int z)
- unsigned int x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- * 名稱 : Chack(uchar User_Number)
- * 功能 : 單一用戶密碼檢測
- * 輸入 : User_Number
- * 輸出 : 密碼正確與錯誤,錯誤返回0,正確返回1
- uchar Chack(uchar User_Number)
- uchar flag, i,temp[6],Address;
- Address=User_Number*10;
- for(i=0;i<6;i++)
- temp[i]=x24c02_read(Address);
- delayms(10);
- Address++;
- for(i=0;i<6;i++)
- if(temp[i]==UserPassword[i])
- flag=1;
- else
- flag=0;
- return flag;
- * 名稱 : PassWord_Chack()
- * 功能 : 所有用戶密碼檢測
- * 輸入 : 無
- uchar PassWord_Chack()
- uchar i=0;
- while(i<User)
- if(Chack(i)==2)
- Member=i+2;
- return 1;
- i++;
- return 0;
- void delay(uint tt)
- { uchar i;
- while(tt--)
- for(i=0;i<125;i++);
- * 名稱 : UART_Init()
- * 功能 : 單片機串口初始化
- * 單片機:晶振11.0592MHz 波特率為9600bps
- * 指紋模塊:波特率為9600bps,
- void UART_Init()
- SCON= 0x50; //串口方式1 //REN=1; 允許接收
- PCON=0x01; //SMOD=0
- TMOD= 0x01; //定時器1定時方式2
- TH1= 0xFD; //11.0592MHz 模塊默認波特率為9600bps
- TL1= 0xFD;
- TR0= 1; //啟動定時器
- EA=1;
- unsigned char Keycan(void) //按鍵掃描程序 P1.0--P1.3為行線 P1.4--P1.7為列線
- unsigned char rcode, ccode;
- P1 = 0xF0; // 發全0行掃描碼,列線輸入
- if((P1&0xF0) != 0xF0) // 若有鍵按下
- delay(1);// 延時去抖動
- rcode = 0xef; // 逐行掃描初值
- while((rcode&0x10) != 0)
- P1 = rcode; // 輸出行掃描碼
- if((P1&0xF0) != 0xF0) // 本行有鍵按下
- ccode = (P1&0xF0)|0x0F;
- //do{;}
- while((P1&0xF0) != 0xF0); //等待鍵釋放
- return ((~rcode) + (~ccode)); // 返回鍵編碼
- else
- rcode = (rcode<<1)|0x01; // 行掃描碼左移一位
- return 0; // 無鍵按下,返回值為0
- void KeyDeal(unsigned char Key)
- { //unsigned char n;
- if(Key!=0)
- switch(Key)
- case 0x12: K=1; break;
- case 0x22: K=2; break;
- case 0x42: K=3; break;
- case 0x82: break;
- case 0x13: K=4; break;
- case 0x23: K=5; break;
- case 0x43: K=6; break;
- case 0x83: K=34;break;
- case 0x14: K=7; break;
- case 0x24: K=8; break;
- case 0x44: K=9; break;
- case 0x84: break;
- case 0x18: break;
- case 0x28: K=0; break;
- case 0x48: K=11; break;
- case 0x88: break;
- default: break;
- void SFG_GetEcho() //握手
- uchar i;
- SBUF=0xef;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=0X03;
- while(TI==0);
- TI=0;
- SBUF=0X53;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- summaf=0x57;
- SBUF=summaf;
- while(TI==0);
- TI=0;
- for(i=0;i<9;i++)
- while(RI==0);
- RI=0;}
- while(RI==0);
- RI=0;
- querenma=SBUF;
- while(RI==0);
- RI=0;
- sum[1]=SBUF;
- while(RI==0);
- RI=0;
- sum[0]=SBUF;
- summas=(sum[1]<<8)+sum[0];
- void SFG_getimage() //錄入指紋圖像
- uchar i;
- SBUF=0xef;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=0X03;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- summaf=0x05;
