查看: 2857|回復: 2
keilc51自帶的intrins.h函數編譯報錯
ID:764368 發表于 2020-5-29 16:23 | 顯示全部樓層 |閱讀模式
INTRINS.H
Intrinsic functions for C51.
Copyright (c) 1988-2010 Keil Elektronik GmbH and ARM Germany GmbH
All rights reserved.
#ifndef __INTRINS_H__
#define __INTRINS_H__
#pragma SAVE
#if defined (__CX2__)
#pragma FUNCTIONS(STATIC)
/* intrinsic functions are reentrant, but need static attribute */
#endif
extern void          _nop_     (void);
extern bit           _testbit_ (bit);
extern unsigned char _cror_    (unsigned char, unsigned char);
extern unsigned int  _iror_    (unsigned int,  unsigned char);
extern unsigned long _lror_    (unsigned long, unsigned char);
extern unsigned char _crol_    (unsigned char, unsigned char);
extern unsigned int  _irol_    (unsigned int,  unsigned char);
extern unsigned long _lrol_    (unsigned long, unsigned char);
extern unsigned char _chkfloat_(float);
extern int           abs       (int);
extern void          _illop_   (void);
#endif
#if !defined (__CX2__)
extern void          _push_    (unsigned char _sfr);
extern void          _pop_     (unsigned char _sfr);
#endif
#pragma RESTORE
#endif
ID:660091 發表于 2020-5-30 10:22 | 顯示全部樓層
就算是自帶函數報錯,錯誤也是在你編寫的函數中找,因為自帶函數不可能出錯。
你這個錯誤是意思是少了;你看哪里缺了分號
ID:589491 發表于 2021-3-22 17:18 | 顯示全部樓層
錯誤的分號
