(1)開(kāi)機(jī)后,紫燈持續(xù)顯示2分鐘后,風(fēng)扇在高速模式下運(yùn)行。空氣質(zhì)量傳感器預(yù)熱結(jié)束,開(kāi)始檢測(cè)空氣質(zhì)量。(實(shí)際測(cè)3.5分鐘) (2)當(dāng)空氣質(zhì)量傳感器檢測(cè)到空氣質(zhì)量差時(shí),指示燈仍然顯示紫色,并持續(xù)30秒。 (3)檢測(cè)空氣質(zhì)量,如檢測(cè)結(jié)果仍然是差,則仍然執(zhí)行第2步步驟。如檢測(cè)到空氣質(zhì)量為良(或優(yōu))指示燈顯示綠色,并持續(xù)20秒。 (4)檢測(cè)氣質(zhì)量,如檢測(cè)結(jié)果為差指示燈顯示為紫色,并從第2步開(kāi)始向下執(zhí)行;如檢測(cè)結(jié)果為良,則從第3步開(kāi)始向下執(zhí)行;檢測(cè)結(jié)果為優(yōu),則指示燈顯示藍(lán)色。 (5)當(dāng)空氣質(zhì)量傳感器檢測(cè)到差,步驟從第2步到第5步依次循環(huán)執(zhí)行。
單片機(jī)源程序如下:
- #define __MAIN_C
- /* Includes ------------------------------------------------------------------*/
- #include "stm8s.h"
- #include "system.h"
- #include "sensor.h"
- #include "Key.h"
- #include "Speed_Control.h"
- #include "Filter.h"
- #include "EEPROM.h"
- /* Private defines -----------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- void CLK_Configuration(void);
- void GPIO_Configuration(void);
- void TIM4_Configuration(void);
- void TIM2_Configuration(void);
- void AD_Configuration(void);
- void FLASH_Configuration(void);
- /* Private functions ---------------------------------------------------------*/
- //u8 wData[10]={8,2,3,4,5,6,7,8,9,10};
- //u8 rData[10];
- void main(void)
- CLK_Configuration();
- GPIO_Configuration();
- Check_Manufature();
- TIM4_Configuration(); //定時(shí)時(shí)鐘基準(zhǔn)
- TIM2_Configuration(); //風(fēng)扇PWM
- AD_Configuration();
- Parameter_Init();
- PIN_GAS_POWER(on); //傳感器電源一直給
- /* Infinite loop */
- while (1)
- if(Manufature != 0)
- Process_Manufature();
- else
- Process_Key();
- Process_LED();
- Process_Speed_Control();
- Process_AD();
- Process_RealAirQuality();
- Process_Anion();
- Process_Filter();
- //系統(tǒng)時(shí)鐘配置
- CLK->CKDIVR = 0x00; //16MHz
- //CLK->PCKENR1 |= 0x10; //Peripheral Clock-TIM4
- //輸入輸出配置
- //PC7:NEGA1 PD3:NEGA2
- GPIO_Init(GPIOC,GPIO_PIN_7,GPIO_MODE_OUT_PP_LOW_SLOW);
- GPIO_Init(GPIOD,GPIO_PIN_3,GPIO_MODE_OUT_PP_LOW_SLOW);
- //PC6:TriLED_1 PC5:TriLED_2 PC3:TriLED_3
- GPIO_Init(GPIOC,GPIO_PIN_6,GPIO_MODE_OUT_PP_LOW_SLOW);
- GPIO_Init(GPIOC,GPIO_PIN_5,GPIO_MODE_OUT_PP_LOW_SLOW);
- GPIO_Init(GPIOC,GPIO_PIN_3,GPIO_MODE_OUT_PP_LOW_SLOW);
- //PD2:KEY_FILTER_RESET PC4:KEY_SPEED
- GPIO_Init(GPIOD,GPIO_PIN_2,GPIO_MODE_IN_FL_NO_IT);
- GPIO_Init(GPIOC,GPIO_PIN_4,GPIO_MODE_IN_FL_NO_IT);
- //PB4:EE_SCL PB5:EE_SDA
- GPIO_Init(GPIOB,GPIO_PIN_4,GPIO_MODE_OUT_OD_HIZ_SLOW);
- GPIO_Init(GPIOB,GPIO_PIN_5,GPIO_MODE_OUT_OD_HIZ_SLOW);
- //PA2:GAS_POWER
- GPIO_Init(GPIOA,GPIO_PIN_2,GPIO_MODE_OUT_PP_HIGH_SLOW); //低電平有效
