查看: 2088|回復: 4
KEIL編譯時大量未定義是啥意思 大哥們求救!
ID:736212 發表于 2020-5-20 19:17 | 顯示全部樓層 |閱讀模式
本人純純的小白,設計做這個在網上找的程序 不知道什么原因編譯時引腳全是未定義 這程序哪里錯了 有無老哥解釋下
#include <AT89X52.h>
#define UCHAR UNSIGNED CHAR
#define UINT UNSIGNED INT
#define DAC0832 P1
unsigned char codediscode[] = {0x03f,0x06,0x5b,0x4f,0x66,0x6d, 0x7d,0x07,0x7f,0x6f,0x76};    /* ??????????? */
unsigned char disbuf[4];
sbit wr1=P3^6;
sbit rd1=P3^7;
sbit key1=P2^0;
sbit key2=P2^1;
sbit key3=P2^2;
sbit key4=P2^3;
void delay(void)     /*???????*/
  uchar x;
  for(x=0;x<20;x++);
void hexbcd(uint a)  /*??DA??????????????????????? */  /*  a?????DA???????  */
  float b;
  int c;
  b =10.00; /*2209.40000000/256.00000000;*/   /*????????????a=50??????????5V????a=150??????????15V??????????λ?????????????????10??????*/
  c = b*a;
  disbuf[3] = c/1000;
  disbuf[2] = c%1000/100;
  disbuf[1] = c%100/10;
  disbuf[0] = c%10;
void key(void)   /*??????????*/
{      /* key1??+0.1V   a+=1 */
      /* key2??+1V     a+=10 */
  int a;    /* key3??-1V     a-=10 */
  if(key1)    /* key4??+0.1V   a-=1 */
    if(key2)
      if(key3)
        if(key4);
     while(key4 == 0);
     a=4;
       while(key3 == 0);
  a=3;
      while(key2 == 0);
   a=2;
   while(key1 == 0);
a=1;
  if(a==1)      DAC0832 += 1;
  else if(a==2) DAC0832 += 10;
  else if(a==3) DAC0832 -= 10;
  else if(a==4) DAC0832 -= 1;
  else          DAC0832 = DAC0832;
  if(DAC0832<0)    /* ????DA???????????????????????????????????????Χ4.5V--16V */
DAC0832 = 0;
  else if(DAC0832>310)
DAC0832 = 310;
  else;
void display(void)    /* ????????????3λ??С???? */
  P0 = discode[disbuf[0]];
  P2_7 = 0;
  P2_6 = 1;
  P2_5 = 1;
  P2_4 = 1;
  delay();
  P2_7 = 1;
  P2_6 = 1;
  P2_5 = 1;
  P2_4 = 1;
  P0 = discode[disbuf[1]];
  P2_7 = 1;
  P2_6 = 0;
  P2_5 = 1;
  P2_4 = 1;
  delay();
  P2_7 = 1;
  P2_6 = 1;
  P2_5 = 1;
  P2_4 = 1;
  P0 = discode[disbuf[2]]+0x80;
  P2_7 = 1;
  P2_6 = 1;
  P2_5 = 0;
  P2_4 = 1;
  delay();
  P2_7 = 1;
  P2_6 = 1;
  P2_5 = 1;
  P2_4 = 1;
  P0 = discode[disbuf[3]];
  P2_7 = 1;
  P2_6 = 1;
  P2_5 = 1;
  P2_4 = 0;
  delay();
  P2_7 = 1;
  P2_6 = 1;
  P2_5 = 1;
  P2_4 = 1;
void main(void)      /* ?????? */
  wr1 = 0;       /* DA????????????Ч */
  rd1 = 0;       /* DA????????????Ч */
  DAC0832 = 50;      /* ???????????????????????5V */
   key();        /* ???e??????? */
hexbcd(DAC0832);  /* ??????????? */
display();    /* ??????????? */
ID:195446 發表于 2020-5-20 22:14 | 顯示全部樓層
運行了一下樓主的程序,錯誤有3處。2個定義要用小寫。1個code后面要加空格。
#define DAC0832 P1
unsigned char code  discode[] = {0x03f,0x06,0x5b,0x4f,0x66,0x6d, 0x7d,0x07,0x7f,0x6f,0x76};    /* ??????????? */
ID:352449 發表于 2020-5-20 23:56 | 顯示全部樓層
ID:94031 發表于 2020-5-21 06:48 | 顯示全部樓層
編譯器未找到 AT89X52.h 這個頭文件造成,改成 reg51.h 這個通用的即可。
ID:755472 發表于 2020-5-21 08:27 | 顯示全部樓層
沒有添加頭文件
