查看: 2830|回復: 4
大佬幫忙看看,單片機沒電輸出,8段四位數碼管
ID:734017 發表于 2020-4-27 01:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
接線檢查過來,11對應,就是沒電來
用的是共陽8段四位數碼管,8段接P0,有上拉,片選接P0~P3
#include <reg52.h>
//                 0   1   2   3   4   5   6   7  8    9
unsigned char LED8DATA_One[10] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
//                 高位       底位
unsigned char LED8DATA_Two[4] = {0x01, 0x02, 0x04, 0x08};
unsigned char led[4] = {0x00};
unsigned char k=0;
int minute = 0,sec = 0;
unsigned int Counter=0;
void LEDDATA(unsigned char MM, unsigned char jj)
P1 = MM;
P3 = jj;
void Time1_Init()
TMOD |= 0X10;
TMOD &= 0XDF;
TH1 = 0XFC;
TL1 = 0X66;
TR1 = 1;
void int_Init()
ET1 = 1;
EA = 1;
Time1_Init();
int_Init();
while (1);
void interrupt_time_1() interrupt 3
TH1 = 0XFC;
TL1 = 0X66;
Counter++;
if (1000 == Counter)
  Counter = 0;
  sec++;
  if (sec == 60)
   minute++;
   sec = 0;
  led[3] = sec % 10;
  led[2] = sec / 10 % 10;
  led[1] = minute % 10;
  led[0] = minute / 10 % 10;
if (k < 4)
  k++;
  k = 0;
LEDDATA(LED8DATA_One[led[k]],LED8DATA_Two[k]);
ID:584814 發表于 2020-4-27 09:22 | 只看該作者
P1、P3是啥東東
ID:70069 發表于 2020-4-27 10:12 | 只看該作者
#include <reg52.h>
//                 高位       底位
unsigned char k=0;
P1 = MM;
P3 =jj;
void Time1_Init()
//TMOD |= 0X10;
//TMOD &= 0XDF;
EA = 1;
TMOD=0X10;
TH1 = 0XFC;
TL1 = 0X66;
ET1 = 1;
TR1 = 1;
void delay(int i)
{ int a,b;
for(        a=0;a<i;a++)
   for(b=0;b<200;b++)
Time1_Init();
while (1)
  { led[3] = sec % 10;
     if (k < 4)
        k++;
       k = 0;
     delay(5);
     P0=0X00;
TH1 = 0XFC;
TL1 = 0X66;
Counter++;
  Counter = 0;
  sec++;
  if (sec == 60)
   minute++;
   sec = 0;
TOMD定時器設置不對
ID:734017 發表于 2020-4-27 23:24 | 只看該作者
IO 口 P1和P3
ID:734017 發表于 2020-4-29 12:25 | 只看該作者
benclee 發表于 2020-4-27 10:12
#include
unsigned char LED8DATA_One[10]  ...
是我學習板上IO有沖突,謝謝你哦
