查看: 2992|回復(fù): 0
DS18B20+單片機10路溫度檢測程序,LCD1602輪顯,串口上傳數(shù)據(jù)
ID:361216 發(fā)表于 2020-5-17 14:44 | 顯示全部樓層 |閱讀模式
能夠同時檢測10個DS18B20的溫度結(jié)果。在LCD1620上輪流顯示。也可以通過串口向上位機發(fā)送10個溫度的值,但需要上位機向單片機提出請求;具體看程序嘛。
#include <reg51.h>
#include <Intrins.h>
//DS18B20 相關(guān)定義開始
//存儲器操作命令
#define                 ANEW_MOVE                     0xB8                    //重新調(diào)出E^2數(shù)據(jù)
#define                 READ_POWER              0xB4                    //讀電源
#define                 TEMP_SWITCH             0x44                    //啟動溫度變換
#define                 READ_MEMORY             0xBE                    //讀暫存存儲器
#define                 COPY_MEMORY             0x48                    //復(fù)制暫存存儲器
#define                 WRITE_MEMORY            0x4E                    //寫暫存存儲器
//引腳定義
sbit                 DQ = P3^7;                                                        //溫度數(shù)據(jù)線端口
//DS18B20序列號,通過調(diào)用GetROMSequence()函數(shù)在P0口讀出(讀10次)
const unsigned char code ROMData1[8] = {0x28, 0xFF, 0x4D, 0x29, 0x22, 0x17, 0x03, 0x15};
const unsigned char code ROMData2[8] = {0x28, 0xFF, 0xEC, 0xEA, 0x21, 0x17, 0x04, 0x3D};
const unsigned char code ROMData3[8] = {0x28, 0x2B, 0x88, 0x77, 0x91, 0x08, 0x02, 0xC2};
const unsigned char code ROMData4[8] = {0x28, 0x32, 0x07, 0x77, 0x91, 0x04, 0x02, 0xE6};
const unsigned char code ROMData5[8] = {0x28, 0x22, 0x04, 0x77, 0x91, 0x12, 0x02, 0xB5};
const unsigned char code ROMData6[8] = {0x28, 0xD5, 0xF0, 0x16, 0xA8, 0x01, 0x3C, 0xAC};
const unsigned char code ROMData7[8] = {0x28, 0x75, 0x68, 0x16, 0xA8, 0x01, 0x3C, 0x79};
const unsigned char code ROMData8[8] = {0x28, 0x69, 0x5B, 0x16, 0xA8, 0x01, 0x3C, 0x95};
const unsigned char code ROMData9[8] = {0x28, 0xA3, 0x21, 0x16, 0xA8, 0x01, 0x3C, 0x15};
const unsigned char code ROMData10[8] = {0x28, 0xBA, 0x04, 0x16, 0xA8, 0x01, 0x3C, 0xF2};
//數(shù)據(jù)存儲結(jié)構(gòu)
typedef struct tagTempData
        unsigned char                                         btThird;                                                        //百位數(shù)據(jù)
        unsigned char                                         btSecond;                                                        //十位數(shù)據(jù)
        unsigned char                                         btFirst;                                                        //個位數(shù)據(jù)
        unsigned char                                         btDecimal;                                                        //小數(shù)點后一位數(shù)據(jù)
        unsigned char                                        btNegative;                                                        //是否為負數(shù)
}TEMPDATA;
TEMPDATA m_TempData;
unsigned char RomI=0;
//DS18B20 相關(guān)定義結(jié)束
//LCD1602 相關(guān)定義開始
#define                DATA        P0      //1602驅(qū)動端口
//ROM操作命令
#define                 READ_ROM                       0x33                    //讀ROM
#define                 SKIP_ROM                       0xCC                    //跳過ROM
#define                 MATCH_ROM               0x55                    //匹配ROM
#define                 SEARCH_ROM              0xF0                    //搜索ROM
#define                 ALARM_SEARCH            0xEC                    //告警搜索
//控制端口定義
sbit                 RS=                P2^6;
sbit                 RW=                P2^5;
sbit                 E=                P2^7;
//LCD1602 相關(guān)定義結(jié)束
//RS232 相關(guān)定義開始
