查看: 2524|回復: 0
關于C語言重復定義的問題
ID:70069 發表于 2020-5-26 23:09 | 顯示全部樓層 |閱讀模式
.\Objects\TEST.axf: Error: L6200E: Symbol fs multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol fileinfo multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol dir multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol FILE_TYPE_TBL multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol file multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol ftemp multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol br multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol bw multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol fatbuf multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol char_upper multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol exf_getfree multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol exfuns_init multiply defined (by exfuns.o and user.o).
.\Objects\TEST.axf: Error: L6200E: Symbol f_typetell multiply defined (by exfuns.o and user.o).
Not enough information to list image symbols.
上面是錯誤信息。
說在exfuns 和 user里面重復定義了。但是沒有在user里面定義,只是包含了exfuns的頭文件這是怎么回事呢?
exfuns.c內容
#include "string.h"
#include "exfuns.h"
#include "fattester.h"
#include "malloc.h"
#include "usart.h"
//FATFS 擴展代碼
//STM32F4工程模板-庫函數版本
#define FILE_MAX_TYPE_NUM                7        //最多FILE_MAX_TYPE_NUM個大類
#define FILE_MAX_SUBT_NUM                4        //最多FILE_MAX_SUBT_NUM個小類
//文件類型列表
u8*const FILE_TYPE_TBL[FILE_MAX_TYPE_NUM][FILE_MAX_SUBT_NUM]=
{"BIN"},                        //BIN文件
{"LRC"},                        //LRC文件
{"NES"},                        //NES文件
{"TXT","C","H"},        //文本文件
{"WAV","MP3","APE","FLAC"},//支持的音樂文件
{"BMP","JPG","JPEG","GIF"},//圖片文件
{"AVI"},                        //視頻文件
///////////////////////////////公共文件區,使用malloc的時候////////////////////////////////////////////
FATFS *fs[_VOLUMES];//邏輯磁盤工作區.
FIL *file;                          //文件1
FIL *ftemp;                          //文件2.
UINT br,bw;                        //讀寫變量
FILINFO fileinfo;        //文件信息
DIR dir;                          //目錄
u8 *fatbuf;                        //SD卡數據緩存區
//為exfuns申請內存
//返回值:0,成功
//1,失敗
u8 exfuns_init(void)
        u8 i;
        for(i=0;i<_VOLUMES;i++)
                fs[ i]=(FATFS*)mymalloc(SRAMIN,sizeof(FATFS));        //為磁盤i工作區申請內存
                if(!fs[ i])break;
        file=(FIL*)mymalloc(SRAMIN,sizeof(FIL));                //為file申請內存
        ftemp=(FIL*)mymalloc(SRAMIN,sizeof(FIL));                //為ftemp申請內存
        fatbuf=(u8*)mymalloc(SRAMIN,512);                                //為fatbuf申請內存
        if(i==_VOLUMES&&file&&ftemp&&fatbuf)return 0;  //申請有一個失敗,即失敗.
        else return 1;
//將小寫字母轉為大寫字母,如果是數字,則保持不變.
u8 char_upper(u8 c)
        if(c<'A')return c;//數字,保持不變.
        if(c>='a')return c-0x20;//變為大寫.
        else return c;//大寫,保持不變
//報告文件的類型
//fname:文件名
//返回值:0XFF,表示無法識別的文件類型編號.
//                 其他,高四位表示所屬大類,低四位表示所屬小類.
u8 f_typetell(u8 *fname)
        u8 tbuf[5];
        u8 *attr='\0';//后綴名
        u8 i=0,j;
        while(i<250)
                i++;
                if(*fname=='\0')break;//偏移到了最后了.
                fname++;
        if(i==250)return 0XFF;//錯誤的字符串.
         for(i=0;i<5;i++)//得到后綴名
                fname--;
                if(*fname=='.')
                        fname++;
                        attr=fname;
                        break;
        strcpy((char *)tbuf,(const char*)attr);//copy
         for(i=0;i<4;i++)tbuf[ i]=char_upper(tbuf[ i]);//全部變為大寫
        for(i=0;i<FILE_MAX_TYPE_NUM;i++)        //大類對比
                for(j=0;j<FILE_MAX_SUBT_NUM;j++)//子類對比
                        if(*FILE_TYPE_TBL[ i][j]==0)break;//此組已經沒有可對比的成員了.
