查看: 1563|回復: 0
為什么數碼管顯示的數字和我所設置的不同,而且第2和3和最后個數碼管會閃
ID:728467 發表于 2020-5-1 16:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
連線未有錯,用其他數碼管程序正常。想顯示111432然后減下去,可顯示的是452……
#include<reg52.h>
#include<intrins.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]=
{0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,
0x76,0x79,0x38,0x3f,0};
uchar temp,t0,t1,bai,shi,ge,flag,flag1,change,change1;
uint hou;
void delay(uint);
void display(uchar aa,uchar bb,uchar cc,uchar bai,uchar shi,uchar ge);
void init();
init();
  if(flag1!=1)
   display(1,1,1,bai,shi,ge);
   display(16,17,18,18,19,20);
void init()
{ change1=0;
change=0x7f;
hou=432;
temp=0xfe;
P1=temp;
TMOD=0X11;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
EA=1;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
{  P0=0x00;
        dula=1;
        dula=0;
  change1=_crol_(change,1);
   switch(change1)
    case 0xfe:P0=table[aa];
     break;
    case 0xfd:P0=table[bb];
     break;
    case 0xfb:P0=table[cc];
     break;
    case 0xf7:P0=table[bai];
     break;
    case 0xef:P0=table[shi];
     break;
    case 0xdf:P0=table[ge];
     break;
  change=change1;
        wela=1;
        wela=0;
        dula=1;
        dula=0;
  P0=0XFF;
        delay(5);
void delay(uint z)
uint x,y;
  for(x=z;x>0;x--)
   for(y=110;y>0;y--);
void timer0() interrupt 1
t0++;
if(flag!=1)
  if(t0==10)
  t0=1;
  temp=_crol_(temp,1);
  P1=temp;
    if(t0%4==0)
   P1=~P1;
  if(t0==60)
   TR0=0;
   P1=0XFF;
   flag1=1;
void timer1() interrupt 3
t1++;
  if(t1==2)
  t1=0;
  hou--;
  bai=hou/100;
  shi=hou%100/10;
  ge=hou%10;
   if(hou==398)
    TR0=0;
TR0=1;
flag=1;
t0=0;
P1=0XFF;
    TR1=0;