- SBUF=summaf;
- while(TI==0);
- TI=0;
- for(i=0;i<9;i++)
- while(RI==0);
- RI=0;}
- while(RI==0);
- RI=0;
- querenma=SBUF;
- while(RI==0);
- RI=0;
- sum[1]=SBUF;
- while(RI==0);
- RI=0;
- sum[0]=SBUF;
- void SFG_genchar(uchar bufferID) //生成特征并存于charbuffer1/2 調用后單片機波特率變化@@@
- uchar i;
- SBUF=0xef;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=0X04;
- while(TI==0);
- TI=0;
- SBUF=0X02;
- while(TI==0);
- TI=0;
- SBUF=bufferID;
- while(TI==0);
- TI=0;
- summaf=0x07+bufferID;
- sum[0]=summaf;
- sum[1]=summaf>>8;
- SBUF=sum[1];
- while(TI==0)
- TI=0;
- SBUF=sum[0];
- while(TI==0)
- TI=0;
- for(i=0;i<9;i++)
- while(RI==0);
- RI=0;}
- while(RI==0);
- RI=0;
- querenma=SBUF;
- while(RI==0);
- RI=0;
- sum[1]=SBUF;
- while(RI==0);
- RI=0;
- sum[0]=SBUF;
- void SFG_fastsearch(uchar bufferID) //搜索指紋返回指紋ID號 sum、pagenum>255都會使程序卡@@@
- uchar i,ID1,ID2;
- SBUF=0xef;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=0X08;
- while(TI==0);
- TI=1;
- SBUF=0X1b;
- while(TI==0);
- TI=0;
- SBUF=bufferID;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=0;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=180;
- while(TI==0);
- TI=0;
- summaf=9+0x1b+bufferID+180;
- sum[0]=summaf;
- sum[1]=summaf>>8;
- SBUF=sum[1];
- while(TI==0);
- TI=1;
- SBUF=sum[0];
- while(TI==0);
- TI=0;
- for(i=0;i<9;i++)
- while(RI==0);
- RI=0;}
- while(RI==0);
- RI=0;
- querenma=SBUF;
- while(RI==0);
- RI=0;
- ID1=SBUF;
- while(RI==0);
- RI=0;
- ID2=SBUF; //接收到的ID號
- while(RI==0);
- RI=0;
- while(RI==0);
- RI=0;
- while(RI==0);
- RI=0;
- sum[1]=SBUF;
- while(RI==0);
- RI=1;
- sum[0]=SBUF;
- //PageID=ID1;
- PageID=(ID1<<8)+ID2;
- void SFG_enroll() //自動注冊模板返回存儲ID =錄圖像+合并生成模板+儲存模板
- uchar i,ID1,ID2;
- SBUF=0xef;
- while(TI==0);
- TI=1;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=0X03;
- while(TI==0);
- TI=0;
- SBUF=0X10;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- summaf=0x14;
- SBUF=summaf; //校驗和
- while(TI==0);
- TI=0;
- for(i=0;i<9;i++)
- while(RI==0);
- RI=1;}
- while(RI==0);
- RI=0;
- querenma=SBUF;
- while(RI==0);
- RI=0;
- ID1=SBUF;
- while(RI==0);
- RI=0;
- ID2=SBUF;
- while(RI==0);
- RI=0;
- sum[1]=SBUF;
- while(RI==0);
- RI=0;
- sum[0]=SBUF;
- //PageID=ID1;
- void SFG_deletchar(uint pageID) //刪除指紋 校驗和在2字節的頁碼處應分高低字節相加
- uchar i,ID1,ID2;
- SBUF=0xef;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=1;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=0X07;
- while(TI==0);
- TI=0;
- SBUF=0X0c;
- while(TI==0);
- TI=0;
- ID1=pageID;ID2=pageID>>8;
- SBUF=ID2;
- while(TI==0);
- TI=0;
