查看: 1202|回復(fù): 3
求大神幫我看看紅外通訊程序哪里不對!
ID:752619 發(fā)表于 2020-5-15 15:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
# include "reg52.h"
typedef unsigned char u8;
typedef unsigned int u16;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit IRIN=P3^2;
u8 IrValue[6];
u8 Time;
u8 DisplayData[8];
u8 code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
                      0x77,0x7c,0x39,0x5e,0x79,0x71,0x76};
void delay(u16 i)
while (i--);
void DigDisplay ()
u8 i;  //i???????8?????
for (i=0;i<3;i++)
  switch (i)
   case (0):      //???i????0???????????
    LSA=0;LSB=0;LSC=0;break; //break????????case (0)?????switch
   case (1):
    LSA=1;LSB=0;LSC=0;break;
   case (2):
    LSA=0;LSB=1;LSC=0;break;
  P0=DisplayData[ i];    //????????
  delay(100);  //????????????
     P0=0x00; //??????????????
void IrInit()     //?????
IT0=1;//????????
EX0=1; //???ж?0????
EA=1;  //?????ж?
IRIN=1; //????????
void main ()
IrInit();
while (1)
  DisplayData[0]=smgduan[IrValue[2]/16];  //??λ
  DisplayData[1]=smgduan[IrValue[2]%16];  //??λ
  DisplayData[2]=smgduan[16];
  DigDisplay();
void ReadIr() interrupt()
u8 j,k;
u16 err;
Time=0;
delay(700);//7ms
if(IRIN==0)  //???????????????????????????????????9ms????
  err=1000;  //1000*10us=10ms,????????????????????
  while ((IRIN==0)&&(err>0)) //??????9ms????????   //??????????????????????????????????????????????ó???????????????
   delay(1);   //10us?????????1000???
   err--;
  if(IRIN==1)  //?????????9ms????
   err=500;   //5ms
   while((IRIN==1)&&(err>0)) //???4.5ms????????????
    delay(1);
    err--;
   for(k=0;k<4;k++)    //????4??????
    for(j=0;j<8;j++)    //???????????
     err=60;
     while((IRIN==0)&&(err>0))    //??????????560us???
      delay(1);
      err--;
     err=500;
     while((IRIN==1)&&(err>0))   //????????????
      delay(10);  //0.1ms
      Time++;
      err--;
      if (Time>30)   //3ms???????3ms???????????????
       return;
     IrValue[k]>>=1;     //k???????????
     if (Time>=8)  //??????????????565us???????λ1
      IrValue[k]|=0x80;
     Time=0;//??????????????
  if (IrValue[2]!=~IrValue[3])    //??????????????????
   return;     //??????????????????????
ID:752619 發(fā)表于 2020-5-15 15:33 | 只看該作者
這是紅外通信的程序
ID:328014 發(fā)表于 2020-5-15 17:11 | 只看該作者
我看了一下 你這個程序 沒有問題啊
ID:752619 發(fā)表于 2020-5-15 20:46 | 只看該作者
51hei團團 發(fā)表于 2020-5-15 17:11
我看了一下 你這個程序 沒有問題啊
有問題的,總是報錯,我看了好久,沒看出來
