查看: 1677|回復: 0
51單片機仿真0到F
ID:757936 發表于 2020-5-22 07:41 來自觸屏版 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
          #include <reg52.h>
         sbit duanxuan=P2^5;
         sbit weixuan=P2^6;
         uchar num;
         uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
                             0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
         void delayms(uint);
                  weixuan=1;
                 P0=0x00;
                 weixuan=0;
                         for(num=0;num<16;num++){
                              duanxuan=1;
                                  P0=table[num];
                                  duanxuan=0;
                                  delayms(1000);
         void delayms(uint xms)
             uint i,j;
                 for(i=xms;i>0;i--)
                         for(j=110;j>0;j--);