- //100us時(shí)鐘基準(zhǔn)
- //TIM4_TimeBaseInit(0x04, 100); // Time base configuration
- TIM4->PSCR = 0x04; //16
- TIM4->ARR = (100-1); //100
- TIM4_ARRPreloadConfig(ENABLE);
- TIM4_ClearFlag(TIM4_FLAG_UPDATE); // Clear TIM4 update flag
- TIM4_ITConfig(TIM4_IT_UPDATE, ENABLE); //Enable update interrupt
- enableInterrupts(); // enable interrupts
- TIM4_Cmd(ENABLE); // Enable TIM4
- //PWM_Vfan風(fēng)扇電壓控制 PWM模式 10kHz載頻
- TIM2_DeInit();
- TIM2_TimeBaseInit(TIM2_PRESCALER_16,99); //載頻10kHz
- //PWM1模式,輸出使能,初始化占空比0%,有效電平為高電平
- TIM2_OC1Init(TIM2_OCMODE_PWM1,TIM2_OUTPUTSTATE_ENABLE,0,TIM2_OCPOLARITY_HIGH);
- TIM2_OC1PreloadConfig(ENABLE);
- TIM2_ARRPreloadConfig(ENABLE);
- TIM2_Cmd(ENABLE); //TIM2 enable counter
- //AD配置
- ADC1->TDRL = 0x60; //disable schmitt trigger
- ADC1->CR1 |= 0x40; //f(adc)=f(master)/8
- ADC1->CR2 |= 0x08; //數(shù)據(jù)右對(duì)齊
- //ADC1->CSR = 6; //通道選擇,初始化為AD_Vfan-AIN6
- ADC1->CSR = 5; //通道選擇,GAS-AIN5
- ADC1->CR1 |= ADC1_CR1_ADON; //start AD conversion
- ADC1->CR1 |= ADC1_CR1_ADON; //啟動(dòng)轉(zhuǎn)換必須第二次使用寫(xiě)指令來(lái)置位寄存器的位
- ADC1_DeInit();
- //單次采樣,通道6,數(shù)據(jù)右對(duì)齊
- ADC1_ConversionConfig(ADC1_CONVERSIONMODE_SINGLE,ADC1_CHANNEL_6,ADC1_ALIGN_RIGHT);
- //f(adc)=f(master)/8
- ADC1_PrescalerConfig(ADC1_PRESSEL_FCPU_D8);
- //disable schmitt trigger
- //ADC1_SchmittTriggerConfig(ADC1_SCHMITTTRIG_ALL,DISABLE);
- //ADC1_SchmittTriggerConfig(ADC1_SCHMITTTRIG_CHANNEL5,DISABLE);
- //ADC1_SchmittTriggerConfig(ADC1_SCHMITTTRIG_CHANNEL6,DISABLE);
- //Enable the ADC1 peripheral
- AD_Start();
- //ADC1_StartConversion(); //初始化AD啟動(dòng)需要寫(xiě)兩次ADC1->CR1,以后只寫(xiě)一次就可以了
- //FLASH配置-EEPROM
- //Define FLASH programming time
- FLASH_SetProgrammingTime(FLASH_PROGRAMTIME_STANDARD);
- //FLASH_Unlock(FLASH_MEMTYPE_PROG);
- //Wait until Flash Program area unlocked flag is set
- //while (FLASH_GetFlagStatus(FLASH_FLAG_PUL) == RESET)
- //Unlock flash data eeprom memory
- FLASH_Unlock(FLASH_MEMTYPE_DATA);
- //Wait until Data EEPROM area unlocked flag is set
- //while (FLASH_GetFlagStatus(FLASH_FLAG_DUL) == RESET)
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval : None
- void assert_failed(u8* file, u32 line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
STM8S_StdPeriph_Template.rar
(448.15 KB, 下載次數(shù): 54)
2020-5-5 09:29 上傳
點(diǎn)擊文件名下載附件
控制程序
原理圖和PCB源文件.rar
(652.5 KB, 下載次數(shù): 70)
2020-5-5 09:29 上傳
點(diǎn)擊文件名下載附件
原理圖和PCB
AP1301車(chē)載空氣凈化器修改后-20130811更新.doc
(2.99 MB, 下載次數(shù): 54)
2020-5-5 09:29 上傳
點(diǎn)擊文件名下載附件
說(shuō)明文檔
