查看: 2112|回復: 1
單片機實驗代碼 數(shù)字電壓表
ID:763828 發(fā)表于 2020-5-28 22:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#define uint  unsigned int
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
                                                //0-9的碼表
uint temp;
sbit START = P2^4;
sbit ALE = P2^7;
sbit OE = P2^6;
sbit EOC = P3^3;
sbit ADD_A = P2^2;
sbit Q1 = P3^4;
sbit Q2 = P3^5;
sbit Q3 = P3^6;
sbit Q4 = P3^7;
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
void ADC0809_init()
        ALE = 0;
        START = 0;
        ADD_A = 0;
        ALE = 1;
        START = 1;
void display(uint num)
    uint qian,bai,shi,ge;
        qian = num/1000;
        bai = num%1000/100;
        shi = num%100/10;
        ge = num%10;
        Q4 = 1;
        Q1 = 0;
        P1 = table[qian] | 0x80;
        delay(5);
    Q1 = 1;
        Q2 = 0;
        P1 = table[bai];
        delay(5);
    Q2 = 1;
        Q3 = 0;
        P1 = table[shi];
        delay(5);
    Q3 = 1;
        Q4 = 0;
        P1 = table[ge];
        delay(5);
           ADC0809_init();
         EA = 1;
         EX1 = 1;
         IT1 = 1;
         while(1);
void ADC_int()  interrupt 2
    display(temp);
        ALE = 0;
        START = 0;
        temp = P0/256.0*5*1000;
        ALE = 1;
        START = 1;
        EA = 1;
ID:1 發(fā)表于 2020-6-1 01:26 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
