查看: 42311|回復: 0
Proteus8.9 仿真STM32407ZGT6系列010_PWM多路可變頻率可調占空比輸出
ID:371233 發表于 2020-4-29 20:26 | 顯示全部樓層 |閱讀模式
一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
圖1
二,調整虛擬器件,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點擊Source Code標簽。(如下圖5所示)
圖5
四,編輯main.c,timer.c,timer.h, key.c,key.h, led.c,led.h 代碼如Proteus8.9 仿真STM32407ZGT6系列001(如下圖6所示)
圖6
五,Main.c 代碼:
/* Main.c file  generated by New Project wizard
* Author:   Ziegler Yin
*  Created:   周四 一月 16 2020
*  Processor: STM32F407ZGT6ZGT6
*  Compiler:  GCC for ARM
#include  "mfuncs.h"
#include  "delay.h"
#include  "usart.h"
#include  "led.h"
#include  "key.h"
#include  "timer.h"
#define RT(A ,  B) (A> 300)?  (B= 0):  (B=1)
uint32_t  gt_fig(u8 sts){
      if(1== sts) return  TIM_GetCapture1(TIM4);
      if(2== sts) return TIM_GetCapture2(TIM4);
      if(3== sts) return  TIM_GetCapture3(TIM4);
      if(4== sts) return  TIM_GetCapture4(TIM4);
void st_fig(u8  sts, uint32_t gt){
      if(1== sts) TIM_SetCompare1(TIM4, gt);
      if(2== sts) TIM_SetCompare2(TIM4, gt);
      if(3== sts) TIM_SetCompare3(TIM4, gt);
      if(4== sts) TIM_SetCompare4(TIM4, gt);
void  new_Pwm(u16 *tmbuf, u16 * mdc) {
      Pwm_Init(*(tmbuf+0), *(tmbuf+1));
      TIM_SetCompare1(TIM4, mdc[0]);
      TIM_SetCompare2(TIM4, mdc[1]);
      TIM_SetCompare3(TIM4, mdc[2]);
      Pwm_Init3(*(tmbuf+2), *(tmbuf+3));
      TIM_SetCompare2(TIM3, mdc[1]);
int main(void)
      u16 psc=840, per=600, idc[4]= {500, 200,  300, 400};
      u16 umd, pwmval=0, tm43[2][2]= {840,  600, 1680, 1200};
      u8 status= 0, dir= 1, chgFry[1]= {0, 0};
      int gtln= 0;
      char *wd, *wds, *lnslt[7]={"未選", "A線路", "B線路", "C線路", "D線路", "變頻1-A,B,C倍頻或初始狀態", "變頻2-D四倍頻或初始狀態"};
      NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置系統中斷優先級分組2
      delay_init(168);  //初始化延時函數
      uart_init(9600);//初始化串口波特率為115200
     LED_Init();
     KEY_Init();
      uprint("大家好。。r\n");
      uprint("大家來造呼吸機-----。\r\n");
                 gtln= nmtoa(wd, 10, psc);
                 uprint(wd);  uprint("\r\n");
                 gtln= nmtoa(wd, 10,  (psc+10000));
      LED0= LED1= LED2= 1;
      chgFry[0]= 0;
      chgFry[1]= 4;
      new_Pwm(tm43, idc);
      uprint("控制芯片STM32F407ZGT6_008_PWM仿真開始了。\r\n");
     delay_ms(100);
          wd= lnslt[status]; ;
           uprint("Arm運行時......占空比:\r\n");
           uprint(wd);
           uprint("線路可調整狀態:\r\n");
           if(1==ReadKey(GPIOC, 0x0080)) {
                 status++;
             delay_ms(20);
                 if(status> 6) status= 0;
                 uprint("線路調整狀態......占空比");
                 uprint(wd);
           if(1==ReadKey(GPIOC, 0x0010)) {
                 LED0= 1;
                 pwmval= gt_fig(status);
                 gtln= nmtoa(wds, 10, pwmval);
                 if(status>0){
                       if(per< (pwmval+ 50)) {
                                  uprint("線路調整, 占空值到達最高值  ......\r\n");
                                  st_fig(status,  (per+ 1));
                      else{
