查看: 1639|回復: 1
51單片機1602按鍵松手,光標不顯示,怎么回事?
ID:746099 發表于 2020-5-18 11:44 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define  uint  unsigned  int
#define  uchar unsigned  char
sbit  beep=P2^3;
sbit  lcdrs=P3^5;
sbit  lcden=P3^4;
sbit   wela=P2^7;
sbit   dula=P2^6;
sbit   key0=P3^0;
sbit   key1=P3^1;
sbit   key2=P3^2;
sbit   rd=P3^7;
uchar  shi,fe,miao,t0,j,num,num1,temp;
uchar  code  table[]={"0123456789"};
uchar  code  table1[]={"Welcome!"};
void delayms(uint  xms)
  uint  i,j;
  for(i=xms;i>0;i--)
    for(j=110;j>0;j--);
void  di()
  beep=0;
  delayms(30);
  beep=1;
void  write_com(uchar com)
  lcdrs=0;
  lcden=0;
  P0=com;
  lcden=1;
  delayms(5);
  lcden=0;
void  write_date(uchar date)
  lcdrs=1;
   lcden=0;
   P0=date;
   lcden=1;
   delayms(5);
   lcden=0;
void  init()
         rd=0;
     TMOD=0x01;
         TH0=(65536-50000)/256;
         TL0=(65536-50000)%256;
         ET0=1;
         TR0=1;
         EA=1;
         shi=0;
         fe=0;
         miao=0;
         wela=0;
         dula=0;
         write_com(0x38);
         delayms(1);
         write_com(0x0c);
         delayms(1);
         write_com(0x06);
         delayms(1);
         write_com(0x01);
void  display()
  write_com(0x80);
  for(j=0;j<8;j++)
  write_date(table1[j]);
    delayms(2);
  write_com(0x80+0x45);
  for(j=0;j<1;j++)
  write_date(table[shi/10]);
    delayms(2);
  write_com(0x80+0x46);
  for(j=0;j<1;j++)
  write_date(table[shi%10]);
  delayms(2);
  write_com(0x80+0x47);
  for(j=0;j<1;j++)
  write_date(':');
  delayms(2);
   write_com(0x80+0x48);
  for(j=0;j<1;j++)
  write_date(table[fe/10]);
  delayms(2);
  write_com(0x80+0x49);
  for(j=0;j<1;j++)
  write_date(table[fe%10]);
  delayms(2);
  write_com(0x80+0x4a);
  for(j=0;j<1;j++)
  write_date(':');
  delayms(2);
  write_com(0x80+0x4b);
  for(j=0;j<1;j++)
  write_date(table[miao/10]);
  delayms(2);
  write_com(0x80+0x4c);
  for(j=0;j<1;j++)
  write_date(table[miao%10]);
  delayms(2);
void  keysan()
        rd=0;
        if(key0==0)
                   delayms(10);
                   if(key0==0)
                                          TR0=0;
                                          while(!key0);
                                          write_com(0x80+0x10);
                                          write_com(0xf0);
                                          di();
void  main()
   init();
   display();
   keysan();
void  T0_time()  interrupt  1
  t0++;
  if(t0==20)
  t0=0;
  miao++;
  if(miao==60)
  miao=0;
  fe++;
  if(fe==60)
  fe=0;
  shi++;
  if(shi==24)
  shi=0;
ID:584814 發表于 2020-5-22 10:11 | 顯示全部樓層
看不懂你講啥,對沒注釋的程序沒興趣,以下百度來的供參考:
屏幕開關、光標開關、閃爍開關。
08H、09H、0AH、0BH:關閉顯示屏,實質上是不把DDRAM中的內容對應顯示在屏幕上,對DDRAM的操作還是在進行的,執行這條指令,接著對 DDRAM進行寫入,屏幕上沒有任何內容,但是接著執行下面的某條指令,就能看到剛才屏幕關閉期間,對DDRAM操作的效果了。
0cH:打開顯示屏,不顯示光標,光標所在位置的字符不閃爍。
0dH:打開顯示屏,不顯示光標,光標所在位置的字符閃爍。
0eH:打開顯示屏,顯示光標,光標所在位置的字符不閃爍。
0fH:打開顯示屏,顯示光標,光標所在位置的字符閃爍。
關于光標的位置:光標所在的位置指示了下一個被寫入的字符所處的位置,加入在寫入下一個字符前沒有通過指令設置DDRAM的地址,那么這個字符就應該顯示在光標指定的地方。
