只需一步,快速開(kāi)始
查看: 3596|回復(fù): 0
基于AT89c51的16×16點(diǎn)陣設(shè)計(jì)原理圖+程序
ID:525983 發(fā)表于 2020-5-28 02:35 | 顯示全部樓層 |閱讀模式
使用四塊8×8的點(diǎn)陣拼成16×16的點(diǎn)陣,用了兩個(gè)譯碼器,只設(shè)置了三個(gè)字(改字可以用字模轉(zhuǎn)換器)按鍵控制左移、右移、暫停、啟動(dòng)。
電路原理圖如下:
單片機(jī)源程序如下:
  1. /************************************************
  2. 16x16點(diǎn)陣漢字滾動(dòng)顯示
  3. ************************************************/
  4. #include <reg51.h>
  5. #define uchar unsigned char
  6. #define uint  unsigned int
  7. sbit LA=P1^0;                                    //138譯碼器地址選擇引腳
  8. sbit LB=P1^1;
  9. sbit LC=P1^2;
  10. sbit LD=P1^3;
  11. sbit k1=P3^6;                                    //啟動(dòng)或暫停按鍵
  12. sbit k2=P3^7;                                    //改變方向按鍵
  13. bit  fx=0;                                       //滾動(dòng)方向
  14. uint index=0;                                    //列掃描索引
  15. uchar code hztab[]={
  16.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //空格
  17.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  18.
  19.     0x08,0x04,0x10,0x04,0x20,0x24,0x40,0x24,0xfc,0x24,0xa2,0x24,0x22,0xfd,0x22,0x26, //老
  20.     0x42,0x24,0x42,0x2c,0x42,0x14,0x82,0x24,0x1e,0x44,0x00,0x04,0x00,0x04,0x00,0x00,
  21.
  22.     0x00,0x00,0xe1,0x3f,0x02,0x00,0x0c,0x00,0xf0,0xff,0x00,0x00,0x00,0x40,0xf8,0x47, //師
  23.     0x00,0x44,0x00,0x44,0xff,0x7f,0x10,0x44,0x08,0x44,0xf0,0x47,0x00,0x40,0x00,0x00,
  24.
  25.     0x02,0x08,0x44,0x08,0xa8,0x0f,0x10,0xf8,0x68,0x08,0x86,0x0f,0x00,0x00,0x00,0x01, //好
  26.     0x02,0x41,0x01,0x41,0xfe,0x47,0x00,0x49,0x00,0x51,0x00,0x61,0x00,0x01,0x00,0x00,
  27.
  28.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //空格
  29.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  30. };
  31. //===================函數(shù)聲明====================
  32. void T0_Init();                                  //定時(shí)器0初始化
  33. void delayus(uint us);                           //延時(shí)函數(shù)
  34. void keyscan();                                  //按鍵掃描函數(shù)
  35. //====================主程序=====================
  36. void main()
  37. {
  38.     uchar i,j;
  39.     T0_Init();                                   //定時(shí)器0初始化
  40.     while(1)
  41.     {
  42.         keyscan();                               //按鍵掃描
  43.         for(i=0;i<16;i++)                        //點(diǎn)陣16列
  44.         {
  45.             LA=i&0x01;                           //用級(jí)聯(lián)138進(jìn)行列選
  46.             LB=i&0x02;
  47.             LC=i&0x04;
  48.             LD=i&0x08;
  49.             j=index+i;                           //定位當(dāng)前要顯示的列
  50.             P0=hztab[j*2+1];                     //發(fā)送點(diǎn)陣數(shù)據(jù)
  51.             P2=hztab[j*2];                       //共兩個(gè)字節(jié)
  52.             delayus(100);                        //延時(shí)
  53.             P0=P2=0x00;                          //消影
  54.         }
  55.         delayus(100);                            //延時(shí)
  56.     }
  57. }
  58. //=================定時(shí)器0初始化=================
  59. void T0_Init()
  60. {
  61.     TMOD=0x01;                                   //定時(shí)器0,工作方式1
  62.     TH0=(65536-10000)/256;                       //定數(shù)器初值
  63.     TL0=(65536-10000)%256;                       //10ms定時(shí)
  64.     ET0=1;                                       //打開(kāi)定時(shí)器0中斷允許
  65.     EA=1;                                        //打開(kāi)總中斷允許
  66.     TR0=0;                                       //暫不啟動(dòng)定時(shí)器0
  67. }
  68. //===============定時(shí)中斷0服務(wù)程序===============
  69. void timer0() interrupt 1
  70. {
  71.     static uchar tick=0;                         //嘀嗒計(jì)時(shí)
  72.     TH0=(65536-10000)/256;                       //重裝裝初值
  73.     TL0=(65536-10000)%256;                       //10ms定時(shí)
  74.     tick++;                                      //計(jì)數(shù)
  75.     if(tick==5)                                  //5次
  76.     {
  77.         tick=0;                                  //清0
  78.         if(fx==0)index=(index+1)%64;             //若方向?yàn)樽笠疲瑒t掃描線加1
  79.         else index=(index-1+64)%64;              //否則掃描線減1
  80.     }
  81. }
  82. //===================延時(shí)函數(shù)====================
  83. void delayus(uint us)
  84. {
  85.     while(us--);
  86. }
  87. //=================按鍵掃描函數(shù)==================
  88. void keyscan()
  89. {
  90.     if(k1==0)                                    //檢測(cè)k1是否按下
  91.     {
  92.         delayus(100);                            //延時(shí)消抖
  93.         if(k1==0)                                //確認(rèn)k1被按下
  94.         {
  95.             TR0=~TR0;                            //定時(shí)器啟停反轉(zhuǎn)
  96.             while(k1==0);                        //等待按鍵松開(kāi)
  97.         }
  98.     }
  99.     if(k2==0)                                    //檢測(cè)k2是否按下
  100.     {
  101.         delayus(100);                            //延時(shí)消抖
  102.         if(k2==0)                                //確認(rèn)k2被按下
  103.         {
  104.             fx=~fx;                              //方向反轉(zhuǎn)
  105.             while(k2==0);                        //等待按鍵松開(kāi)
  106.         }
  107.     }
  108. }
16×16點(diǎn)陣.zip (22.41 KB, 下載次數(shù): 59)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