                        if(strcmp((const char *)FILE_TYPE_TBL[ i][j],(const char *)tbuf)==0)//找到了
                                return (i<<4)|j;
        return 0XFF;//沒找到
//得到磁盤剩余容量
//drv:磁盤編號("0:"/"1:")
//total:總容量         (單位KB)
//free:剩余容量         (單位KB)
//返回值:0,正常.其他,錯誤代碼
u8 exf_getfree(u8 *drv,u32 *total,u32 *free)
        FATFS *fs1;
        u8 res;
    u32 fre_clust=0, fre_sect=0, tot_sect=0;
    //得到磁盤信息及空閑簇數量
    res =(u32)f_getfree((const TCHAR*)drv, (DWORD*)&fre_clust, &fs1);
    if(res==0)
            tot_sect=(fs1->n_fatent-2)*fs1->csize;        //得到總扇區數
            fre_sect=fre_clust*fs1->csize;                        //得到空閑扇區數
#if _MAX_SS!=512        //扇區大小不是512字節,則轉換為512字節
                tot_sect*=fs1->ssize/512;
                fre_sect*=fs1->ssize/512;
#endif
                *total=tot_sect>>1;        //單位為KB
                *free=fre_sect>>1;        //單位為KB
        return res;
[ i]
[ i][ i][ i][ i][ i][ i]/**********************************************************************************************/
exfuns.h里的內容
[ i]
#ifndef _EXFUNS_H
#define _EXFUNS_H
#include <stm32f4xx.h>
#include "ff.h"
//FATFS 擴展代碼
//STM32F4工程模板-庫函數版本
//淘寶店鋪:http://mcudev.taobao.com
extern FATFS *fs[_VOLUMES];
extern FIL *file;
extern FIL *ftemp;
extern UINT br,bw;
extern FILINFO fileinfo;
extern DIR dir;
extern u8 *fatbuf;//SD卡數據緩存區
//f_typetell返回的類型定義
//根據表FILE_TYPE_TBL獲得.在exfuns.c里面定義
#define T_BIN                0X00        //bin文件
#define T_LRC                0X10        //lrc文件
#define T_NES                0X20        //nes文件
#define T_TEXT                0X30        //.txt文件
#define T_C                        0X31        //.c文件
#define T_H                        0X32    //.h文件
#define T_WAV                0X40        //WAV文件
#define T_MP3                0X41        //MP3文件
#define T_APE                0X42        //APE文件
#define T_FLAC                0X43        //FLAC文件
#define T_BMP                0X50        //bmp文件
#define T_JPG                0X51        //jpg文件
#define T_JPEG                0X52        //jpeg文件
#define T_GIF                0X53        //gif文件
#define T_AVI                0X60        //avi文件
u8 exfuns_init(void);                                                        //申請內存
u8 f_typetell(u8 *fname);                                                //識別文件類型
u8 exf_getfree(u8 *drv,u32 *total,u32 *free);        //得到磁盤總容量和剩余容量
u32 exf_fdsize(u8 *fdname);                                                //得到文件夾大小
#endif
user.c里的內容
[ i]
#include "exfuns.c"
#include "user.h"
#include "lcd.h"
#include "DS1302.h"
#include "gui.h"
#include "usart.h"
#include "DS18B20.h"
#include "sdio_sdcard.h"
#include "ff.h"
#include "malloc.h"
#include "w25qxx.h"
#include "delay.h"
#include "diskio.h"
* @name       :void lcd_time(int x,int y)
* @date       :2020-05-18
* @function   :時間顯示函數
* @parameters :int x x方向坐標
                int y y方向坐標
* @retvalue   :None
{  DS1302_GetTime();
        //        LCD_direction(1);//調整屏方向
                LCD_ShowNum2 (x,y,BLUE,WHITE,TimeData .year ,4,16);
                Show_Str                 (x+=32,y,BLUE,YELLOW,"--",32,1);
                LCD_Show2Num (x+=16,y,BLUE,WHITE,TimeData .month ,2,16);
                Show_Str                 (x+=16,y,BLUE,WHITE,"--",16,0);
                LCD_Show2Num (x+=16,y,BLUE,WHITE,TimeData .day ,2,16);
                Show_Str                 (x+=16,y,BLUE,WHITE,"  ",16,0);
                LCD_Show2Num (x+=8,y,BLUE,WHITE,TimeData .hour ,2,16);
                Show_Str                 (x+=16,y,BLUE,WHITE,":",16,1);
                LCD_Show2Num (x+=8,y,BLUE,WHITE,TimeData .minute ,2,16);
                Show_Str                 (x+=16,y,BLUE,YELLOW,":",16,1);
                LCD_Show2Num (x+=8,y,BLUE,WHITE,TimeData .second ,2,16);
                Show_Str                 (x+=16,y,BLUE,YELLOW," ",16,1);
                LCD_ShowNum2 (x+=8,y,BLUE,WHITE,TimeData .week ,2,16);
* @name       :void usart_ds1302(void)
* @date       :2020-05-18
* @function   :串口調整時間
* @parameters :串口數據發送格式,2020051813140003t以回車結尾
* @retvalue   :None
void usart_ds1302()
{  u8 time_buf[8],time_buf1[8];
         u8 len, i,t,times;
         if(USART_RX_STA&0x8000)//判斷是否有信息發送
                        len=USART_RX_STA&0x3fff;//發送信息的長度
        //printf("\r\n你發送的為:\r\n\r\n");
                        for(t=0;t<len;t++)
                                USART_SendData(USART1, USART_RX_BUF[t]);//接收串口信息并發回