unsigned char ReData,SenData;
bit flag=0; //串口標志位
//RS232 相關(guān)定義結(jié)束
void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber);
unsigned char SendData[8]={' ',' ',' ',' ',' ','.',' ','@'};
//Delay 延時函數(shù)
函數(shù):Delay16us()
功能:延時16us
參數(shù):無
返回:無
void Delay16us()
        unsigned char a;
        for (a = 0; a < 4; a++);
函數(shù):Delay60us()
功能:延時60us
參數(shù):無
返回:無
void Delay60us()
        unsigned char a;
        for (a = 0; a < 18; a++);
函數(shù):Delay480us()
功能:延時480us
參數(shù):無
返回:無
void Delay480us()
        unsigned char a;
        for (a = 0; a < 158; a++);
函數(shù):Delay240us()
功能:延時240us
參數(shù):無
返回:無
void Delay240us()
        unsigned char a;
        for (a = 0; a < 78; a++);
功能:延時240us
參數(shù):無
返回:無
void Delay500ms()
        unsigned char a, b, c;
        for (a = 0; a < 250; a++)
        for (b = 0; b < 3; b++)
        for (c = 0; c < 220; c++);
//延時函數(shù)結(jié)束
//********************DS18B20
函數(shù):Initialization()
功能:DS18B20初始化程序
參數(shù):無
返回:無
void Initialization()
                DQ = 0;
                Delay480us();                         //延時480us
                DQ = 1;
                Delay60us();                        //延時60us
                if(!DQ)                                  //收到ds18b20的應(yīng)答信號
                        DQ = 1;
                        Delay240us();                //延時240us
                        break;
函數(shù):WriteByte(unsigned char btData)
功能:DS18B20從低位開始寫一個字節(jié)
參數(shù):無
返回:無
void WriteByte(unsigned char btData)
        unsigned char i, btBuffer;
        for (i = 0; i < 8; i++)
                btBuffer = btData >> i;
                if (btBuffer & 1)
                        DQ = 0;
                        _nop_();
                        _nop_();
                        DQ = 1;
                        Delay60us();
                        DQ = 0;
                        Delay60us();
                        DQ = 1;
函數(shù):ReadByte()
功能:DS18B20從低位開始讀一個字節(jié)
參數(shù):無
返回:無
unsigned char ReadByte()
        unsigned char i, btDest;
                btDest >>= 1;
                DQ = 0;
                _nop_();
                _nop_();
                DQ = 1;
                Delay16us();
                if (DQ) btDest |= 0x80;
                Delay60us();
        return btDest;
函數(shù):MatchROM(const unsigned char *pMatchData)
功能:DS18B20序列號匹配
參數(shù):無
返回:無
void MatchROM(const unsigned char *pMatchData)
        unsigned char i;
        Initialization();
        WriteByte(MATCH_ROM);
        for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
函數(shù):GetROMSequence()
功能:DS18B20Rom序列獲取,在P0口顯示
參數(shù):無
返回:無
void GetROMSequence()
        unsigned char i;
        Initialization();
        WriteByte(READ_ROM);
        for (i = 0; i < 10; i++)
        P0 = ReadByte();
函數(shù):ReadTemperature()
功能:DS18B20讀取溫度值多點
參數(shù):無
返回:TempData
TEMPDATA ReadTemperature()
        TEMPDATA TempData;
        unsigned int iTempDataH;
        unsigned char btDot, iTempDataL;
        //static unsigned char i = 0;
        TempData.btNegative = 0;                                                //為0溫度為正
        RomI++;
        if (RomI == 11) RomI = 1;
        Initialization();
        WriteByte(SKIP_ROM);                                                        //跳過ROM匹配
        WriteByte(TEMP_SWITCH);                                                        //啟動轉(zhuǎn)換
        Delay500ms();        //調(diào)用一次就行
        Delay500ms();