                            LED0= 1;
                            umd= pwmval +50;
                            uprint("線路調整, 占空值由  ");
                            uprint(wds);
                            uprint(" 增加50 至");
                            uprint(numtoa(10,  umd));
                            uprint("  ...\r\n ");
                            st_fig(status,  umd);
           if(1==ReadKey(GPIOC, 0x0020)) {
                 LED1= 1;
                 if(status==5) {
                      if(chgFry[0]==0) {
                            chgFry[0]= 2;
                            tm43[0][0]= 1680;
                            new_Pwm(tm43,  idc);
                            uprint("線路A,B,C頻率調整到倍頻...\r\n");
                            delay_ms(200);
                      else{
                            chgFry[0]= 0;
                            tm43[0][0]= 840;
                            new_Pwm(tm43,  idc);
                            uprint("線路A,B,C頻率調整到初始狀態...\r\n");
                            delay_ms(200);
                 if(status==6) {
                      if(chgFry[1]==0) {
                            chgFry[1]= 4;
                            tm43[1][0]= 1680;  tm43[1][1]= 1200;
                            new_Pwm(tm43,  idc);
                            uprint("線路D頻率調整到四倍頻...\r\n");
                            delay_ms(200);
                      else{
                            chgFry[1]= 0;
                            tm43[1][0]= 840;  tm43[1][1]= 600;
                            new_Pwm(tm43,  idc);
                            uprint("線路D頻率調整到初始狀態...\r\n");
                            delay_ms(200);
              delay_ms(20);
                 uprint("Arm運行時......占空比");
                 uprint(wd);
                 uprint("線路調整, 由  ");
                 uprint(wds);
                 uprint(" 清零 ");
                 st_fig(status, 0);
           if(1==ReadKey(GPIOC, 0x0040)) {
                 LED2= 1;
                 if(pwmval> 50) {
                 umd= pwmval -50;
                 uprint(wds);
                 uprint(" 減少50 至  ");
                 else {
                      umd= 1;
                      uprint("線路調整, 占空值到達最低值  ......\r\n");
                      st_fig(status, 1);
           LED0= LED1= LED2= 0;
          delay_ms(100);
key.c,key.h,  led.c led.h,time.c,time.h之前的代碼都可借鑒,不在多列,以后不再一一羅列,只列main.c 與相關功能的.c, .h代碼。
六,點擊構建工程按鈕,編譯工程。(如下圖7所示)
圖7
七,點擊窗口左下方仿真按鈕,可見紅,黃,綠燈點亮后一會滅,仿真開始,按下SELECT按鈕,選擇"變頻1-A,B,C倍頻或初始狀態", "變頻2-D四倍頻或初始狀態",按下按下KEY_ZERO按鈕,倍頻, 四倍頻或初始狀態。占空比的調試,參見:博主的Proteus8.9 仿真STM32407ZGT6系列009_PWM多路可調占空比輸出文。虛擬串口,示波器將的狀態變化顯示在屏。 (如下圖8,9,10,11所示)
圖8
圖9
圖10
圖11
八,選擇release,點擊構建工程按鈕,編譯工程生成Hex文件。(如下圖12所示)
圖12
九, 系列的001-003虛擬仿真與開發板對應已證明:虛擬仿真程序對于開發板有效,之后不再上下載到開發板的介紹。
附件Proteus8.9 仿真STM32407ZGT6系列010_PWM多路可變頻率可調占空比輸出在已安裝Proteus8.9的計算機文件夾中打開即可
需要進一步了解,請加入QQ群:976235464
010__PWM多路可變頻率可調占空比輸出pt.rar
366.48 KB, 下載次數: 57, 下載積分: 黑幣 -5
附件Proteus8.9 仿真STM32407ZGT6系列010_PWM多路可變頻率可調占空比輸出在已安裝Proteus8.9的計算機文件夾 ...