        time_buf[t]=USART_RX_BUF[t];
                                while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待發送結束
                      //下面為數組分拆合并如0x32,0x30分拆并組合為0x20
        for(i=0;i<len/2;)
        time_buf1[ i]=time_buf[i*2]<<4;//取8位中的低4位,如0x32變為0x20,
        time_buf1[ i]=time_buf1[ i]|(time_buf [i*2+1]&0x0f);//將上面取的低4為和這里的低4位合,如0x20和0x01變為0x21
        //(time_buf [i*2+1]&0x0f)此公式為將高4位置0,低4位不變,如0x31變為0x01;
        USART_SendData(USART1 ,time_buf1[ i]);
        i++;
        if(time_buf[len-1]==0X74)//如果到數第二位為t則調整時間
        DS1302_WriteTime(time_buf1);
        USART_RX_STA=0;
                        times++;
                        if(times%5000==0)
                                printf("\r\n??STM32??? ????\r\n");
                                printf("????@ALIENTEK\r\n\r\n");
                delay_ms(800);
* @name       :void lcd_ds18b20(int x,int y)
* @date       :2020-05-18
* @function   :時間顯示函數
                int y y方向坐標
* @retvalue   :None
{ float go_num=0;
        float temp1[2];
        DS18B20_Get_Temp(temp1,go_num,1);//取溫度還沒有弄明白
        LCD_ShowNumF(x,y,RED,WHITE,temp1[1],temp1[0],3,16);
* @name       :void get_sdfree(void)
* @date       :2020-05-18
* @function   :獲取SD卡容量
* @parameters :None
* @retvalue   :None
void get_sdfree()
        u8 res=0;
u32 total,sdfree;
while(exf_getfree("0",&total,&sdfree))        //得到SD卡的總容量和剩余容量
                LCD_ShowString(30,150,16,"SD Card Fatfs Error!",0);
printf("sd card fatfs error\r\n");
                delay_ms(200);
                LCD_Fill(30,150,240,150+16,WHITE);        //清除顯示
                delay_ms(200);
        //        LED0=!LED0;//DS0閃爍
         POINT_COLOR=BLUE;//設置字體為藍色
        LCD_ShowString(30,150,16,"FATFS OK!",0);
        LCD_ShowString(30,170,16,"SD Total Size:     MB",0);
        LCD_ShowString(30,190,16,"SD  Free Size:     MB",0);
printf ("fatfs ok\r\n");
         LCD_ShowNum(30+8*14,170,total>>10,5,16);                                //顯示SD卡總容量 MB
         LCD_ShowNum(30+8*14,190,sdfree>>10,5,16);                                        //顯示SD卡剩余容量 MB
        printf("sd total size %d MB\r\n",total>>10);
printf("sd free  size %d MB\r\n",sdfree>>10);
* @name       :void write_sd(int x,int y)
* @date       :2020-05-18
* @function   :寫數據到SD卡
                int y y方向坐標
* @retvalue   :None
//BYTE READBUFFER[1024]={0};
void write_sd(u8 first,BYTE *WRITEBUFFER)
        u8 res;
        UINT fnum;
FIL fsrc;//文件對象
FIL fsrcend;
        //FATFS fs;
        res=f_mount(fs[0],"0:",1);                                         //掛載SD卡
        if(first==0)//如果沒有被格式過則將SD卡格式化
        {res=f_mkfs("0:",1,4096);//格式化FLASH,1,盤符;1,不需要引導區,8個扇區為1個簇
                if(res==0)
                        f_setlabel((const TCHAR *)"0:mcudev");        //設置Flash磁盤的名字為:ALIENTEK
                        LCD_ShowString(30,150,16,"Flash Disk Format Finish",0);        //格式化完成
                        printf("sd disk format finish\r\n");
                }else
                 LCD_ShowString(30,150,16,"Flash Disk Format Error ",0);        //格式化失敗
                        printf("sd disk format error\r\n");
                        delay_ms(1000);
        res=f_open (&fsrc,"0:/你好.txt",FA_OPEN_EXISTING|FA_WRITE  );//創建一個文件,如果存在就打開
        if(res==0x00)
                f_lseek(&fsrc,fsrc.fptr+fsrc.fsize);
                f_write(&fsrc, WRITEBUFFER, sizeof(WRITEBUFFER), &fnum);
                res=f_open (&fsrc,"0:/你好.txt",FA_CREATE_ALWAYS|FA_WRITE  );
                        if(res==FR_OK)
                                {        LCD_ShowString (30,210,16,"OPEN WORD OK!",0);
                                        printf("open word ok\r\n");
                                        res=f_write(&fsrc ,WRITEBUFFER ,sizeof(WRITEBUFFER ),&fnum);
                                        if(res==FR_OK)
                                                        printf("文件寫入成攻,寫入字節數據:%d\r\n",fnum);
                                                        printf("寫入的數據為:\r\n%s\r\n",WRITEBUFFER);
                                                        LCD_ShowString (30,230,16,WRITEBUFFER,0);
                f_close (&fsrc);//關閉文件
                f_mount(NULL,"0:",1);//卸載SD卡
user.h里的內容
#ifndef _USER_H
#define _USER_H
//#include "sys.h"
void lcd_ds1302(int x,int y);
void lcd_ds18b20(int x,int y);
void usart_ds1302(void);
#endif
請大神指教。。。。。