        Initialization();
        //多個芯片的時候用MatchROM(ROMData)換掉WriteByte(SKIP_ROM)
        switch (RomI)
                case 1 : MatchROM(ROMData1); break;                        //匹配1
                case 2 : MatchROM(ROMData2); break;                        //匹配2
                case 3 : MatchROM(ROMData3); break;                        //匹配3
                case 4 : MatchROM(ROMData4); break;                        //匹配4
                case 5 : MatchROM(ROMData5); break;                        //匹配5
                case 6 : MatchROM(ROMData6); break;                        //匹配6
                case 7 : MatchROM(ROMData7); break;                        //匹配7
                case 8 : MatchROM(ROMData8); break;                        //匹配8
                case 9 : MatchROM(ROMData9); break;                        //匹配8
                case 10 : MatchROM(ROMData10); break;                        //匹配8
        //WriteByte(SKIP_ROM);                                                        //跳過ROM匹配(單個芯片時用這句換掉上面的switch)
        WriteByte(READ_MEMORY);                                                        //讀數(shù)據(jù)
        iTempDataL = ReadByte();
        iTempDataH = ReadByte();
        iTempDataH <<= 8;
        iTempDataH |= iTempDataL;
        if (iTempDataH & 0x8000)
                TempData.btNegative = 1;
                iTempDataH = ~iTempDataH + 1;                                //負數(shù)求補
        //為了省去浮點運算帶來的開銷,而采用整數(shù)和小數(shù)部分分開處理的方法(沒有四舍五入)
        btDot = (unsigned char)(iTempDataH & 0x000F);        //得到小數(shù)部分
        iTempDataH >>= 4;        //得到整數(shù)部分
        btDot *= 5;        //btDot*10/16得到轉(zhuǎn)換后的小數(shù)數(shù)據(jù)
        btDot >>= 3;
        //數(shù)據(jù)處理
        TempData.btThird   = (unsigned char)iTempDataH / 100;
        TempData.btSecond  = (unsigned char)iTempDataH % 100 / 10;
        TempData.btFirst   = (unsigned char)iTempDataH % 10;
        TempData.btDecimal = btDot;
        return TempData;
函數(shù):ReadOneTemperature()
功能:DS18B20讀取單個溫度值
參數(shù):無
返回:TempData
TEMPDATA ReadOneTemperature()
        TEMPDATA TempData;
        i++;
        if (i == 11) i = 1;
        Initialization();
        Delay500ms();
        Initialization();
        iTempDataH <<= 8;
        btDot >>= 3;
        //數(shù)據(jù)處理
        return TempData;
函數(shù):DataProcess()
功能:LCD1602顯示溫度數(shù)據(jù)處理
參數(shù):無
返回:無
void DataProcess()
        m_TempData = ReadTemperature();
        if (m_TempData.btNegative)
                DisplayOne(1, 6, '-', 0);
                SendData[1]='-';
        DisplayOne(1, 6, m_TempData.btThird, 1);
        DisplayOne(1, 7, m_TempData.btSecond, 1);
        DisplayOne(1, 8, m_TempData.btFirst, 1);
        DisplayOne(1, 10, m_TempData.btDecimal, 1);
        SendData[1]=' ';
//DS18B20 程序結(jié)束
//LCD1602 程序開始
函數(shù):Busy()
功能:判斷LCD忙指令
參數(shù):無
返回:無
void Busy()
        DATA = 0xff;
        RS = 0;
        RW = 1;
           while(DATA & 0x80)
                E = 0;
                   E = 1;
           E = 0;
函數(shù):WriteCommand()
功能:寫LCD指令程序
參數(shù):btCommand
返回:無
void WriteCommand(unsigned char btCommand)
        Busy();
        RS = 0;
        RW = 0;
        E = 1;
        DATA = btCommand;
        E = 0;
函數(shù):WriteData()
功能:寫LCD數(shù)據(jù)程序
參數(shù):btData
返回:無
void WriteData(unsigned char btData)
        Busy();
        RS = 1;
        RW = 0;
        E = 1;
        DATA = btData;
        E = 0;
