查看: 1948|回復: 1
基于單片機控制和L298驅動的步進電機,在四相八拍的工作方式下,LED顯示燈不亮怎么...
#include<reg51.h>
#define unit unsigned int
    sbit zz=p3^2;
  sbit fz=p3^3;
  sbit jias=p3^4;
  sbit jians=p3^5;
  sbit stop=p3^6;
  sbit ledzz=p1^4;
  sbit ledfz=p1^5;
  sbit ledjias=p1^6;
  sbit ledjains=p1^7;
  sbit F1=P2^0;
  sbit F2=p2^1;
  sbit F3=P2^2;
  sbit F4=P2^3;
  unsigned char code FFW[8]={0xfe,0xfc,0xfd,0xf9,0xfb,0xf3,0xf7,0xf6};
    unsigned char code FFZ[8]={0xf6,0xf7,0xf3,0xfb,0xf9,0xfd,0xfc,0xfe};
    void motor_ffw();
    unit rate,K1,K2;
    void delay1(uint nms)
        unit i,j;
        for(i=nms;i>0;i--)
        for(j=110;j>0;j--);
    void delay()
        unsigned int k,t;
        t=rate;
        while(t--)
            for(k=0;k<50;k++);
    void motor_ffw()
        unsigned char i;
        if(K1==1)
            for(i=0;i<8;i++)
            P2=FFW[i]&0x1f;
            delay();
        if(K2==1)
            for(i=0;i<8;i++)
            P2=FFZ[i]&0x1f;
            delay();
    void key()
        if(zz==0)
            delay1(10);
            if(zz==0)
            {K1=1;K2=0;ledzz=0;ledfz=1;ledjias=1;ledjians=1;}
        if(fz==0)
            delay1(10);
            if(fz==0)
            {K2=1;K1=0;ledzz=1;ledfz=0;ledjias=1;ledjians=1;}
        if(jias==0)
            delay1(10);
            if(jias==0)
            {rate=rate-10;ledzz=1;ledfz=1;ledjias=0;ledjians=1;if(rate==0)rate=10;}
        if(jians==0)
            delay1(10);
            if(jians==0)
            {rate=rate+10;ledzz=1;ledfz=1;ledjias=1;ledjians=0;}
        if(stop==0)
            delay1(10);
            id(stop==0)
            {P2=0Xff;K1=0;K2=0;}
        rate=100;
            key();
            motor_ffw();
ID:770645 發表于 2020-6-20 15:05 | 只看該作者
有沒有用8088cpu做的