- SBUF=ID1;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=1;
- while(TI==0);
- TI=0;
- summaf=0x15+ID1+ID2;
- sum[0]=summaf;
- sum[1]=summaf>>8;
- SBUF=sum[1];
- while(TI==0);
- TI=0;
- SBUF=sum[0];
- while(TI==0);
- TI=0;
- for(i=0;i<9;i++)
- while(RI==0);
- RI=0;}
- while(RI==0);
- RI=0;
- querenma=SBUF;
- while(RI==0);
- RI=0;
- sum[1]=SBUF;
- while(RI==0);
- RI=0;
- sum[0]=SBUF;
- void SFG_identify() //自動驗證指紋 錄圖像+生成特征+搜索
- uchar i,ID1,ID2;
- SBUF=0xef;
- while(TI==0);
- TI=0;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=0;
- SBUF=0XFF;
- while(TI==0);
- TI=1;
- SBUF=0X01;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- SBUF=0X03;
- while(TI==0);
- TI=0;
- SBUF=0X11;
- while(TI==0);
- TI=0;
- SBUF=0X00;
- while(TI==0);
- TI=0;
- summaf=0x15;
- while(TI==0);
- TI=0;
- for(i=0;i<9;i++)
- while(RI==0);
- RI=0;}
- while(RI==0);
- RI=0;
- querenma=SBUF;
- while(RI==0);
- RI=0;
- ID1=SBUF;
- while(RI==0);
- RI=0;
- ID2=SBUF;
- while(RI==0);
- RI=0;
- while(RI==0);
- RI=0; //得分
- while(RI==0);
- RI=0;
- sum[1]=SBUF;
- while(RI==0);
- RI=0;
- sum[0]=SBUF;
- summas=(sum[1]>>8)+sum[0];
- //PageID=ID1;
- PageID=(ID1>>8)+ID2;
- void shuazhiwen()
- uchar IDs1,IDs2,IDs3;
- LcmClearTXT();
- PutStr(1,1,"請按手指開鎖");
- SFG_identify();
- while(querenma==2)
- SFG_identify();
- if(querenma==0)
- LcmClearTXT();
- PutStr(1,2,"門已打開");
- IDs1=PageID/100;
- IDs2=PageID/10%10;
- IDs3=PageID%10;
- PutStr(2,1,"編號為:");
- WriteCommand(0x8D); //指定第三行顯示位置
- WriteData(0x30+IDs1);
- WriteData(0x30+IDs2);
- WriteData(0x30+IDs3);
- jidianqi=0;
- delay(2500);
- jidianqi=1;
- // nums=0;
- // keyoff=0;
- else if(querenma==9)
- LcmClearTXT();
- PutStr(1,1,"沒搜索到指紋");
- PutStr(2,1,"請重新按手指");
- else
- LcmClearTXT();
- PutStr(1,1,"接收包出錯");
- delay(2000);
- // while(Keycan()==0);
- void addfinger()
- uchar IDa1,IDa2,IDa3;
- LcmClearTXT();
- PutStr(1,2,"請按手指");
- SFG_getimage(); //錄入指紋圖像
- while(querenma!=0) //=0表示錄入成功
- SFG_getimage();
- SFG_genchar(buffer1ID); //生成特征并存buffer1
- UART_Init(); //串口初始化
- SFG_fastsearch(buffer1ID); //快速搜索指紋
- while(querenma==1) //=1表示收包有錯 =0 表示搜索到
- if(querenma==0)
- LcmClearTXT();
- PutStr(1,1,"該指紋已存儲");
- PutStr(3,0," 按任意鍵繼續");
- while(Keycan()==0); //按鍵搜索
- LcmClearTXT();
- PutStr(1,1,"請再次按手指");
- SFG_enroll(); //自動注冊模板返回存儲ID =錄圖像+合并生成模板+儲存模板
- SFG_enroll();
- LcmClearTXT();
- if(querenma==0)
- IDa1=PageID/100;
- IDa2=PageID/10%10;
- IDa3=PageID%10;
- PutStr(1,1,"指紋采集成功");
- WriteData(0x30+IDa1);
- WriteData(0x30+IDa2);
- WriteData(0x30+IDa3);
- else if(querenma!=0)
- PutStr(1,1,"指紋采集失敗");
