查看: 1911|回復: 3
實現一個單片機串行接口雙機通訊測試系統,我的這個為什么沒有效果
ID:751978 發表于 2020-5-14 19:10 | 顯示全部樓層 |閱讀模式
1黑幣
//??????н???
#include <reg51.h>
code unsigned char tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char i;
SCON=0x40;
PCON=0X00;
TMOD=0X20;
TH1=0XFD;
TL1=0XFD;
TR1=1;
REN=1;
while(RI==0);
i=SBUF;
P0=tab[ i];
RI=0;
ID:751978 發表于 2020-5-14 19:11 | 顯示全部樓層
//??????н???
#include<reg51.h>
sbit S=P0^0;
unsigned char count;
key()
unsigned int k;
if(S==0)
for(k=0;k<1200;k++);
if(S==0){
count++;
if(count==10)count=0;
while(!S);
main()
TMOD=0X20;
TH1=0XFD;
TL1=0xfd;
TR1=1;
SCON=0x40;
PCON=0x00;
count=0;
key();
SBUF=count;
while(!TI);
TI=0;
ID:213173 發表于 2020-5-14 22:22 | 顯示全部樓層
whaless 發表于 2020-5-14 19:11
//??????н???
#include
sbit S=P0^0;
#include<reg51.h>
sbit S=P0^0;
void key()
        unsigned int k;
        if(S==0)
                if(S==0)
                        count++;
                        if(count>=10)
                                count=0;
                        while(!S);
                        SBUF=count;
                        while(!TI);
                        TI=0;
        TMOD=0X20;
        SCON=0x50;
        PCON=0x00;
        TH1=0xfd;
        TL1=0xfd;
        TR1=1;
        count=0;
                key();
#include <reg51.h>
        unsigned char i;
        SCON=0x50;
        PCON=0X00;
        TMOD=0X20;
        TH1=0xfd;
        TL1=0xfd;
        TR1=1;
        P0=0xbf;//'-'
                if(RI==1)
                        RI=0;
                        i=SBUF;
                        P0=tab[ i];
