查看: 2330|回復: 0
基于51單片機HX711傳感器電子秤設計
ID:744211 發表于 2020-5-4 23:15 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
#include "main.h"
#include "HX711.h"
#include "uart.h"
#include "LCD1602.h"
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
long Weight_Shiwu = 0;
unsigned char flag = 0;
bit Flag_ERROR = 0;
sbit speak= P1^7;
//校準參數
//因為不同的傳感器特性曲線不是很一致,因此,每一個傳感器需要矯正這里這個參數才能使測量值很準確。
//當發現測試出來的重量偏大時,增加該數值。
//如果測試出來的重量偏小時,減小改數值。
//該值可以為小數
#define GapValue 400
//主函數
    Uart_Init();
    Send_Word("Welcome to use!\n");
    Send_Word("Made by Beetle Electronic Technology!\n");
        Init_LCD1602();
        LCD1602_write_com(0x80);
        LCD1602_write_word("Welcome to use!");
        Delay_ms(1000);                 //延時,等待傳感器穩定
        Get_Maopi();                                //稱毛皮重量
                EA = 0;
                Get_Weight();                        //稱重
                EA = 1;
                Scan_Key();
                //顯示當前重量
                if( Flag_ERROR == 1)
            Send_Word("ERROR\n");
                        LCD1602_write_com(0x80+0x40);
                        LCD1602_write_word("ERROR ");
                        speak=0;
                              speak=1;
            Send_ASCII(Weight_Shiwu/1000 + 0X30);
            Send_ASCII(Weight_Shiwu%1000/100 + 0X30);
            Send_ASCII(Weight_Shiwu%100/10 + 0X30);
            Send_ASCII(Weight_Shiwu%10 + 0X30);
            Send_Word(" g\n");
                        LCD1602_write_data(Weight_Shiwu/1000 + 0X30);
            LCD1602_write_data(Weight_Shiwu%1000/100 + 0X30);
            LCD1602_write_data(Weight_Shiwu%100/10 + 0X30);
            LCD1602_write_data(Weight_Shiwu%10 + 0X30);
                        LCD1602_write_word(" g");
//掃描按鍵
void Scan_Key()
        if(KEY1 == 0)
                Delay_ms(5);
                if(KEY1 == 0)
                        while(KEY1 == 0);
                        Get_Maopi();                        //去皮
//稱重
void Get_Weight()
        Weight_Shiwu = HX711_Read();
        Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                //獲取凈重
        if(Weight_Shiwu > 0)
                Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/GapValue);         //計算實物的實際重量
                if(Weight_Shiwu > 5000)                //超重報警
                        Flag_ERROR = 1;
                        Flag_ERROR = 0;
                Weight_Shiwu = 0;
        //        Flag_ERROR = 1;                                //負重報警
//獲取毛皮重量
void Get_Maopi()
        Weight_Maopi = HX711_Read();
//MS延時函數(12M晶振下測試)
void Delay_ms(unsigned int n)
        unsigned int  i,j;
        for(i=0;i<n;i++)
                for(j=0;j<123;j++);
HX711.7z
1.25 MB, 下載次數: 24, 下載積分: 黑幣 -5
收藏收藏 分享淘帖 頂1 踩