函數(shù):Clear()
功能:LCD清屏
參數(shù):無
返回:無
void Clear()
        WriteCommand(1);
函數(shù):Init()
功能:初始化LCD
參數(shù):無
返回:無
void Init()
        WriteCommand(0x0c);        //開顯示,無光標顯示
        WriteCommand(0x06);        //文字不動,光標自動右移
        WriteCommand(0x38);        //設(shè)置顯示模式:8位2行5x7點陣
函數(shù):DisplayOne()
功能:顯示單個字符
參數(shù):bRow,btColum,btData,bIsNumber
返回:無
        if (bRow)                 WriteCommand(0xc0 + btColumn);
        else                      WriteCommand(0x80 + btColumn);
        if (bIsNumber)         WriteData(btData + 0x30);
        else                   WriteData(btData);
函數(shù):DisplayString()
功能:顯示字符串
參數(shù):bRow,btColum,*pData
返回:無
void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
        while (*pData != '\0')
                   if (bRow) WriteCommand(0xc0 + btColumn);        //顯示在第1行
                   else            WriteCommand(0x80 + btColumn);        //顯示在第0行
                WriteData(*(pData++));                                                //要顯示的數(shù)據(jù)
                btColumn++;        //列數(shù)加一
//LCD1602 程序結(jié)束
//RS232 程序開始
函數(shù):RS232_Init()
功能:串口通信初始化程序,T1端口
參數(shù):無
返回:無
void RS232_Init()
           TMOD|= 0x20;      //定時器工作方式2
    SCON = 0x50;  //REN=1允許串行接受狀態(tài),串口工作模式1
    TH1 = 0xF3;   //2400,12m
    TL1 = TH1;
    PCON|= 0x80;
                TR1 = 1;
    EA = 1;
    ES = 1;
函數(shù):SendOneByte(unsigned char c)
功能:串口發(fā)送程序
參數(shù):c
返回:無
void SendOneByte(unsigned char c)
    SBUF = c;
    while(!TI);
    TI = 0;
函數(shù):ser_int (void) interrupt 4 using 1
功能:串口接收程序中斷
參數(shù):無
返回:無
void ser_int (void) interrupt 4 using 1
  if(RI)        //RI接受中斷標志
         RI = 0;                    //清除RI接受中斷標志
        ReData = SBUF;  //SUBF接受/發(fā)送緩沖器
         flag=1;
//RS232 程序結(jié)束
void main(void)
        unsigned char Nu[10][2]={"1 ","2 ","3 ","4 ","5 ","6 ","7 ","8 ","9 ","10"};
        unsigned char Nui[10]={'A','B','C','D','E','F','G','H','I','J'};
//        unsigned char c;
        int i=0,j;
        Init();
        RS232_Init();
        Clear();
        DisplayString(0, 0, "10 POI.TEMP.DET.");
        DisplayOne(1, 9, '.', 0);
        while (1)
                //while(!flag);
                //ReData=SBUF;
                        if(ReData=='K')
                                ReData=' ';
                                RomI=0;
                                i=0;
                                for(;i<10;)
                                DataProcess();
                                DisplayOne(1, 1, Nu[ i][0], 0);
                                DisplayOne(1, 2, Nu[ i][1], 0);
                                SendData[0]=Nui[ i];
                                SendData[2]=m_TempData.btThird+0X30;
                                SendData[3]=m_TempData.btSecond+0X30;
                                SendData[4]=m_TempData.btFirst+0X30;
                                SendData[6]=m_TempData.btDecimal+0X30;
                                for(j=0;j<8;j++)
                                        SendOneByte(SendData[j]);
                                        i++;
                                if(i==10)
                                        SendOneByte('*');//*表示10個數(shù)據(jù)發(fā)送完成
                                DataProcess();
                                i++;
                if(i==10)
                        i=0;
全部資料51hei下載地址:
DS18B20-10-pots.zip (3.71 KB, 下載次數(shù): 42)
參與人數(shù) 1黑幣 +50 收起 理由
