查看: 2575|回復: 4
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS無法生成hex文件
#include <reg51.h>
#define SEG P2
#define SCAN P3
#define uint  unsigned int
uchar shu[] = {0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf9,0x80,0xc0,0xb0,0xc0,0xf8,0xc0,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};//18030708
uchar seg[10] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar sel[8] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char count=0;
unsigned int y,m;
void Timer0Interrupt(void) interrupt 1
    TH0 = 0x3C;
    TL0 = 0x0B0;
    count++;
void delay_1ms(uint x)
        uint i,j;
        for(i=0; i<x; i++)
           for(j=0; j<120; j++);
void InitTimer0(void)
    TMOD = 0x01;
    TH0 = 0x3C;
    TL0 = 0x0B0;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
               for(m=0;m<8;m++)
                SCAN = ~0xff;
                SEG = shu[y+m];
                SCAN = ~sel[m];
                delay_1ms(1);
if(count==20){count=0;break;}}
void main(void)
           for(y=0;y<15;y++)
        InitTimer0();
ID:750491 發表于 2020-5-13 09:43 | 只看該作者
就是出現了這個*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
ID:213173 發表于 2020-5-13 10:14 | 只看該作者
ID:584814 發表于 2020-5-13 11:49 | 只看該作者
Keil 5 表示生成無壓力。ERROR L104: MULTIPLE PUBLIC DEFINITIONS可能是低版本的沒處理好變量以為是有重復定義,如果堅持在低版本上生成可將似是而非的不同之處搞大點而不僅在大小寫。
參與人數 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:686878 發表于 2020-5-13 13:11 | 只看該作者
用Keil 4編譯沒有錯誤啊
