查看: 3869|回復(fù): 0
使用Arduino控制兩個數(shù)碼管,實(shí)現(xiàn)60秒倒計(jì)時
ID:765067 發(fā)表于 2020-5-30 17:29 | 顯示全部樓層 |閱讀模式
void setup()
{ // put your setup code here, to run once:
                for(int i=2;i <= 17;++i)
                        pinMode(i,OUTPUT);
void loop()
{ // put your main code here, to run repeatedly:
        int seg[10][8]={{2,3,4,5,6,7,-1},{3,4,-1},{2,3,5,6,8,-1},{2,3,4,5,8,-1},{3,4,7,8,-1},
                                                        {2,4,5,7,8,-1},{2,4,5,6,7,8,-1},{2,3,4,-1},{2,3,4,5,6,7,8,-1},{2,3,4,5,7,8,-1}};
        for(int i = 59;i >= 0;--i)
                for(int j=0;seg[i/10][j] != -1;++j)
                        digitalWrite(seg[i/10][j],HIGH);
                for(int j=0;seg[i%10][j] != -1;++j)
                        digitalWrite(seg[i%10][j]+8,HIGH);
                delay(1000);
                        digitalWrite(seg[i/10][j],LOW);
                        digitalWrite(seg[i%10][j]+8,LOW);
