查看: 4577|回復: 0
MSP430電池電壓采集Proteus仿真程序
MSP430電池電壓采集仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include <MSP430x24x.h>
  3. #define uint unsigned int
  4. uchar const table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,  //共陰數碼管段選碼表,無小數點
  5.                                0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  6. uchar table_volt[4] = {0};               //數組,存儲電壓值
  7. uchar Index;                            //變量
  8. //*******延時函數************//
  9. void Delay_ms(unsigned int t)
  10. {
  11.     unsigned int num;
  12.     while(t--)
  13.       for(num=1330;num>0;num--);
  14. }
  15. //ADC管腳定義
  16. #define ADCST0          P5OUT &= ~BIT4
  17. #define ADCST1          P5OUT |= BIT4
  18. #define ADCALE0         P5OUT &= ~BIT5
  19. #define ADCALE1         P5OUT |= BIT5
  20. #define ADCEOC0         P5OUT &= ~BIT6
  21. #define ADCEOC1         P5OUT |= BIT6
  22. #define ADCOE0          P5OUT &= ~BIT7
  23. #define ADCOE1          P5OUT |= BIT7
  24. #define ADC_Channel0          P5OUT &= ~BIT0
  25. #define ADC_Channel1          P5OUT |= BIT0
  26. unsigned int  ADC1 = 0;                                  //變量,采集電池電壓值
  27. //*******ADC采集啟動函數************//
  28. void ADC_START(void)
  29. {
  30.   ADCALE1;
  31.   ADCST1;
  32.   Delay_ms(1);
  33.   ADCALE0;
  34.   ADCST0;
  35.   Delay_ms(1);
  36. }
  37. //*******ADC采集時序實現函數************//
  38. unsigned int ADC_READ(void)
  39. {
  40.   unsigned int data;
  41.   data=0x00;
  42.   Delay_ms(1);
  43.   ADCOE1;
  44.   ADC_START();
  45.   Delay_ms(5);
  46.   data=P4IN;                    //讀取數據
  47.   ADCOE0;
  48.   return data;                          //返回數據
  49. }
  50. //*******主函數************//
  51. void main(void)
  52. {
  53.
  54.     WDTCTL=WDTPW + WDTHOLD; // 關閉看門狗
  55.     P2DIR=0xFF;            // 設置方向
  56.     P2SEL=0;            // 設置為普通I/O 口
  57.
  58.     P3DIR=0xFF;            // 設置方向
  59.     P3SEL=0;            // 設置為普通I/O 口
  60.
  61.     P2OUT=0x00;
  62.     P3OUT=0xFF;
  63.
  64.     P5SEL = 0x00;
  65.     P5DIR |= BIT0+BIT4+BIT5+BIT6;               //ADC芯片接口
  66.
  67.
  68.
  69.     while(1)
  70.     {
  71.
  72.          P3OUT=0xFF;
  73.          if( Index == 0 )                       //如果第一個數碼管顯示,加入小數點
  74.          {
  75.             P2OUT=table[table_volt[Index]]+0x80;//小數點
  76.          }
  77.          else                                           //其他不加
  78.          {
  79.             P2OUT=table[table_volt[Index]];             //顯示電壓值
  80.          }
  81.             P3OUT=~(1<<Index);
  82.           if(++Index==4) Index=0;
  83.          Delay_ms(1);                   //延時
  84.
  85.         ADC1 = ADC_READ()*20-80;                //ADC電池電壓采集,放大
  86.         table_volt[0] = ADC1/1000;               //千位
  87.         table_volt[1] = ADC1%1000/100;            //百位
  88.         table_volt[2] = ADC1%100/10;                            //十位
  89.         table_volt[3] = ADC1%10;                        //個位
  90.
  91.     }
  92.
  93. }
電池電壓檢測仿真.zip (439.18 KB, 下載次數: 47)
