查看: 2379|回復: 5
單片機紅外發射 怎么修改才能按一次只發射一次信號
ID:261025 發表于 2020-5-2 21:23 | 顯示全部樓層 |閱讀模式
用單片機矩陣鍵盤發射用戶碼數據碼  現在是按住不放連續循環發射  怎么改成按住只發射一次  用這個程序發射紅米手機發射解出來的碼控制機頂盒為什么不能控制
#include<reg52.h>////////////  12c5a60s2 晶振12M
static bit OP;
//#define uint unsigned int
uchar qishiok,count,key,flag,temp1;
uchar xinhaook,ding,qishiflag,temp2;
uchar temp;endcount,temp3,temp4;
uchar kaiok;
//int k01=0,k02=0,k03=0,k04=0,k05=0,k06=0,k07=0,k08=0;
//sbit key01=P1^7;
//sbit key02=P1^6;
//sbit key03=P1^5;
//sbit key04=P1^4;
//sbit key05=P1^3;
//sbit key06=P1^2;
//sbit key07=P1^1;
//sbit key08=P1^0;
uchar shu;
sbit P3_7=P3^7;
void init()
    TMOD=0x02;
    TH0=0xe6;
    TL0=0xe6;
    EA=1;
    ET0=1;
    TR0=1;
    flag=0;
    qishiok=0;
void time0() interrupt 1
        count++;
     if(flag)
      {P3_7=~P3_7;}
      {P3_7=1;}
void qishi() //發射起始
        int a;
                count=0;
        flag=1;
                for(a=0;a<2;a++)
                        endcount=173;
                do{}
                  while(count<endcount);
                          count=0;
        flag=0;
        count=0;
                endcount=173;
        do{}
        count=0;
        qishiok=1;
void jieshu() //發射結束
            int b;
                shu=0x02;
            count=0;
            for(b=0;b<4;b++)
          flag=1;
          do{}while(count<35);
          if(shu-(shu/2)*2)
                  ding=45;
                  ding=15;
              flag=0;
              count=0;
          do{}while(ding>count);
              count=0;
          shu=shu>>1;
void xinhao(uchar temp)        //發射信號
    int i;
    shu=temp;
    count=0;
    for(i=0;i<8;i++)
              flag=1;
              if(shu-(shu/2)*2)
                  ding=45;
                  ding=15;
              flag=0;
              count=0;
              count=0;
          shu=shu>>1;
          xinhaook=1;
void delay()//結束延時
  int i,j;
//  for(i=0;i<400;i++) //原程序
    for(i=0;i<100;i++)
    for(j=0;j<100;j++)
void fashe(temp1,temp2,temp3,temp4)
        init();
        qishi();
                xinhao(temp1);
        xinhao(temp2);
                xinhao(temp3);
                xinhao(temp4);
                jieshu();
            delay();
void main()//主程序
      P1=0xfe;
                if(P1==0xee)
                fashe(0x00,0xFF,0x45,0xBA);// 1          11101110
                if(P1==0xde)
                fashe(0x00,0xFF,0x44,0xBB);// 2          11011110
                if(P1==0xbe)
                fashe(0x00,0xFF,0x07,0xF8);// 3          10111110
            if(P1==0x7e)
                fashe(0x00,0xFF,0x16,0xE9);// A          01111110
          P1=0xfd;
                if(P1==0xed)
                fashe(0x00,0xFF,0x0C,0xF3);// 4
                if(P1==0xdd)
                fashe(0x00,0xFF,0x08,0xF7);// 5
                if(P1==0xbd)
                fashe(0x00,0xFF,0x42,0xBD);// 6
                if(P1==0x7d)
                fashe(0x00,0xFF,0x47,0xB8);// B
          P1=0xfb;
                if(P1==0xeb)
                fashe(0x00,0xFF,0x0C,0xF3);// 7
                if(P1==0xdb)
                fashe(0x00,0xFF,0x08,0xF7);// 8
                if(P1==0xbb)
                fashe(0x00,0xFF,0x42,0xBD);// 9
                if(P1==0x7b)
                fashe(0x00,0xFF,0x47,0xB8);// C
          P1=0xf7;
                if(P1==0xe7)
                fashe(0x00,0xFF,0x0C,0xF3);// *
                if(P1==0xd7)
                fashe(0x00,0xFF,0x08,0xF7);// 0
                if(P1==0xb7)
                fashe(0x00,0xFF,0x42,0xBD);// #
                if(P1==0x77)
                fashe(0x00,0xFF,0x47,0xB8);// D
ID:420836 發表于 2020-5-3 01:29 | 顯示全部樓層