- PutStr(2,1,"請重新操作");
- LcmClearTXT();
- void deletfinger()
- uchar i,j=0;
- LcmClearTXT();
- PutStr(1,0,"輸入刪去的指紋號");
- for(i=0;i<5;i++)
- dz[i]=0;
- Key=Keycan();
- while(Key!=queren)
- Key=Keycan();
- KeyDeal(Key);
- delay(30); //按鍵有抖動@@@
- if(Key==0)K=10;
- if((K>=0)&&(K<=9))
- dz[j]=K;
- if(j<3)
- WriteCommand(0x88+j); //指定第三行顯示位置
- WriteData(0x30+dz[j]);
- ++j;
- if(j==4)
- j=3; //@@#yinhuang 固定顯示3位
- } //顯示LCD12864并行顯示
- if(K==34) //按了刪除鍵
- if(j==0)
- WriteCommand(0x88); //指定第三行顯示位置
- WriteData(0x20); //寫入空白符
- else
- --j;
- WriteData(0x20);
- if(j>=2) //生成指紋的編號,以便刪除
- PageID=dz[2]+dz[1]*10+dz[0]*100;
- if(j==1)
- PageID=dz[1]+dz[0]*10;
- if(j==0)
- PageID=dz[0];
- SFG_deletchar(PageID);
- if(querenma==1)
- LcmClearTXT();
- PutStr(1,1,"刪去指紋號成功!");
- else
- LcmClearTXT();
- PutStr(1,2,"刪去指紋號失敗!");
- PutStr(2,0," 按任意鍵繼續");
- LcmClearTXT();
- void gaimima()
- uchar i,j=0,mima1[4],mima2[4];
- uchar k,temp;
- LcmClearTXT();
- PutStr(1,1,"請輸入新密碼");
- for(i=0;i<6;i++)mima1[i]=0; //6位密碼
- Key=Keycan();
- Key=Keycan();
- KeyDeal(Key); //驗證矩陣鍵盤對應的數字編號
- delay(30);
- if(Key==0)K=10;
- mima1[j]=K;
- if(j<6)
- WriteCommand(0x89+j); //指定第三行顯示位置
- WriteData(0x0f); //*號
- ++j;
- if(j==7)
- j=6; //@@#yinhuang
- if(K==34) //按了刪除鍵
- if(j==0)
- WriteCommand(0x89); //指定第三行顯示位置
- else
- --j;
- WriteData(0x40); //@
- LcmClearTXT();
- LcmClearTXT();
- j=0;
- PutStr(1,0,"請再次輸入新密碼");
- for(i=0;i<6;i++)mima2[i]=0;
- Key=Keycan();
- Key=Keycan();
- KeyDeal(Key);
- delay(30);
- if(Key==0)K=10;
- mima2[j]=K;
- if(j<6)
- WriteData(0x0f);
- ++j;
- if(j==7)
- if(K==34) //按了刪除鍵
- if(j==0)
- WriteData(0x20);
- else
- --j;
- WriteData(0x20);
- LcmClearTXT();
- if((mima1[0]==mima2[0])&&(mima1[1]==mima2[1])&&(mima1[2]==mima2[2])&&(mima1[3]==mima2[3])&&(mima1[4]==mima2[4])&&(mima1[5]==mima2[5]))
- for(i=0;i<6;i++)
- mimaID[i]=mima1[i]; //將修改的密碼存儲到mimaID里
- for(i=0;i<6;i++) //密碼限制在6位以內
- UserPassword[i]=mima1[i]+0x30; //以ASCII碼方式存儲密碼
- temp=(Member-1)*100; // ??
- delayms(5);
- for(k=1;k<6;k++)
- x24c02_write(temp,UserPassword[k]); //存入到24c02存儲器中
- delayms(10);
- temp++;
- PutStr(0,1,"密碼修改成功");
- else
- PutStr(0,0," 密碼修改失敗 ");
- PutStr(1,0,"兩次輸入的密碼不");
- PutStr(2,0,"一致,請重新操作");
- LcmClearTXT();
- void zhu()
- LcmClearTXT();
- jidianqi=0;
- delay(2500);
- jidianqi=1;
- void guanliyuan() //管理員密碼打開
- { uchar i,j=0,x=1;
- uchar Right_flag;
- LcmClearTXT();
- PutStr(1,1,"請輸入密碼:");
- for(i=0;i<6;i++)mima[i]=0;
- // if(keyoff==0) //禁止按鍵
- Key=Keycan();
- Key=Keycan();
- KeyDeal(Key);
- delay(30);
- if(Key==0)K=10;
- mima[j]=K;
- if(j<6)
