查看: 2819|回復: 5
code.c(6): error C129: missing ';' before 'table' 關于溫度監測
#include<reg51.h>
#define uint unsigned
int warn_l2 = 50;
int warn__shi=0;
uchar cod table[] = {
                                        0x3f,0x06,0x5b,0x4f,
                                        0x66,0x6d,0x7d,0x07,
                                        0x7f,0x6f,
                                        0xbf,0x86,0xdb,0xcf,
                                        0xe6,0xed,0xfd,0x87,
                                        0xff,0xef,
                                        0x40
void delay(int z)
        int a,b;
        for(a = 0;a < z ;a++)
                for(b = 0;b < 120; b++);
void  display(uchar num , uchar dat)
        uchar i;
        dula = 0;
        wela = 0;
        wela = 1;
        i = 0x00;
        i = i | (~(((0x01)<<(num))));
        P0 = i;
        wela = 0;
        dula = 1;
        P0 = table[dat];
        dula = 0;
        P0 = 0xff;
        dula = 0;
        delay(3);
void dis_temp(int t)
        uchar i;
        i = t100;
        display(1,i);
        i = t%10010;
        display(2,i+10);
        i = t%100%10;
        display(3,i);
        delay(5);
不知道要怎么解決求助各位大神
ID:592807 發表于 2020-5-1 21:55 | 只看該作者
uchar cod table[21] = { 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef,0x40};你為了讓數組看起來整齊用了很多空格,把空格刪了
ID:452950 發表于 2020-5-1 22:17 | 只看該作者
uchar code table[]
code拼錯了
ID:235200 發表于 2020-5-1 22:27 | 只看該作者
table前的cod改為code
ID:89217 發表于 2020-5-2 00:57 | 只看該作者
看來問題已經解決了
ID:742410 發表于 2020-5-2 12:49 | 只看該作者
解決了 謝謝各位大佬
