只需一步,快速開(kāi)始
查看: 3167|回復(fù): 9
這是論壇上照學(xué)的一個(gè)單片機(jī)測(cè)直流電機(jī)轉(zhuǎn)速的一個(gè)例子,為啥我仿真的時(shí)候電機(jī)不轉(zhuǎn)
回帖獎(jiǎng)勵(lì) 40 黑幣 回復(fù)本帖可獲得 20 黑幣獎(jiǎng)勵(lì)! 每人限 1 次(中獎(jiǎng)概率 80%)
ID:746195 發(fā)表于 2020-5-10 21:02 | 顯示全部樓層 |閱讀模式
圖片1為原圖,2為我照搬的圖
附上代碼-------
#include <reg51.h>
sbit open = P2^0;
sbit close = P2^1;
sbit swap = P2^2;
sbit sub_speed = P2^3;
sbit add_speed = P2^4;
sbit PWM1 = P3^0;
sbit PWM2 = P3^1;
/************************液晶顯示*************/
sbit E=P3^7;
sbit RW = P3^6;
sbit RS = P3^5;
sbit test = P3^4;
int time = 0;
int high = 20;
int period = 30;
int change = 0;
int flag = 0;
int num_medium = 0;
int num_display = 0;
int count_speed = 0;
uchar wword[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
/*******************延時(shí)t毫秒****************/
void delay(uchar t)
        uint i;
        while(t)
                    /*對(duì)于11.0592MHz時(shí)鐘,延時(shí)1ms*/
                  for(i=0;i<125;i++);
                  t--;
//寫(xiě)命令函數(shù)LCD
void wc51r(uchar j)
            RS=0;
                  RW=0;
         P1=j;
                  E=1;
                  E=0;
                 delay(3);
//寫(xiě)數(shù)據(jù)函數(shù)LCD
void wc51ddr(uchar j)
                  RS=1;
                  RW=0;
         P1=j;
                  E=1;
                  E=0;
                  delay(2);
//初始化函數(shù)LCD
void init()
         wc51r(0x01);  //清屏
         wc51r(0x38);  //使用8位數(shù)據(jù),顯示兩行,使用5*7的字型
         wc51r(0x0c);  //顯示器件,光標(biāo)開(kāi),字符不閃爍
         wc51r(0x06);  //字符不動(dòng),光標(biāo)自動(dòng)右移一格
/***********8T0中斷服務(wù)程序************PWM波的生成**********/
void time0_int(void) interrupt 1
                time++;
                TH0 = 0xec;
                TL0 = 0x78;
                if(change == 0)
                              PWM2 = 1;
                        if(time == high)
                              PWM1=0;
                        else if(time == period)
                                  PWM1 = 1;
                                  time = 0;
                 {            PWM1 = 1;
                                 if(time == high)
                                       PWM2=0;
                                   PWM2 = 1;
                                            time = 0;
/****T1中斷服務(wù)程序********單位時(shí)間(S)方波的個(gè)數(shù)*************/
void time1_int(void) interrupt 3
                count_speed++;
         if(count_speed == 20)
                {     count_speed = 0;
                           num_display = num_medium;
                           num_medium = 0;
/************************速度顯示的數(shù)據(jù)處理*********************/
void datamade()
uint data MM,NN;
             wc51r(0xc2);
          wc51ddr('S');
                   wc51ddr('p');
                   wc51ddr('e');
                   wc51ddr('e');
                   wc51ddr('d');
          wc51ddr(0x3a);
                   NN = num_display%100;
                   MM = num_display/100;
                    wc51ddr(wword[MM]);
MM = NN/10;
              NN = NN%10;
wc51ddr(wword[MM]);
wc51ddr(wword[NN]);
/**********通過(guò)按鍵實(shí)現(xiàn)對(duì)電機(jī)開(kāi)關(guān)、調(diào)速、轉(zhuǎn)向的控制***************/
void motor_control()
                  if(open == 1)
                                EA = 1;
                  if(close == 1)
                                EA = 0;
                  if(swap == 1)
                                        change = ~change;
                                        while(swap != 0)
                        if(sub_speed == 1)
                                           high++;
                                         if(high == 30)
                                                EA=0;
                                       while(sub_speed != 0)
                         if(add_speed == 1)
                                                   high--;
                                                if(high == 5)
                                                   high = 5;
                                       while(add_speed != 0)
/***************************主函數(shù)*********************************/
                     P2 = 0x00;
                         ET0 = 1;
                         ET1 = 1;
                         TMOD = 0x11;
                         TH0 = 0xec;             //定時(shí)器T0設(shè)置參數(shù)
                         TL0 = 0x78;
                         TH1 = 0x3c;            //定時(shí)器T1設(shè)置參數(shù)
                         TL1 = 0xb0;
                         TR0 = 1;
                         TR1 = 1;
               init();               //液晶顯示初始化程序
                     wc51r(0x84);
                     wc51ddr('H');
                     wc51ddr('e');
                     wc51ddr('l');
                     wc51ddr('l');
                     wc51ddr('o');
                          if(test == 0)
                     num_medium++;
datamade();
motor_control();
ID:732506 發(fā)表于 2020-5-11 04:46 | 顯示全部樓層
從圖上看電機(jī)不一樣。
ID:773778 發(fā)表于 2020-6-9 17:23 | 顯示全部樓層
你的激勵(lì)源弄錯(cuò)了吧,那不是電源
ID:600952 發(fā)表于 2020-6-10 09:53 | 顯示全部樓層
是啊,那個(gè)好像不是電源,再可能就是電機(jī)不一樣,好像別的地方都一樣啊
你照搬的真規(guī)整,Q1 D1 R1 等都對(duì)應(yīng)上了。
原圖沒(méi)發(fā)工程文件嗎?下下來(lái)直接用多好啊
希望對(duì)你有幫助
ID:656801 發(fā)表于 2020-6-10 14:31 | 顯示全部樓層
P3口沒(méi)有配置上拉輸出吧? 單片機(jī)管腳能輸出高電平么?
ID:633896 發(fā)表于 2020-7-7 12:10 | 顯示全部樓層
會(huì)不會(huì)是電機(jī)的問(wèn)題
ID:595237 發(fā)表于 2020-7-8 00:15 | 顯示全部樓層
只是一組波工作 能夠可以驅(qū)動(dòng)電機(jī)嗎?
理論上 上一組與下一組 是 對(duì)稱(chēng)的 就可以 驅(qū)動(dòng)電機(jī)。
ID:764088 發(fā)表于 2020-7-8 15:56 | 顯示全部樓層
不是抄軟件就能驅(qū)動(dòng)電機(jī)的啊!您的直流電機(jī)參數(shù)如何?如所需 驅(qū)動(dòng)電流 多大啊?您現(xiàn)在輸出配得上嗎?
ID:235954 發(fā)表于 2020-7-12 07:14 | 顯示全部樓層
激勵(lì)源應(yīng)該用錯(cuò)了,你用5V,它實(shí)際要用12V或者24V才能驅(qū)動(dòng),你明顯是電橋的電壓沒(méi)有給對(duì)。
ID:795846 發(fā)表于 2020-7-16 10:38 | 顯示全部樓層
你的電機(jī)需要多大電壓,你的電源能供多大的電壓。是不是你的電源供電不夠,導(dǎo)致電機(jī)不會(huì)轉(zhuǎn)。改一下電源的賦值
