只需一步,快速開(kāi)始
查看: 2736|回復(fù): 4
單片機(jī)+ADC0808芯片,現(xiàn)在精確度是0.05,希望精確度是0.02,求指導(dǎo)如何修改?
回帖獎(jiǎng)勵(lì) 50 黑幣 回復(fù)本帖可獲得 10 黑幣獎(jiǎng)勵(lì)! 每人限 1 次
ID:318131 發(fā)表于 2020-5-13 16:42 | 顯示全部樓層 |閱讀模式
批注 2020-05-13 081618.png 這是文件,里面有仿真和程序
數(shù)字電壓表.rar (108.94 KB, 下載次數(shù): 14)
這是程序
#include<reg52.h>
#define LCD_DB  P2
sbit LCD_RS = P1^0;
sbit LCD_RW = P1^1;
sbit LCD_EN = P1^2;
sbit AD_OE=P3^1;
sbit AD_EOC=P3^2;
sbit AD_A=P3^4;
sbit AD_B=P3^5;
sbit AD_C=P3^6;
sbit AD_START=P3^0;
unsigned char Zh1[]="    voltmeter   ";
unsigned char Zh2[]=" Voltage:       ";
unsigned char sj,ai;
int AD_sj=0,AD_ai=0;
void Busy()                 //檢忙
    unsigned char sta;
    LCD_DB = 0xff;
    LCD_RS = 0;
    LCD_RW = 1;
    do
    LCD_EN = 1;
    sta = LCD_DB;
    LCD_EN = 0;
    while(sta&0x80);
void Lcd_Write_Cmd(unsigned char cmd)      //命令
    Busy();
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_DB = cmd;
    LCD_EN = 1;
    LCD_EN = 0;
void Lcd_Write_Data(unsigned char dat)     //數(shù)據(jù)
    Busy();
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_DB = dat;
    LCD_EN = 1;
    LCD_EN = 0;
void InitLcd()                            //初始化
    Lcd_Write_Cmd(0x38);
    Lcd_Write_Cmd(0x08);
    Lcd_Write_Cmd(0x01);
    Lcd_Write_Cmd(0x06);
    Lcd_Write_Cmd(0x0c);
void LcdSetCursor(unsigned char x,unsigned char y)   //坐標(biāo)
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd_Write_Cmd(addr|0X80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *s)  //字符串
    LcdSetCursor(x,y);
    while(*s)
        Lcd_Write_Data(*s);
        s++;
//AD轉(zhuǎn)換
void AD_xsgs()  //顯示格式
//    AD_sj=100- sj*5.00/25.5;
        AD_sj=5.00*100/255*sj;
    Zh2[10]=(AD_sj/100)+0x30;
    Zh2[11]='.';
    Zh2[12]=(AD_sj%100/10)+0x30;
    Zh2[13]=(AD_sj%100%10)+0x30;
    Zh2[14]='V';
void AD_csh()     //AD主程序
        AD_A=0;
        AD_B=0;
        AD_C=0;
        AD_START=1;
        AD_START=0;
        AD_OE=0;
        AD_START=1;
        AD_START=0;
        while(AD_EOC==1);
        AD_OE=1;
        sj=P0;
        AD_OE=0;
void ad ()
        AD_A=1;
        AD_B=0;
        AD_C=0;
        AD_START=1;
        AD_START=0;
        AD_OE=0;
        AD_START=1;
        AD_START=0;
        while(AD_EOC==1);
        AD_OE=1;
        ai=P0;
        AD_OE=0;
        InitLcd();
        LcdShowStr(0,0,Zh1);
    LcdShowStr(0,1,Zh2);
     AD_csh();
     AD_xsgs();
     ad ();
數(shù)字電壓表.rar
175.59 KB, 下載次數(shù): 7
ID:648281 發(fā)表于 2020-5-14 08:35 | 顯示全部樓層
你好!
1、首先,仿真里面可調(diào)電位器的變化量是1%
2、0808直接加外接時(shí)鐘,實(shí)物測(cè)量沒(méi)有任何意義
ID:213173 發(fā)表于 2020-5-14 08:41 | 顯示全部樓層
分辨率可以做到0.02V,精確度做不到±0.02V。
ID:318131 發(fā)表于 2020-5-14 15:08 | 顯示全部樓層
wulin 發(fā)表于 2020-5-14 08:41
分辨率怎么改為0.02V呢,可以解釋一下嗎。麻煩了
ID:755472 發(fā)表于 2020-5-21 15:40 | 顯示全部樓層
不容易做到