可以使用上升沿單發觸發器來實現它。 只要沒有開關信號的翻轉,它只會觸發一次。 在軟件中實現非常簡單。 首先,檢查是否按下了鍵,并且沒有設置發射標志,如果是,則發射并設置發射標志; 由于設置了發射標志,因此無法重新進入發射例程; 設置發射標志后,停止輸出。 然后代碼檢查按鍵是否已釋放,如果已釋放,則清除發射標志和輸出。等待下一次觸發。
ID:213173 發表于 2020-5-3 08:21 | 顯示全部樓層
矩陣鍵盤按一次只發射一次信號
void main()//主程序
        bit sign=0;                        //按鍵自鎖標志
        uint count=0;                //消抖計數變量
        uchar num=0;                //臨時變量
                P1=0xf0;
                if(P1!=0xf0)                                //檢測有按鍵按下
                        count++;                                //消抖計數
                        if((count>=100)&&(sign==0))        //100~1000,根據主循環周期調整約10~20ms
                                sign=1;                                //按鍵自鎖標志置1
                                num=P1;                                //保存P1值xxxx 0000,x為0或1
                                num|=0x0f;                        //保存num按位或0x0f值xxxx 1111
                                P1=num;                                //賦值P1 xxxx 1111
                                switch(P1)
                                        case 0xee: fashe(0x00,0xFF,0x45,0xBA); break;// 1          11101110
                                        case 0xde: fashe(0x00,0xFF,0x44,0xBB); break;// 2          11011110
                                        case 0xbe: fashe(0x00,0xFF,0x07,0xF8); break;// 3          10111110
                                        case 0x7e: fashe(0x00,0xFF,0x16,0xE9); break;// A          01111110
                                        case 0xed: fashe(0x00,0xFF,0x0C,0xF3); break;// 4
                                        case 0xdd: fashe(0x00,0xFF,0x08,0xF7); break;// 5
                                        case 0xbd: fashe(0x00,0xFF,0x42,0xBD); break;// 6
                                        case 0x7d: fashe(0x00,0xFF,0x47,0xB8); break;// B
                                        case 0xeb: fashe(0x00,0xFF,0x0C,0xF3); break;// 7
                                        case 0xdb: fashe(0x00,0xFF,0x08,0xF7); break;// 8
                                        case 0xbb: fashe(0x00,0xFF,0x42,0xBD); break;// 9
                                        case 0x7b: fashe(0x00,0xFF,0x47,0xB8); break;// C
                                        case 0xe7: fashe(0x00,0xFF,0x0C,0xF3); break;// *
                                        case 0xd7: fashe(0x00,0xFF,0x08,0xF7); break;// 0
                                        case 0xb7: fashe(0x00,0xFF,0x42,0xBD); break;// #
                                        case 0x77: fashe(0x00,0xFF,0x47,0xB8); break;// D
                else                                                //鍵抬起
                        sign=0;                                        //按鍵自鎖標志清0
                        count=0;                                //消抖計數清0
ID:261025 發表于 2020-5-3 21:49 | 顯示全部樓層
wulin 發表于 2020-5-3 08:21
矩陣鍵盤按一次只發射一次信號
void main()//主程序
還是連續發射 不過程序簡化了很多   我又嘗試改了一下 現在發射一次就停止發射了 (不懂C語言 很多都看不懂不知道什么意思  每次改程序都憑直覺亂改的 走了很多彎路)
void main()//主程序
        uchar num=0;                //臨時變量
             P1=0xf0;
                                if(P1=0xf0)
                            count++;                                //消抖計數
                                sign=1;                                //按鍵自鎖標志置1
                                switch(P1)
                       else                                                //鍵抬起
                        sign=0;                                        //按鍵自鎖標志清0
                        count=0;                                //消抖計數清0
ID:311846 發表于 2020-5-4 09:25 | 顯示全部樓層
判斷是否松開按鍵,松開了才進行下一次發送,
ID:261025 發表于 2020-5-4 13:53 | 顯示全部樓層
權威人物 發表于 2020-5-4 09:25
我不懂C語言 只能有限度的修改
紅外解碼器解出的碼用這個程序發送控制網絡機頂盒無效   51遙控器個別按鍵能控制機頂盒  把那個碼用這個程序發出去也沒法控制   這個程序發出的碼用紅外解碼器還能正常解出來    不知道是哪的問題
